Go Back   Club3G Forums > Eclipse General Discussion > 1G/2G Eclipse General Discussion
Old 08/29/2008, 10:29 PM   #1 (permalink)
Just some guy
agtmurphy : who are you?
Send a message via MSN to agtmurphy
Sound like a bad distributor?
So one of the girls I work with has a 98 RS, and it just stopped running on her and will not crank up now. Motor turns over with starter but does not run, I checked all of the fuses, made sure there was fuel in the tank, stuck a screwdriver into the spark plug wires and had someone turn the key, no spark to a ground, so I am thinking the distributor is bad. Just wanted to see if anyone thought that sounded right, or if there is anything else I should look at before I go ordering parts, since no part stores here have or can get the distributor for it. I am trying to keep her dad from having to come down here and tow it 4 hours north to his mechanic in Atlanta, and any help or input would be greatly appreciated.
agtmurphy is offline   Reply With Quote
Old 08/29/2008, 10:41 PM   #2 (permalink)
Zoom FTW
Bitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club existsBitter is one of the reasons this club exists
Send a message via AIM to Bitter Send a message via Yahoo to Bitter
broken timing belt?
Old 08/29/2008, 10:48 PM   #3 (permalink)
Just some guy
oh yeah, meant to mention that, I took off the cover, it looks good, that was my first concern when she asked me to look at it. She said she has had it for about a year and a half and bought it from a guy that owns a shop that put a new motor in it before she bought it. On a side note, the guy put an intake on it that is obviously not meant for the car, just kinda sitting in there, held on by the hose clamp, about 2.75" or 3" pipe running into a bent up reducer to connect to the engine. So, im really not sure how much whoever put the motor in actually knew what they were doing...
Old 08/29/2008, 10:51 PM   #4 (permalink)
Zoom FTW
you need to see the engine crank and the timing belt move. it can be snapped down by the crank and you wont see it. or the tensioner could have failed the belt isnt tight enough to engage the crank or cam sprockets.
Old 08/29/2008, 11:00 PM   #5 (permalink)
Just some guy
I pushed on it and it seemed pretty tight, but will take it off again tomorrow and have someone turn the key with it off and see what happens. Would that explain the lack of spark from the ignition coil? This is the part I am looking at getting if the belt isnt the problem. NAPAONLINEŽ
Thanks for the help btw
Old 08/29/2008, 11:01 PM   #6 (permalink)
Zoom FTW
yes, that would explain no spark AND lack of pulse to the fuel injectors.
so would a bad crank or cam position sensor
Old 08/29/2008, 11:02 PM   #7 (permalink)
Just some guy
any way to check to see if those are bad? and how hard to change those?
Old 08/29/2008, 11:05 PM   #8 (permalink)
Zoom FTW
you'll need some diagnostic knowledge and either a code scanner with data stream display or a multi-meter.
Old 08/29/2008, 11:07 PM   #9 (permalink)
Just some guy
got a multimeter, dont have a code scanner, but could probably borrow one
Old 08/29/2008, 11:08 PM   #10 (permalink)
Just some guy
you have a link to the manual for 2nd gen eclipse? I have the one for the 3rd gen, or is the motor pretty much the same?
Old 08/29/2008, 11:10 PM   #11 (permalink)
Zoom FTW
no, you're more similar to the DOHC motor in the same years of dodge neon than any mitsubishi engine.
Old 08/31/2008, 11:03 PM   #12 (permalink)
Just some guy
Ok, so now pretty sure the crank position sensor is the problem. Once I found it, removed the bolt, and the plastic part outside the engine fell off, leaving the sensor itself with a piece of the plastic attached stuck inside the block. Only way I can come up with to get it out is patience with a pair of pliers/screwdriver/etc. Any other ideas on getting it out?
Forum Jump
Forum Jump
Page generated in 0.92983007 seconds (100.00% PHP - 0% MySQL) with 11 queries
Search Engine Friendly URLs by vBSEO 3.2.0
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
