OFFICIAL 6G72 2000 to 2001+ ECU SWAP thread - Page 2 - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 01/17/2007, 05:42 PM   #61 (permalink)
PharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by all
You really need to find out what is going on w/ the car for me to be able to help you more. I need to know the following:
When the key goes in and you try to start the car, is there a green light on the dash w/ a key that comes on? If so, your combination of ECU, Immobilizer + key is incorrect. Does the car turn over but there is a no spark condition and no light? If so, the ECU isn't sending the spark signal because a criteria isn't being met to allow it to issue the spark signal which might be those pins I mentioned above.
Tell me exactly what the symptoms are which you will only be able to find out from the tech and I can help you get it working.
PharmEcis is offline   Reply With Quote
Old 01/18/2007, 08:10 AM   #62 (permalink)
1st 4cyl DOHC 3G
DNS-EN's Avatar
Vehicle: SPYDER GS TURBO
DNS-EN : who are you?
When swapping ecu's if your hex in the ecu doesn't match the key or immobilizer you will not get the green key light and it will not start. If the key doesn't match the immobilizer you will get the green key light.
2003 eclipse gs spyder @ 15psi
evo 8 Turbo 9.8 hotside
FMIC
fic 550 Injectors
3" downpipe
Rear disc conversion
Evo carbon fiber hood
Innovate LM1 Wideband
ECUFLASH Progrmmed
E-01 Boost controller/Programmer
Manual Trans Swap
prothane motor mount kit
Tein S Tech Springs
Kyb AGX struts
DNS-EN is offline   Reply With Quote
Old 01/18/2007, 08:32 AM   #63 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
MarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by many
The Mitsu Tech said the syncing went fine but the car wouldn't start. I assume that meant that there was no green key icon but apparently the tech doesn't want to speak directly to me (only relays messages through the service rep - who is getting tired of my questions). They didn't say and don't seem to remember if the engine turned over or not. Thanks for your advice and suggestions guys. I will try this again using a different ECU once I can find one.... I will post up any/all new info as I get it. Keep those tips and suggestions coming! I'm hoping to take the car back to the shop no later than next week but I'll try this w/e. I want tem to cut a new 02 key and try that to just to rule out the 02 ECU being bad.
FI Build: http://www.club3g.com/forum/gt-gts/1...ll-thread.html
In Progress: WAIC, Meth Inj, SDS tensioner, ECUFlash
Completed Perf Mods: Vortech V-5, 6G74 Mani/TB, Ripp Headers, Invidia CB w/ HP II Res, Fidanza F/W, Spec S3, Quaife LSD, ZT2/WB/EGT/Boost, Flashable ECU, A1000-6 FPR, VR4 Rails, Venom 310cc Injectors, Walbro GSS342
Future: Pistons, SDS Pullies
MarkSpyder is offline   Reply With Quote
Old 01/18/2007, 08:59 AM   #64 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
I have been trying to determine at what point they started using the new flashable ECU ROMs. I did a VIN search (http://www.analogx.com/contents/vinview.htm) and here is the info I got:
Description Position Raw Data Decoded Data
Region: 1 4 North America
Country: 1-2 4A U.S.A.
Manufacturer: 2-3 A3 Mitsubishi
Model Specific: 4-8 AE55H Unknown
Check Digit: 9 1 Valid
Year: 10 1 2001
Assembly Plant: 11 E E
Serial Number: 12-17 004058 4058
Does that mean that my ECU is from October of 2001?? If so I'm guessing that means there are very few flashable 01 ECUs out there... I'm trying to ensure that the next ECU I get (preferrably an 01) is flashable. I have called some salvage yards to get the build date of the cars that their ECUs came out of but they all said they will have to call me back with that info. I'm guessing that if my ECU is REALLY from 10/01 then it should be flashable. Has anyone been able to flash to an ECU from 10/01 or earlier?? If they/you have then my problem may be with the Tactrix cable and not my ECU.....
