Cylinder number and firing order - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 02/24/2005, 01:46 PM   #1 (permalink)
///M
wiltshp's Avatar
Vehicle: 2004 BMW M3
wiltshp : who are you?wiltshp : who are you?wiltshp : who are you?
Send a message via AIM to wiltshp Send a message via Yahoo to wiltshp
I tried the search and I can't seem to find anything, does anyone know which cylinders are which number and what the firing order is? I.E. If I have to find TDC of cyl 1, which cyl is 1 and so forth. And then what order does each cyl fire at. Thanks!
wiltshp is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 01:48 PM   #2 (permalink)
Never Too Much HP
myrt's Avatar
Vehicle: 01 Strat R/T
myrt : who are you?myrt : who are you?
Send a message via AIM to myrt
FRONT BANK: (going from belts to tranny) 2,4,6
BACK BANK: (going from belts to tranny) 1,3,5
firing order 1,2,3,4,5,6
myrt is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 01:51 PM   #3 (permalink)
///M
wiltshp's Avatar
That sounds like an odd firing order. I was guessing 1,4,5,2,3,6 but I could be wrong. Thanks though!
Old 02/24/2005, 02:01 PM   #4 (permalink)
Never Too Much HP
myrt's Avatar
let me find that fast4ward site and make sure. give me 20
Old 02/24/2005, 02:09 PM   #5 (permalink)
Never Too Much HP
myrt's Avatar
http://www.fast-4ward.com/3GsvcManual/11C.PDF
go to the top of page two. it will give you everything
Old 02/24/2005, 02:35 PM   #6 (permalink)
Sebring 6G72
Burn504's Avatar
Vehicle: Sebring Swapped 6G72
Burn504 : who are you?
Send a message via AIM to Burn504
Myrt is right 123456
Burn504 is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 02:38 PM   #7 (permalink)
Never Too Much HP
myrt's Avatar
damn iam good
Old 02/24/2005, 03:47 PM   #8 (permalink)
///M
wiltshp's Avatar
According to what you call the front and back bank, the front bank is actually the back bank when you are standing in front of the car then? According to the website it says 1,3,5 is on the right hand side when you are standing at the belts. So 2,4,6 would be next to the fire wall. In conclusion, and correct me if I am wrong, if you are standing in front of the car with the hood popped the cylinders and firing order would look like this.
246
135
Old 02/24/2005, 03:50 PM   #9 (permalink)
Got Boost? Me either
Eclipsed4utoo's Avatar
Vehicle: '03 Red GT
Eclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okayEclipsed4utoo seems to be okay
Send a message via AIM to Eclipsed4utoo
sounds right
Eclipsed4utoo is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 04:19 PM   #10 (permalink)
MattS00's Avatar
246
135
^^^^This is not correct
Cylincer #1 is always the one closest to the timing belt. This happens to be on the bank CLOSEST to the fire wall. So the rear bank containts 1,3,5 and the front bank that you see as soon as you open the hood has 2,4,6.
MattS00 is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 04:28 PM   #11 (permalink)
Formerly Nokio
Vehicle: Kia Sorento
Korey : who are you?Korey : who are you?Korey : who are you?Korey : who are you?Korey : who are you?
Send a message via AIM to Korey
yeh, the firing order sounded a little different to me, too...
-Korey
Korey is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 04:32 PM   #12 (permalink)
///M
wiltshp's Avatar
According to the website this is what it says.
The 6G72 (3.0L) engine is a six-cylinder engine. The cylinder numbers are assigned as 1-3-5 for the right bank and 2-4-6 for the left bank from the front of the engine (timing belt side). This engine is fired in the order of 1, 2, 3, 4, 5 and 6 cylinders.
When the hood is opened the timing belt is on the left hand side when you are standing in front of the car. So in turn, if you walk to the passenger side of the car and look at the engine the timing belt is closest and the tranny is furthest away. Am I confused on what I have italisized. This is how I am interperting the right and left bank. If that's the case then the right bank is towards the front and the back bank is towards the firewall. Sorry for sounding so dumb but can someone please clairify this. Thanks!
Old 02/24/2005, 04:39 PM   #13 (permalink)
MattS00's Avatar
You are reading it wrong. Right bank/Left bank comes from RWD vehicles. The point of view is from the drivers seat. In our FWD transverse engines the point of view is from the transmission side. Therefore if you are standing on the drivers side, cylinder # 1 is the furthest cylinder away from you (nearest the timing belt).
Old 02/24/2005, 04:41 PM   #14 (permalink)
///M
wiltshp's Avatar
Ahhhhhhh.......... so the order should be:
135
246
Old 02/24/2005, 04:48 PM   #15 (permalink)
Sebring 6G72
Burn504's Avatar
135
246
yup
it comes from RWD terms.... just imagine spinning your engine and trans to the RWD position and that would be the left/right banks...
Old 02/24/2005, 04:52 PM   #16 (permalink)
///M
wiltshp's Avatar
Thanks guys!
Old 02/24/2005, 05:21 PM   #17 (permalink)
chinchooter11 : who are you?
esay way to find what cylinder is number one is look at the front of the ENGINE i mean where all the pullys area and the timing gears are not the front of the CAR. THen see what head is sticking out farther that should be cylinder number one. for all that dont under stand ill draw it up.
chinchooter11 is offline   Reply With Quote Quick reply to this message
Old 02/24/2005, 06:50 PM   #18 (permalink)
Malveaux's Avatar
Vehicle: 2000 GT
Malveaux : who are you?Malveaux : who are you?
my plug wires are numbered aren't yours? chinchooter is right. firing order is indeed 123456. I just replaced plugs and wires and switch a wire around. oops!
Malveaux is offline   Reply With Quote Quick reply to this message
Old 02/25/2005, 10:44 AM   #19 (permalink)
///M
wiltshp's Avatar
I changed my plugs and wires sometime ago. They weren't numbered!
Old 04/20/2005, 05:23 PM   #20 (permalink)
frozen
simeone33's Avatar
Vehicle: 00gt sds
simeone33 : who are you?simeone33 : who are you?
Send a message via AIM to simeone33
i know this is an old post, but im tryin to figure out where to attach to the dist.
if your standing in front of the car, and look at the dist, there are 3 that attach to the back and three that attach to the front, what is the front top, mid and bottom, and back top, mid bottom?
simeone33 is offline   Reply With Quote Quick reply to this message
Old 04/20/2005, 05:59 PM   #21 (permalink)
Sebring 6G72
Burn504's Avatar
THE distributor cap is numbered....
the engine goes like this..
back 3 on engine are 1 3 5
front 3 on engine are 2 4 6
cap is numbered so attach the right number on the cap to the engine.
Old 04/20/2005, 06:02 PM   #22 (permalink)
frozen
simeone33's Avatar
Vehicle: 00gt sds
allright, thanks alot...
Old 04/20/2005, 08:39 PM   #23 (permalink)
bollocks
darklink's Avatar
Vehicle: 04 Z/00 3g
darklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by all
Send a message via AIM to darklink Send a message via MSN to darklink Send a message via Yahoo to darklink
*IF* i remember right, its 315 and 426 on the the distro cap. as stated above, it is also stamped into the plastic
darklink is offline   Reply With Quote Quick reply to this message
