Go Back   Club3G Forums > Performance & Tech Forums > 3G Eclipse GT/GTS Specific
Closed Thread
Old 05/07/2008, 10:51 AM   #1 (permalink)
Radarcontact's Avatar
Vehicle: 2001 Spyder GT
Radarcontact is similar to TE
Thumbs down lightweight flywheel question
I am going to need a new clutch soon.
Has anyone replaced their OEM flywheel with a lightweight version?
Any noticable improvement???
Sound:
Pioneer Premier FHP800BT double-din
JL 300/2 running CDT HD-65 fronts,
JL 250/1 running JL 12w3v2 @ 4-ohm in custom sealed enclosure (by me)
JL e2150 running Polk db690 rears
ALL new wiring, lots of sound deadening,
4 ga, blocks, relays, etc.
Other:
AEM CAI (red)
Billet wheel spacers
minor exterior mods/tweaks
Radarcontact is offline
Old 05/07/2008, 10:56 AM   #2 (permalink)
SCC-PHOTOGRAPHY.com
HIJACKER's Avatar
Vehicle: 04 NSX, 10 Murano, 08 Alt
HIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends here
You're starting a LOT of new threads today...
Try this:
http://www.club3g.com/forum/search.php
Also, what's the deal with a thumbsdown on every thread you create?
HIJACKER is offline
Old 05/07/2008, 12:12 PM   #3 (permalink)
Blow My 6G72
NC[Spyder]GT's Avatar
Vehicle: 01 Spyder GT 5spd
NC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regularNC[Spyder]GT should be considered a regular
Send a message via MSN to NC[Spyder]GT
1) Man people have, me included.
2) I like to think so, butt dyno says yes. However, I did not do a before/after dyno run plus I had swapped in a Spec clutch and Quaiffe LSD at the same time so dyno results would not have been completely accurate.
NC[Spyder]GT is offline
Old 05/07/2008, 01:27 PM   #4 (permalink)
Vehicle: 03 GTS 3.6L 6g74
GSXROFDFW seems to be okayGSXROFDFW seems to be okayGSXROFDFW seems to be okayGSXROFDFW seems to be okayGSXROFDFW seems to be okayGSXROFDFW seems to be okay
Maybe not the same for others but I did definitly notice a driveability difference as far as unstable idle and almost stalling out when all I had was the alum flywheel, headers and CAI. It was a little better after tuning and I also bumped my idle up a little.
on the plus side the lighter flywheel in conjunction with all 4 solid motor mounts and the just recently added stiffy torque dampener make for excellent throttle response and modulation. The best part of my car I think.
When you push in the clutch to shift the rpms fall off a lot quicker. You have to shifter a little faster than before to conpensate for this. It takes a while to get used to but once you do it is a lot of fun to drive
GSXROFDFW is offline
Old 05/07/2008, 01:32 PM   #5 (permalink)
Tango Sucka!
Tearstone's Avatar
Vehicle: 02 EclipseGT 91 MR2 Turbo
Very rarely do we ever sell a clutch without a flywheel. Chances are you'll need to resurface your flywheel anyways. But while you are in there replacing your clutch, why not treat yourself with extra weight off of your crank?
Tearstone is offline
Old 05/07/2008, 01:34 PM   #6 (permalink)
stilwrks's Avatar
Vehicle: 00' GT 5 spd
stilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okaystilwrks seems to be okay
Yes & yes!
COLDWELL BANKER RESIDENTIAL BROKER
"I'LL ALWAYS HAVE TIME FOR YOUR REFERRALS"
2000 Mitsi. Eclipse GT 5 spd. # 310 TTD
stilwrks is offline
Old 05/07/2008, 05:14 PM   #7 (permalink)
Vehicle: 00 Eclipse GT
EclipseofVa : who are you?
Send a message via AIM to EclipseofVa
I agree with Tearstone, i did my clutch + flywheel at the same time. Might as well, its less pain if you decide to do it later.
I cut vinyl decals let me know if you need any
00 Eclipse GT (fs/ft pm for info)
91 Laser RST
EclipseofVa is offline
Old 05/07/2008, 05:53 PM   #8 (permalink)
Rotary fanatic
2g Strat's Avatar
Vehicle: 2001 Dodge Stratus
2g Strat : who are you?
I notice its kinda hard to climb the threshold into the garage(pretty steep), but i never drove it before to tell you for sure.
01 Stratus R/T: 5spd, 6g74 swap, N2o 75hp
2g Strat is offline
Old 05/07/2008, 07:37 PM   #9 (permalink)
Blow My 6G72
I figured I had to pay someone to drop the tranny for either piece and at $400-600 in labor charges for EACH time the tranny is removed I figured I'd save so much $$$ by forking out the FW money then (sametime install).
Perf Mods: Injen WAI, Diamante Mani/TB, Ripp Headers, Invidia Catback w/ 24" Hushpower II Resonator, Fidanza L/W Flywheel, Spec S3, Quaife LSD, ZT2/WB/EGT/Boost, Upgraded/Flashable ECU, AGX/Progress, Camber Kit, Pat.Perf. Endlinks, D/S iRotors, Deyeme/Ripp/IngallsETD Mounts, VR4 Fuel Rails, Venom 310cc Injectors
In Progress: ECUFlash, Aeromotive FPR, All SS lines, SDS
Old 05/07/2008, 08:23 PM   #10 (permalink)
steadly2004's Avatar
Vehicle: Stratus 2.4L
X3.... lol I am swapping in the new motor with the new tranny, and figured with all the trouble of getting shit in and out I probably won't want to do it again for a long time.
steadly2004 is offline
Closed Thread
Page generated in 0.42401600 seconds (100.00% PHP - 0% MySQL) with 11 queries
