Go Back   Club3G Forums > Eclipse General Discussion > 1G/2G Eclipse General Discussion
Old 01/14/2008, 10:01 AM   #1 (permalink)
Mister Torpedo
Jeremy's Avatar
Vehicle: 1998 Eclipse GS-T
Jeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by allJeremy seems to be well-liked by all
Send a message via ICQ to Jeremy
Low.
As I continue to age in this 21st century, I grow less and less patient with the special needs of my vehicle. While it looks good sitting as low as it does, I was thinking even a subtle life might be in order. It's never sat as a Tokico/Prokit setup is supposed to. Both Eibach and RRE (from whom I bought the parts) say that it looks too low, but I've swapped out the springs to no change. Railroad tracks are brutal and I scrape on just about everything.
I've been considering buying a set of Ground Control coils, allowing me to raise the car up to exactly where I want. Probably about an inch.
Thoughts?
Jeremy is offline   Reply With Quote
Old 01/14/2008, 10:18 AM   #2 (permalink)
11/3/04 - 6/11/06
Doric's Avatar
Vehicle: 2005 GTO
Doric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club existsDoric is one of the reasons this club exists
My only thought is that you're getting old. The car's gorgeous as it sits.
I has a flavr
Doric is offline   Reply With Quote
Old 01/14/2008, 10:36 AM   #3 (permalink)
Mister Torpedo
Jeremy's Avatar
I knew you'd pop in here to tell me to just deal with it.
Old 01/14/2008, 11:07 AM   #4 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Sam has disabled reputation
Why Ground Control as a brand? They seem to make some hit or miss stuff, with a lot of complaints on different car makes that they squeak and rattle like crazy. Maybe that isn't an issue for you, but pulling into a parking lot while being accompanied by a cacophony of racket isn't my idea of a good idea.
Sam is offline   Reply With Quote
Old 01/14/2008, 11:13 AM   #5 (permalink)
Mister Torpedo
Jeremy's Avatar
True dat. I figured that they were reputable since they work with Eibach, but that might be me putting more faith in them than I should.
What's namely attractive is a $400 price point. I don't want full coils, just something that can work with my current damps.
I've had these springs for 6 years. I should probably just deal, eh?
Old 01/14/2008, 11:16 AM   #6 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Honestly, I would try some new springs and dampers all the way around. I can't remember if Eibachs are linear or progressive rates, but I would say to look for a new linear rate spring and some multi-valved dampers to freshen up the height and ride quality.
Old 01/14/2008, 11:19 AM   #7 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Oh yeah, and reading from not only the spring database here, but on practically every car forum I've ever seen, Eibachs sag like no other over time. Since you've had yours this long, it wouldn't hurt to junk 'em.
Old 01/14/2008, 11:22 AM   #8 (permalink)
Mister Torpedo
Jeremy's Avatar
They're actually relatively new. A couple of years ago I sent a pic of my car to Eibach to ask if it looked "normal." They said, "No." And sent me a new set.
But I did think of maybe going to a higher spring and keeping the tok's. They're adjustable which is nice. I don't want to replace them if I don't have to.
Old 01/14/2008, 11:25 AM   #9 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Are the Tokico's older? I could never get more than a few years out of my Illumina's on my other cars before they needed a change. I am not sure if that is the type you have, but in my experience they seem to wear out faster than they should.
Old 01/14/2008, 11:26 AM   #10 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Do you know what the spring rates are on your Eibachs?
Old 01/14/2008, 11:27 AM   #11 (permalink)
Mister Torpedo
Jeremy's Avatar
Tein makes their "high.tech" series, which is a subtle drop on the 2G. .8/.9 drop compared to "1.3" on the pro kit. They're only $190. Might be worth the adventure?
Old 01/14/2008, 11:31 AM   #12 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
I am running Tein STs on my car, and they are firm (the spring rates are almost 200lbs more than OEM) the HTs seem to give a moderate drop and offer a lot more forgiving ride than do the STs, at least from what I have been reading about them.
Old 01/14/2008, 11:31 AM   #13 (permalink)
Mister Torpedo
Jeremy's Avatar
Yeah. They HAVE been around for a while, but they still seem nice and firm. *shrug*
Old 01/14/2008, 11:34 AM   #14 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Hmm, well, I think that for the overall feeling of the car, you would really benefit from a spring/damper swap, but if the ride isn't a bother all that much, the spring swap would be fine too.
Old 01/14/2008, 11:34 AM   #15 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
I'd just stay away from the ground Controls though.
Old 01/14/2008, 11:37 AM   #16 (permalink)
Mister Torpedo
Jeremy's Avatar
I'm not sure what the rates are on my pro kits, Sam.
I love the look of my car, sitting low and all, but it's a serious bitch and camber is a serious pain. With an Ingalls camber adjustment set, I can only BARELY get a -.5° and that's with 2° of positive adjustment. It's LOW, man. I think .5" higher might be a nice subtle lift while keeping it looking nice.
As it sits now, I can barely get my thumb into either well above the tire.
There was a time that I did canyon stuff like a crazed psycho. I'd still like the option of going for a nice brisk cruise, but I don't need to be hugging the edge at 120. I don't race, I don't take it to tracks...Hrpmh.
Old 01/14/2008, 11:46 AM   #17 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
Yeah, I've been really backing off the ride height stuff too. I am at a moderate drop, but still only have 3" of clearance and that's a pain to deal with as is, I couldn't foresee myself going much lower. I run with a -1.9 camber on the rear and -1.4 on the front end, just because it's fun, and my car loves negative camber. I just don't like dealing with the ride height issues.
What I would suggest it, see if you can find the spring rates on your pro-kit, and see everything else available out there and compare spring rates, progressive or liner, and ride height. If you want clearance and comfort, you should look for a progressive spring, with a low spring rate at around an inch at drop, but not a whole lot more. I think you probably have a ton of choices actually.
Old 01/14/2008, 11:50 AM   #18 (permalink)
Mister Torpedo
Jeremy's Avatar
Probably do. Thanks for the words, Sam.
I don't know why you'd touch the suspension in a Z, honestly. Maybe it's just my lack of experience driving them, but they feel really, really tight from the factory.
My camber thing is hilarious. Since we get shitty weather and stuff, our roads warp and get really freakish ruts. There are times that I have to hold the wheel with both hands to keep the car from following the grooves like rails. I've had the car jerk itself into an adjacent lane as it falls off of the crest of the road. Fucked up, huh?
Old 01/14/2008, 11:59 AM   #19 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
No problem at all.
If I can give a numerical figure from one to ten on a Z from the factory, I would give OEM a solid 6, with springs, dampers and aggressive negative camber, I would give it a 9. It really makes a world of difference.
You know, that isn't necessarily a camber issue, that almost sounds like a tie rod, or tire issue, it sounds like tramlining, but it wouldn't make sense since I assume you are running similar branded and sized tires all the way around, right? So I would figure worn ball joints or tie rod ends, or your tires just have that "feature"" ( ) built into them.
I know that having gone through six different brands of tires on my car, I had some BFGs, and Toyo's on there and their soft sidewalls, and weird footprints had me all over the road, whereas the OEM Bridgestones with stiff as a board sidewall kept me glued straight and true.
Old 01/14/2008, 12:04 PM   #20 (permalink)
Mister Torpedo
Jeremy's Avatar
Ball joints, eh? Why would you say that? I would think cambered tires would pull into grooves, but maybe I'm wrong.
STOP GIVING ME THINGS TO WORRY ABOUT!
Old 01/14/2008, 12:09 PM   #21 (permalink)
Sam
Generally Bitter
Sam's Avatar
Vehicle: Yes
