Vehicle: 2001 GT 5 speed
clutch
is it just me or is the clutch on our cars alot different from most cars? ive allways had honda and i have to say they feel alot more... idunno... responsive or somthing.(sorry guys don't get me wrong i love the 3g.) i was jw.
2001 Eclipse GT (Fed spec) DNX custom catback exhuast Ebay hps CAI (3 not 2.5) SPEC stage 2 clutch KYB AGX TEIN S-TECH's Megan racing strut tower support Ngk plugs ebay short shifter Energy suspension shifter bushings Khumo ecasta 711 tires TYC black tails clear front turn signals LED blue wireless underglow LED blue interior glow sweeet rad racing pedals/knob. |
Blow My 6G72
I'd say that my 3G clutch feels "looser" or ya, unresponsive when compared to my 96 Corolla or 91 Storm. I figured that it had something to due with it being a V6 as oppossed to my older 4 bangers. Just a guess though...
Perf Mods: Injen WAI, Diamante Mani/TB, Ripp Headers, Invidia Catback w/ 24" Hushpower II Resonator, Fidanza L/W Flywheel, Spec S3, Quaife LSD, ZT2/WB/EGT/Boost, Upgraded/Flashable ECU, AGX/Progress, Camber Kit, Pat.Perf. Endlinks, D/S iRotors, Deyeme/Ripp/IngallsETD Mounts, VR4 Fuel Rails, Venom 310cc Injectors In Progress: ECUFlash, Aeromotive FPR, All SS lines, SDS |
yeah man thats exactly what i was thinking. maybe i'm just not used to 6 cylinders. i hope thats what it is lol
Tango Sucka!
The V6 clutch is different than a conventional clutch, it's a pull style clutch. Like what is found on the Evo and the Supra, not a conventional push style clutch.
Russ Sanderlin - Twitter - Facebook - Blog Mitsubishi Eclipse - Generation Gap Eclipse Tech - *New* 5G Eclipse - 2006+ Eclipse Forums - Mitsubishi Mid Atlantic - Mitsubishi Florida |
ASSHOLE!
plus hondas feel more responsive because most of them are cable clutches not hydrolic
http://www.myspace.com/mustangfreak1983 |
Tango Sucka!
Very true.
ASSHOLE!
actually true cause the 96 civic i built last year was cable clutch
#9 (permalink) | |
EDIT: and if you want proof, here you go http://hondaswap.com/reference-mater...n-specs-29132/ |
whats the difference between a push style clutch and a pull clutch.
![]() Join Date: Jan 2002
The throw out bearing on our clutch snaps into the fingers of the pressure plate and when you press on the clutch pedal the TOB pulls the fingers of the pressure plate. This allows for a longer lever arm in the pressure plate, which lowers the amount force needed to open the clutch.
On most conventional clutches the TOB pushes the fingers of pressure plate in. Another factor for poor clutch pedal feed back is that we have a dampner on the hydrolic system. I think it can be removed, and I wanted to try it, but I have been busy. The rubber lines could also be swaped out for braided lines, if the right fittings could be found. Clutch disengagement idea |
wow thanks alot guys good things to know