Old 01/23/2007, 08:51 AM   #65 (permalink)
Dr. 9023G
Guest
Posts: n/a
We need pin out diagrams of the 2000 ECU and the 2002 ECU. This maybe a problem. If it is, it can be corrected by just moving some wires to their correct pin on the 2002 ECU.
Old 01/23/2007, 09:15 AM   #66 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
I have ordered another 02 GT MT conv ECU this morning and will be trying the swap again by next w/e. If that one doesn't work then we will KNOW a swap from an "old" 01 to an 02 requires additional work other than just a resync.
Old 01/23/2007, 09:28 AM   #67 (permalink)
All the diagrams are listed further up in this thread and hosted on my server. The documents are in MDI format so you will need Office 2003 installed to view them.
Old 01/23/2007, 09:31 AM   #68 (permalink)
Dr. 9023G
Guest
Posts: n/a
We need pin outs. I will search today to check for differences. Mark, what's your vin#? I want to check the production date of your car.
Dave
Old 01/23/2007, 09:32 AM   #69 (permalink)
Dr. 9023G
Guest
Posts: n/a
I have Office. I wil look at them. You say you have all years?
Dave
Old 01/23/2007, 09:58 AM   #70 (permalink)
http://club3g.com/forum/showpost.php...4&postcount=33
Old 01/23/2007, 10:00 AM   #71 (permalink)
I have alldata on my box so I can pull up ANYTHING you want for the most part.
Old 01/23/2007, 01:05 PM   #72 (permalink)
TheFranchise's Avatar
Donkey Kong Champion! Midi Golf Champion!
Vehicle: 2000 Mitsubishi Eclipse
TheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by allTheFranchise seems to be well-liked by all
what exactly on the car wouldnt start? i'd hate to say that this swap is a dud b/c some tech jacked up the ecu install and forgot to ground it or goofed up the immobilizer flash
TheFranchise
2000 Mitsubishi Eclipse GT
2007 Nissan 350Z Grand Touring
1991 Nissan Sentra SE-R
3G Boosted Since Jan 2003, Beating on the 3G since 2000.
TheFranchise is offline   Reply With Quote
Old 01/23/2007, 01:09 PM   #73 (permalink)
Dr. 9023G
Guest
Posts: n/a
Greg I am looking at print outs for the injector pins. I havent gotten past the first line and there are differences in the numbers. Take a look for yourself and see if this can be corrected with a rewire of the harness.
Dave
Old 01/23/2007, 01:15 PM   #74 (permalink)
Dave
wtf? please explain
TheFranchise
Old 01/23/2007, 01:17 PM   #75 (permalink)
He's probably misreading the connectors. The numbers list the connector number and the associated pin. They are obviously different connectors for auto to 5spd.
Shade tree mechanics FTW!
Old 01/23/2007, 01:19 PM   #76 (permalink)
TheFranchise
Old 01/23/2007, 01:20 PM   #77 (permalink)
What you have to pay attention to is the first number. You'll see something like 1 - 41 or 1 -47. The 41 or 47 is simply the connector harness and they are just numbered differently. If you want, put a C in front of the 41 so you get C41 which is the connector.
If you look at the layout of both ECUs you will see that all the pin numbers and their corresponding locations are identical but Mitsu decided to change the connector number for whatever reason.
*edit* also when you look at the ECU connector diagram you will notice that for whatever reason ALLDATA has the diagrams reversed. The pinouts are still the same though you are just looking at one from the connector side and the other from the harness side.
Old 01/23/2007, 01:45 PM   #78 (permalink)
Dr. 9023G
Guest
Posts: n/a
On the 2000 M/T it uses say 1-41 but on the 2002 M/T it uses 1-47. This is just injector 1. If you compare the 2000 A/T to the 2002 A/T they are identical (1-41). Also their is a neutral/park postion switch on the 2000 that I can not find on the 2002, and a fuel temp sensor on the 2002 I can't find on the 2000. So here is my question, why does the 2000 ecu use 41 and 2002 uses 41 and 47?
