#121 (permalink) |
BoomGoesTheDynaMitt
Ah, the hose that goes to the nipple on the GT mani where the Dia mani has no nipple.... That is plugged into the intake "pipe". Use a plastic 5/16" (i think) "Y" so you can link that hose to the intake. Thats what I did. I will be removing that and installing the niple if Dr9023G can fine the proper one. Was planning to drill and tap mine anyways.
FI Build: http://www.club3g.com/forum/gt-gts/1...ll-thread.html In Progress: WAIC, Meth Inj, SDS tensioner, ECUFlash Completed Perf Mods: Vortech V-5, 6G74 Mani/TB, Ripp Headers, Invidia CB w/ HP II Res, Fidanza F/W, Spec S3, Quaife LSD, ZT2/WB/EGT/Boost, Flashable ECU, A1000-6 FPR, VR4 Rails, Venom 310cc Injectors, Walbro GSS342 Future: Pistons, SDS Pullies |
#123 (permalink) | ||
#125 (permalink) |
BoomGoesTheDynaMitt
Ripp 06s or 05s I think.
#126 (permalink) |
BoomGoesTheDynaMitt
Mine is the same. Seems to come and go... I moved my TB cable last night and mounted it directly to the manifold after reoving the stock manifold bracket. Seems to have helped but it did not completely remove the surge. I'll rip the mani off this w/e and recheck all my vac lines, etc.
#127 (permalink) | ||
Vehicle: '00 Passat 1.8T
#131 (permalink) |
BoomGoesTheDynaMitt
look at the TB. the screw is at the front on the left. you can not miss it. i've been told to use a flathead and not a philips screwdriver...
#132 (permalink) | |
#133 (permalink) |
Ok I have some input for this thread and some questions too.
I have client's car that I built a motor for and installed a Ripp SDS stage 2 setup in. The car has been converted with my own fuel and electronic setup. The car is also running RPW's long tube headers. The car is using the stock throttlebody with a Diamante manifold. I've been having a hell of a time with the P401 code. This is for EGR insufficient flow. EGR was properly hooked up as is all the vacuum lines. I've tested the EGR valve and it works flawlessly. The solenoid also works fine. I've tested the vacuum check valve for EGR and it also works good. I've swapped solenoids, check valve and EGR valve just to eliminate those as a possibility. I went through the complete diagnostics for the EGR system and I found the following: From the EGR port I get great vacuum just like I'm supposed to. That would be the first nipple on the throttlebody, closest to the front of the engine. The rear nipple on the throttle body should read zero vacuum at idle but it does not. It reads a good 4 in/hg of vacuum. The reason I know it should read zero is because I went and tested with my vacuum pump / gauge on another stock 3G. What I've been able to determine is that the throttlebody opening on the Diamante manifold is just too large for the 60mm throttlebody. The throttlebody opening on the Diamante manifold measures 68mm. Because it is so large, the throttlebody is not sealing properly against the manifold. One of those ports is supposed to read manifold vacuum and the other prethrottlebody vacuum. Bottom line, this is causing the EGR system to not behave properly. Instead of there being no vacuum on the EGR valve line and then vacuum to open it, the valve is constantly getting 4 to 5 in/hg of vacuum and when the solenoid is switching on to activate the EGR valve, it actually gets NO vacuum! Is anyone else experiencing this code? I managed to get this in both naturally aspirated mode (blower disconnected from the intake piping) and w/ the blower hooked up. And yes, I did put a new gasket in place to no avail. |
#134 (permalink) | |
Guest
Posts: n/a
Dave |
#135 (permalink) |
BoomGoesTheDynaMitt
I've gotten a P0455 a couple times fter this swap but no P0401. Very interested in what you all find out as I am still experiencing intermident idle surge. I wonder if that may be related...
#136 (permalink) | |
I was trying to consider what is different? The valve is turned 90 degrees, do the holes line up? Is there a restriction there? Are the passages from the tube to the valve location the same? Ive cleared my code a few times but it keeps coming back. I havent taken the time to try to sit down and fix it. If you are stumped then I feel I'm SOL. |
#140 (permalink) |
I think Dave is referring to having the EGR pipe bolted up properly and not leaking.
