This has all been talked about for a while, theories of how to go about it and so on. I have recently been working with somebody on creating the "Big Map" for the 01-03 Galant, and 01-05 Eclipse V6 platforms running boost. Currently however we only have this one ROM finished for the 05 (which I believe should suit the 03-05 V6), the 01-02 ROM will be worked on next when this initial patch is finalized...please be patient.
Current Features on this patch;
"Big Maps" High/Low Octane Ignition and Fuel (30 x 30)
Knock on CEL
MUT Table
2Byte Load
MAF Clipping Coefficient
Injector Battery Voltage Latency Compensation
Accel Enrichment
Open Loop Load #1 and #2
Min Coolant Temp for Closed Loop
Injector Scaling
MAF Scaling
MAF Smoothing
MAF Sensor Filtering
MAF Size
Rev Limit
Speed Limit
Desired ISCV initial step position with AC on/off - Drive/Neutral
Desired Idle RPM Neutral/Drive
High Octane Fuel Map
High Octane Ignition Map
Knock on CEL, MUT Table
This patch is all done by "Acamus" and he is doing this on a "donationware" basis. Any and all donations are greatly appreciated to show appreciation for his hard work, and continued support with developing this patch. V6 Patch Donation
Acamus added a table that switches Pin 32 with a duty cycle based on Load and RPM. AFAIK, we're supposed to make sure the ROM runs like usual, and if possible, monitor or log MUT_86 for solenoid duty. Pin 32 is used on GTS models to control the variable induction solenoid, but I confirmed that the pin works properly on GT models when run with the right ROM.
I didn't get the car flashed last night like expected, but I'm going to flash it before I leave work. I'll probably hook up an LED to visually confirm that the duty cycle is varying like expected.
Acamus added a table that switches Pin 32 with a duty cycle based on Load and RPM. AFAIK, we're supposed to make sure the ROM runs like usual, and if possible, monitor or log MUT_86 for solenoid duty. Pin 32 is used on GTS models to control the variable induction solenoid, but I confirmed that the pin works properly on GT models when run with the right ROM. I'll probably hook up an LED to visually confirm that the duty cycle is varying like expected.
It would be better to get some cheapooscilloscope now that the duty can be measured at the pin also.
Otherwise we have only qualitative result i.e. LED will change its illumination intensity according to the duty.
Acamus, I was unable to get my car to start using the newer version of the BigMaps ROM that you sent me. It seemed like it was an immobilizer issue, although I tried using both normal and disabled immobilizer settings, and several points in between.
i just finished moving all my tables over (copying from one rom to another)... I did notice one thing though, this rom doesn't have the EGR tables defined (tables 1 and 2) :scratch:
i'll have results in a few minutes here...
edit... nvm, i just noticed the tables under "EGR" ..
I don't think that would make a difference considering that I've run several different ROM ID's on my car without trouble. My guess is that the problem is well above my abilities to correct.
Acamus, I compared the ROMs using EcuFlash, and it's coming up with differences in FB01, 02, 04, 10, 11, and 12. Does that sound correct to you? Also, Dragon, does that match what you saw as well?
I'm either not explaining it clearly or you never thought about it. Does this look familiar? This is what comes up when you flash a new ROM or use the compare to ROM function in EcuFlash. These are my results . . .
Cool, i'll give it a try first thing in the morning, meanwhile... back to arguing with the gf on the phone lol (yes, I am replying to this over the phone while getting bitched out lol)
Any chance I can get one of these ROMs for my 2000 GT Manual - H8539F - 21810021? I've got $$ for ya if I can finally remove my emanage and safely tune up past my current 10psi limit.
ecuflash crashes everytime i try to open the new rom. Care to take a look into that issue? (just to be sure it was the rom itself i was able to succesfully open 2 other roms, so the problem isn't ecuflash, the problem is the new rom)
Dragon (and Acamus), I thought it was just my copy of EcuFlash. It can't find a definition for the ROM and if I try to create one, EcuFlash crashes. There aren't any items in the drop down menu for the 'copy from' or 'inherit from' options.
My problem with wiring in my 01 ecu last time around was that it wanted more (precat) O2 sensors. I don't suppose this ROM could be made to not need those inputs...?
Why not buy a harness online and wire the bank 02's into that? That way you won't mess up the car given a mistake or two and you'll have wires you can use instead of pins directly in the ECU. I was actually thinking about doing this, correct me if it won't work. :dunno:
There are a couple of periphery bits that deal with disabling oxygen sensors, although I have not experimented with them. My gut feeling is that it should be possible . . .
I just tried it with a 00 in there... Still wouldn't start up. I dunno if this piece of info would help at all but i just noticed when i tried to get the DTC's off the ECU after i flashed it with the project rom, Evoscan would not connect to the ecu. Not only that, i tried starting up evoscan to start datalogging with the key in the "on" position and it also would not connect to the ecu.
It starts up... dunno if the pin is putting out the desired amount of voltage though. I'll have to find my volt meter and connect it up to pin 32 sometime later today. Thanks again!
(will donate some more for taking your time in to helping us out )
Dragon, nice catch with the EvoScan test. I didn't even think about trying that when I was testing the ROM.
I copied the ROM to my car and it seems to work well. Logging in EvoScan showed that the solenoid tuning MUT address was changing, but the scan frequency was insufficient to determine the rate of change. I might try picking up a cheap PC based oscilliscope to completely verify operation.
:scratch: .... how do you log pin 32 in evoscan? Better said, what address did you input into evoscan to pick up on the change?
A little OT but i thought i'd mention it anyways... I'm fearing that my ECU is reaching a point where it no longer will be "completely" flashable. The reason i say that is because when reading off the ECU about half off the maps and tables come back as garbage :'(
Related Threads
Mitsubishi Eclipse 3G Club
2.8M posts
48.6K members
Since 2004