Old 01/23/2007, 01:47 PM   #79 (permalink)
Dr. 9023G
Guest
Posts: n/a
Originally Posted by TheFranchise View Post
That is why your ECU swap is working right! I am just trying to trouble shoot Mark problem. We already know all you boosted 3G guys are god.
Old 01/23/2007, 02:01 PM   #80 (permalink)
Dr. 9023G
Guest
Posts: n/a
And this is incorrect. The car will start with out the immoblizer in sync, it will run for a second then shut off.
Old 01/23/2007, 02:46 PM   #81 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Dave
Sorry for the delay... They actually have me working and earning my $ today
VIN#: 4A3AE55H11E004058
(2001/GT/5SPD/convertible/with old-skool non-flashable ECU ROM)
I spoke with Dave on the phone. I think he is on to something with the Pin41/Pin47 stuff. Sounded like the injector + power wires are different on the 01s and 02s. Once some more info is posted about which wires need to be swapped I will do it and try the flash again. I do plan to purchase and try an 02 key this time though, just in case.
Old 01/23/2007, 02:54 PM   #82 (permalink)
Dr. 9023G
Guest
Posts: n/a
Sorry I should have elaborated more in my post.
Old 01/23/2007, 05:38 PM   #83 (permalink)
its a typo; no where does it ever reference what pin 41 is for the 00 ecu with that all data handout.
btw the pic was all in good fun; chill out. and my ecu swap will work fine (whenever i get the time to actually do it)
TheFranchise
Old 01/23/2007, 05:40 PM   #84 (permalink)
pin 41 doesnt exist for M/T cars; not according to ANY of the Factory service manuals I have or the AllData i have seen.
TheFranchise
Old 01/23/2007, 06:05 PM   #85 (permalink)
Dr. 9023G
Guest
Posts: n/a
That is what greg says he has, so his charts are wrong. Alldata PDF's, I see in the files pin 41 but couldn't find it on the charts. What about the other pins that couldn't be accounted for (neutral/park postion switch and fuel temp sensor )? Would these pins even matter?
Old 01/23/2007, 06:13 PM   #86 (permalink)
they only chart that seems to be wrong is the pin41 reference on the 00 M/T. everything else seems right on. fuel temp sensor doesnt show up until 2003+ ecu and models as discussed at the beginning of the thread. i am not aware of any input signal from the neutral/park position switch but havent really looked hard since I have a M/T
TheFranchise
Old 01/23/2007, 08:37 PM   #87 (permalink)
I think I figured out what they are for. I'm pretty sure they might be a ground. If you look, some of it references a body ground. It would make sense then that the first number is a voltage wire and the second is probably the grounding wire for that setup.
Old 01/24/2007, 08:24 AM   #88 (permalink)
Dr. 9023G
Guest
Posts: n/a
So what does that mean in reference to the non start problem?
EDIT- Would those have to moved in order to get the correct wiring set-up.
Old 01/25/2007, 06:11 PM   #89 (permalink)
dudei'm pretty sure those are the 2 wires you'd probe with a ohmeter to read the approriate resistance value, hence the chart being called the ECU RESISTANCE PINOUT. If pin 41 and pin 47 are both +12V with the IGN ON then this is a non issue for the swap. I dont have ready access to test mine yet maybe you have a 00 to test it?
TheFranchise
Old 01/26/2007, 07:18 AM   #90 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
I will try and test mine this afternoon (Saturday @ the latest). Should I just check for voltages or do you know the resistance values too? Just tell me what to look for and I will put that DVM to work. I currently have one 01 ECU and two 02 ECUs to "play" with.
Old 01/26/2007, 07:29 AM   #91 (permalink)
well you just need to probe your ecu harness pin 41 and pin 47 since that is the source of 12V from the battery.
