Kampfbereit
The 6G74 and 6G72 heads are identical except for the cams and the distributor.
Russ Sanderlin Eclipse Tech - Club, Association, Event and Custom Decals Liberty Maxim - Turbo Magazine Feature |
#3 (permalink) | |
Ah yes...
However, the reason for the 3.5L camshafts is simple enough, different valve clearances and opening and closing, and then the distributor needs to be changed because the 3.5L camshafts have different 'key' design and the 3G distributor would not fit. |
#4 (permalink) | |
Kampfbereit
I would surmise that 3.5L camshafts are different because the timing belt has further to travel due to the increased height of the engine. Yes, the distributor is different due to the key in the cam, but aesthetically the distributors are different as well.
#7 (permalink) | |
Ah yes...
Kampfbereit
Yes the SOHC 6G74 out of the Diamante is a direct swap. The only thing you run into is changing out the axle bracket in the back.
Diamante guys have been using our 5spd transmissions to do their 5spd swaps for years now. Another note, is that if you retain the use of the Diamante Plenum you can't use the strut bar anymore, but from what it looks like the GT plenum will still clear with the strut bar still on. BTW, where are you getting these images from, is it that one thing you were supposed to send me that time ![]() Regardless, I can get you guys a great price on full 6G74 engines complete with exhaust intake/exhaust manifolds through one of our guys here in Florida. If anyone is interested, I am currently getting 6G74 CP pistons made and if anyone would like to jump on board for a short or long block let me know. http://www.diamanteowners.com/forum/...howtopic=82650
#11 (permalink) | |
Ah yes...
As far as the axle brackets. Which ones are you talking about? |
#12 (permalink) | |
Kampfbereit
Lance Corporal
Vehicle: 04 Cummins 4x4
Well damn. I was planning on using a VR4 block for my build but now Im thinking about this 3.5L. How far out can this motor be bored? 3.8? 4.0!!!??
And no shit Kris where do you get those breakouts from?? I want!!!
Gig'em Aggies!!! My Spyder Only two defining forces have ever offered to die for you: 1. Jesus Christ 2. The American G. I. Motivated Lance Corporal of Marines! OOHRAH! |
#15 (permalink) | |
Kampfbereit
![]() Dude, just putting the 6G74 in a N/A car makes a world of differnce in power. I was considering just dropping another one in the Galant I have too ![]() I forsee this being a very popular path for future 3G owners even if your just going the N/A route. It's best that if you guys want to start doing this, get to the junk yards now because there are 6G74s that these junkyard guys want to get rid of for super cheap. Even if you just do the direct swap it's still waaaaaay more cost effective than even buying an CAI
Lance Corporal
No shit man. As the old addage goes, "There is no replacement for cubic inches, except more cubic inches." (I know this isnt strickly true)
#17 (permalink) | |
Ah yes...
Russ, this is where it is confusing I know you spoken with Dave. Which bracket do you use. The VRX A/T one in the a 3G Manual? |
#18 (permalink) | |
Kampfbereit
#19 (permalink) |
Kampfbereit
I know this is kind of geeky to say, but I was absolutely floored when I took the oil pan off of my 74 that it was a 4 bolt main like the 6G72TT engines were.
From what I understand these might be the same engines they use in the 6G74TT ![]() This is our 6G72 2 bolt main
#20 (permalink) |
Kampfbereit
Here is some good information where about 75% documented here sort of gives you an idea of the differences. I can take more pictures of the parts if you guys want tonight.
http://wrenchmonkey.com/Webpages/6G74swap.html
#21 (permalink) | |
Ah yes...
Anywho better start looking for a VRX motor, anyone know of a place that makes pistons etc... for these beside RPW? |
#22 (permalink) | |
Kampfbereit
#23 (permalink) | |
Ah yes...
Probably there would be very little need to replace anything beside pistons on those motors for 500whp. And they would just need machining, balance the rods and the crank with knife edging. And cryo treat them. I think that would be sufficent for those motors. However, I noticed they dont have oil squirters for hte pistons.
#24 (permalink) |
Lance Corporal
~3.8L + 25psi would make me
and
#26 (permalink) |
Lance Corporal
Hell yea! 600+whp
#27 (permalink) | |
Kampfbereit
72 on the left, 74 on the right.
#30 (permalink) | |
Lance Corporal
#31 (permalink) | |
Kampfbereit
#32 (permalink) | |
Eclipse GT 3.5 6G74
OK I have 6G74 mounted in my car your not
#33 (permalink) | |
Faster piggy,FASTER!
Vehicle: '03 Galant ES V6 Turbo
#34 (permalink) | |
Kampfbereit
#35 (permalink) | |
Lance Corporal
#36 (permalink) | |
Kampfbereit
![]() I was keeping it on the D/L, but I figure I would at least offer my expertise on the subject of doing these swaps. IMHO I think every V6 owner can afford to throw in a junkyard 6G74 into their engine bay. The manifolds even bolt up to the stock downpipe. The V6 turbo kit even bolts right up to the 6G74 cali spec manifolds.
#38 (permalink) |
Lance Corporal
Where is the oil filter located on a stock Diamonte? Like you say, it wouldnt be in the way of the belts. Im on the hunt for a 6G74 block now.
#39 (permalink) | |
Kampfbereit
#40 (permalink) |
Lance Corporal
That makes sense. Like you said this is a pretty easy swap that will result in nice gains. And with the ECU reflash it will run right without too much of a hassle. We can just relfash our ECUs with the Diamonte ROMs.
#41 (permalink) | |
Kampfbereit
It actually felt exactly like how my car feels when it first spools up but it's just missing something after about 4K RPMs but still quite the kick in the pants.
#43 (permalink) | |
Kampfbereit
Horsepower 210 @ 5,000 Torque 231 @ 4,000 According to the results of my butt dyno, the results were quite favorable. Just think how much horsepower headers or an intake gives you. If you can pull an engine for $300~$600 and plop it in your car, you would be crazy not do do this depending on the condition of the engine when you get it. http://www.car-parts.com
#45 (permalink) | |
Kampfbereit
The exhaust is in the back of the car, so I don't think that will be an issue, and the CAI would fit as well.
#47 (permalink) | |
Kampfbereit
#48 (permalink) |
Zed oh six
Vehicle: 2002 Corvette Z06
Juan, Tearstones car does not have a 3.5 in it. It is another car that he is talking about. He has seen and ridden in the car personally.
You aren't the only one to do this. |
#51 (permalink) | |
Lance Corporal
#53 (permalink) |
Kampfbereit
I'm not going to give in Juan's blatent lack of maturity. For anyone else that needs assistance with this upgrade you know how to get a hold of me. rsanderlin@tearstone.com
#54 (permalink) | |
Eclipse GT 3.5 6G74
At this time I do not have the WHP because I have a stage 1 in my car and I changed for stage 2, the last week I received the graybox and the software to set it with the new stage. As soon as I have the WHP I will let you know. I want to test it soon. |
#57 (permalink) | |
Eclipse GT 3.5 6G74
I do not find that the Eclipse have 35% more HP with only change the short block for a 6G74, living all the other stock parts of the eclipse |
#59 (permalink) | |
Kampfbereit
