Vehicle: mitsubishi eclipse gs-t
uprated piston set 4g63t
im after some uprated 4g63t pistons that keep the 2.0 liter but all i can find is 2.3 2.4 conversions im only wanting to get them to reinforce them with a new crank and connectiong rods can any1 lead me of there knowledge please.
Zoom FTW
you have to be pushing alot of power or have a really poor tune to worry about the 4g63 pistons. heck the NA 4G64 pistons are good to 13-15PSI no problems, probably more but they get replaced with rebuilds to lower the CR a little.
4G63 8.8 piston - Google Product Search
bosorio187: dude bosorio187: the streets are my race track bosorio187: i am tardo 1993 Geo Prizm 7A-FE/A245E with 130K miles. K&N drop in, deleted intake snorkel, +15 degrees base timing, Ebay Header, no rear muffler=zoom zoom peppy :) - still need to do the tbelt +10k miles overdue. |
im running standard at the moment but will change to the 16g turbo but i was just thinking about doing the internals aswell just as a saftey thing should i not bother then and keep them standard and save my money
Zoom FTW
im sure someone else will chime in with more knowledge than i have, but the google link i provided does have some piston sets for your engine.
i took a look at them i can get the cosworth pistons easy as there factory is not far from me and look good and had a few reviews in super street not long ago and they came out the best but if you say there ok then ill leave them for now.
also why i got you here can you help on brake fluid? ive got dot 3 in as standars but i want to go higher can i go to dot 5.1 or should i go for dot 4? as im getting a little brake fade on dot 3 thanks |
Zoom FTW
your brake fade is more likely the pad compound than it is the fluid. boiling fluid doesnt feel like fade, it feels like you have a spongy pedal. fade feels like you're pressing the pedal but its not doing as much stopping as it should. 2 pretty different feelings.
dot4 should be fine, just keeping fresh fluid in there is more important. fluid should be changed about every 2 years, more often if you live where its very damp and humid. as for pads, hawk hps pads seem to be pretty darn good. some people complain that they squeek or squeel, i havent had any of that. they are a bit on the dusty side. theres other pads out there, but i dont have personal experience with them. check out a site like tire rack and see whats available for your car. when it comes to rotors, plain rotors are just fine. slotted are ok too, but wear the pads slightly faster. drilled are much much more prone to cracking and breaking than regular or slotted rotors are.
ok il check the pads then i did want hawk but couldnt get them at the time living in the u.k its pretty hard for some products to get and time aswell and they needed to be done quickly. so it wouldnt harm to go dot 5.1 at the same time?
i know all about the discs i had drilled on my old clio williams and they cracked within a year so i changed to grooved and they were the best. i know ebc make a racket as i had them on my old skyline red stuff they were awful as they got rid of mose of the asbestos and caused noises. but if hawk or good then ill go for them. untill project mu come up with a caliper and disc for the 95-99 gst eclipse! thanks for all your help mate and nice chatting to you aswell |
Zoom FTW
dot 5.1 is obscenely expensive and generally pretty hard to find. just get some off the shelf dot4 from a local autoparts retailer.
im lost dot 5.1 is not expensive i had ap racing dot 5.1 and it cost me less then £40 for the whole fill plus bleeding and i still had some left over thats about $80 why is it so hard to find in the states?
#10 (permalink) | |
Zoom FTW
450F or 230C dry boiling point is PLENTY high from 99% of driving.