TheFranchise
Old 01/26/2007, 08:42 AM   #92 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Probe for just voltage?
Old 01/26/2007, 08:49 AM   #93 (permalink)
Dr. 9023G
Guest
Posts: n/a
Probe for both because that is also a resistance chart.
Old 01/26/2007, 08:56 AM   #94 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
I guess I'll do negative probe to ground and positive probe to the harness pins when reading for ohms?
- ecu unplugged?
- car "on" but engine off, correct?
Thanks guys...sorry for the noobish questions. Just want to make sure I get all the proper readings so I can do this once and report back any needed info.
Old 01/26/2007, 11:27 AM   #95 (permalink)
- ecu unplugged?
probe 41/47 and body ground
see if both read 12V with IGN on
TheFranchise
Old 01/27/2007, 10:18 AM   #96 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Ran into a prob. I cant seem to find out which pin is which. Anyone know where to look for this info or know which plugs/positions are Pin 41 & 47? I checked the Engine Electrical chart and the 00E_Electrical PDF but I'm not seeing it. I have the ECU unplugged and the DVM ready. Just ned to know which pins on which plugs to test. Thx. (I previously got that info from my SAFC2 documentation but I have sold that recently)
Old 01/27/2007, 10:23 AM   #97 (permalink)
Dr. 9023G
Guest
Posts: n/a
here are the PDF's
http://www.club3g.com/forum/showpost...4&postcount=33
I think one of the Ecu pinout diagrams is reversed but if you study it, it will make sense.
Dave
Old 01/27/2007, 10:27 AM   #98 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
These are MDI files, not PDFs. WTF opens an MDI?? I have MS Office but it doesn't look like any of thos progs will open it...
:edit: Here it is. Thank God for SAFC2's Online Install Manuals.
Old 01/27/2007, 10:41 AM   #99 (permalink)
Dr. 9023G
Guest
Posts: n/a
MS word will open them. Sorry i said PDF. I am just use to reading them in that format.
Dave
Old 01/27/2007, 11:17 AM   #100 (permalink)
mitsubshiclip's Avatar
Vehicle: 3G
mitsubshiclip sucksmitsubshiclip sucks
probably gonna get shit for asking this but what is wrong with the 2000 gt ecu's
mitsubshiclip is offline   Reply With Quote
Old 01/27/2007, 11:23 AM   #101 (permalink)
Dr. 9023G
Guest
Posts: n/a
It cannot be flashed.
Dave
Old 01/27/2007, 11:34 AM   #102 (permalink)
Vehicle: 3G
flashed? yea i dont know much
Old 01/27/2007, 12:55 PM   #103 (permalink)
Dr. 9023G
Guest
Posts: n/a
I have a 2001 ECU here with me. It has a different part# then your ECU. I was at Mitsu w/ my buddy Dave (lol same name). We were going through all the data at their Mitsu web data station. I sent you a PM be sure to answer it.
Dave
Old 01/27/2007, 02:18 PM   #104 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
My 01 GT ECU has 0V between Pins 41 and 47 and body ground while the ignition is turned to on. I'll check PM now. Damn power went out for a few hours today
Old 01/27/2007, 04:32 PM   #105 (permalink)
Dr. 9023G
Guest
Posts: n/a
Give me all the numbers for the immoblizer new and old.
Dave
Old 01/27/2007, 04:39 PM   #106 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Here are all the part #s I have:
01 ECU: MD367858
Processor ID: MH7203FA A02 9M3
01 Immob: MR482501
02 ECU: MR578380
Processor ID: MH8206F A01 AF07491
02 Immob: MN141577
02 ECU: MR578380
Old 01/27/2007, 04:55 PM   #107 (permalink)
Dr. 9023G
Guest
Posts: n/a
01 Immob: MR482501
MR482501 $149.28 $0.00 $112.71
Electrical - Body electrical - Anti-theft components - Control module
Control module, eclipse, all 2000
02 Immob: MN141577
This one gets tricky under that part number there are two different immoblizers.
MN141577 $114.55 $0.00 $86.49
Control module, eclipse, all, to 4/1/04 2002 - 2004
Add to Cart Contact Us
Control module, eclipse, all, from 4/1/04 2004 - 2005
Old 01/27/2007, 04:59 PM   #108 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Dave, any idea if your 01 ECU is flashable?
Old 01/27/2007, 05:01 PM   #109 (permalink)
Dr. 9023G
Guest
Posts: n/a
I have no way to test it. I am looking up the immoblizer for the 01 right now. I am getting it up but need to find the part# to verify.
Old 01/27/2007, 05:15 PM   #110 (permalink)
If you send me an ECU I can test it for flashability. I have a complete wiring harness laying around I can use for a bench.
Old 01/29/2007, 12:45 PM   #111 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
PharmE (or anyone with Office03) - Any chance you could resave those files as "tiff" images? Only those wth Office2003 can view MDI files. I just spent 2+ days downloading a trial of Office2007 just so I could read these images and low and behold you MUST have the 2003 version in order to view them!
http://filext.com/detaillist.php?extdetail=MDI
"Extension: MDI
A high resolution, tag-based graphics format. .MDI files are only supported by the Microsoft Office 2003 version (NOT supported in Office 2007 I'm told) of Microsoft Office Document Imaging. If you are going to share files with people who are using Office Document Imaging 2002, or another document imaging program, save your files in TIFF format for compatibility."
Old 01/30/2007, 09:02 AM   #112 (permalink)
Dr. 9023G
Guest
Posts: n/a
Where do I send it Greg?
Old 01/30/2007, 09:02 AM   #113 (permalink)
Dr. 9023G
Guest
Posts: n/a
"Extension: MDI
Walk me through it and I will try.
Old 01/30/2007, 12:46 PM   #114 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
Just open the file as you would normally. Then click "File" @ top left, then "Save As". Change the file type (not file name) from ".MDI" to ".tiff" (or anything other than MDI). It should be that simple. That would be the process for most Microsux apps but I don't have that Microsoft Desktop Imaging app on any of my PCs so I can't confirm this. Just holler if any questions. And many thanks for helpin me out. Just spent $400 on Office07 and I already know that won't read it... LOL, wtf MS!!!
Old 01/30/2007, 12:59 PM   #115 (permalink)
Dr. 9023G
Guest
Posts: n/a
I saved them and emailing them your way. It will 2000-2004
Old 01/31/2007, 03:07 PM   #116 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
To those who are unable to view the pinout files (.MDI) - I found a free app that lets you view them.
MDI Viewer 1.0.1 available here: http://www.download.com/MDI-Viewer/3...ml?tag=tab_scr
I have tested it and it works. No probs reading the files now.
Old 01/31/2007, 05:33 PM   #117 (permalink)
Vehicle: 2000 GT
poormansclips : who are you?
Hey spyder, have you tried to get it working or anything again. I am watching this closely because I have to do the same thing.
poormansclips is offline   Reply With Quote
Old 01/31/2007, 05:49 PM   #118 (permalink)
Your Reality Check
ICEMAN99TURBO's Avatar
Vehicle: Y2K GT-P
ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Looks like fun.. I think I will need to take a class.
ICEMAN99TURBO is offline   Reply With Quote
Old 01/31/2007, 06:02 PM   #119 (permalink)
Dr. 9023G
Guest
Posts: n/a
No you won't just buy the stuff and My mitsu Man says he will get it to work.
Dave
Old 01/31/2007, 06:06 PM   #120 (permalink)
Your Reality Check
Vehicle: Y2K GT-P
That is the prob, I would love to do this, but am scared shitless, to try it. I read these threads and I am so fucking lost, I don't know my ass from my elbow.