Pictures speak louder than words so I'll show you guys the problem of the Diamante manifold w/ the stock throttlebody. Here you see the stock Diamante gasket on the Diamante manifold. Note that the gasket is basically the exact diameter of the throttlebody opening in the manifold. Here you can see the Diamante gasket laid over the GT throttlebody. Notice the holes in the throttlebody at the top. Those are normally sealed by the stock gasket on the GT. The problem lies in the fact that EGR valve to work uses the port on the left which has a channel to a port below and to the left of it which runs through the throttlebody to the intake piping side of the throttlebody. This is so that there is no vacuum on this port during idle and when the throttleplate gets cracked it will see a tiny amount of vacuum that allows the EGR valve to be operated. Now, it is possible that the stock gasket might sorta seal for a while and allow you to run check engine free for a bit, but I doubt it will last. If you ever replace the gasket, the leak will be there and allow the A port to get vacuum when it shouldn't. I'm not off in my diagnosis of this. From what I've seen, anyone who swaps to a Diamante manifold and retains the use of the stock throttlebody should eventually pop a 401 code because the valve will not have vacuum to operate. Basically this feeds the EGR solenoid w/ a trace amount of vacuum which the ECU can then engage by turning the solenoid on. This then allows the check valve (the round thing) to supply full vacuum to the EGR valve. That is why the vacuum port closest to the front of the car labeled E is hooked up to the check valve and is always supplying manifold pressure. Due to this, the GTS seems to be a superior manifold for the stock throttlebody. I even tried hooking a brat up simply to the MDP sensor to try and fool the ECU. No dice. BTW Dave, yes the MDP is fine as I can read it's fluctuations in EVOScan under boost. Could this cause idle fluctuations? Absolutely. It is for all intents and purposes an internal vacuum leak. The throttlebody is not sealed and is allowing air to pass from one side of the tb to the other. While it's metered air, it's still not supposed to be entering the engine. Last edited by PharmEcis; 03/23/2007 at 05:51 PM. |
#141 (permalink) |
Oh I almost forgot, I tried to cheat and install a small vacuum source in front of the throttlebody. While it did allow me to see absolutely no vacuum at idle, I also wouldn't see any vacuum while revving the motor which opens the throttle plate. It is possible I didn't tap close enough to the throttlebody. Basically you need a new port for the E line on the throttlebody. The Diamante manifold makes it useless.
#143 (permalink) |
BoomGoesTheDynaMitt
eh?
I'm feelin like a guinea pig... got a link? I'm so tired of this fluctuation although it does dissappear for awhile. Its intermident.
#145 (permalink) |
BoomGoesTheDynaMitt
You think that is vacuum leak related? I guess if the intake isnt sitting correctly then the rubber elbow doesn't seal properly? I ask because my WAI hits my battery and doesn't look like it is sealed 100%. The idle ONLY happens after the car is warm. The warmer the more frequent the surge I'm finding.
#146 (permalink) | |
#147 (permalink) | |
Guest
Posts: n/a
Dave |
#148 (permalink) | |
BoomGoesTheDynaMitt
Dave, Thanks for looking into those vacuum "holes" and their relation to the gasket. If I still have the idle surge after starting up today i will probably try sealing them with the Mitsu white goop next w/e. But, does anyone know if the RPW or Diamonte TB will solve any possible issues with these vacuum holes? I'm thinking it may be easier for me to just swap out the GT TB for a superior one and eliminate that gasket/vacuum hole alignment issue at the same time.
#150 (permalink) |
BoomGoesTheDynaMitt
FYI, after tapping the manifold for a 2nd nipple my idle surge is still present. Now I'm lost as to what could be causing this.... Looking forward to seeing the "How To" Dave!
BTW, can the Mitsu white goop be removed fairly easily or would you need to drill it out? Just want to make sure I can back out of plugging the holes if it doesn't help my idle surge issue.
#151 (permalink) | |
I actually got this car to pass the EGR test but I cheated, I used a BRAT. Sealing the gasket against the throttlebody was an idea I had too but I don't like using any kind of sealer in the intake tract. The sealant might work for an NA guy but I have a feeling that boost would push the gasket off the tb a bit and not allow it to seal properly. |
#152 (permalink) |
Guest
Posts: n/a
I talked to the guys at Mitsu and they said the white diamond care won't come off if it properly cured. The gasket will have to be pressed against the stock manifold flange for a few days to allow it to properly dry. The said heat would not be a factor because they use this to seal the thermostat housing to the intake mani on the 4 cyl., they also use it on the oil pans, and other hot spots.
...and getting a proflow or Rpw TB will not fix this because they use the stock throttle body as the core. The only thing they do is bore it out and put in the proper size butterfly. |
#154 (permalink) | |
Guest
Posts: n/a
Dave |
#155 (permalink) |
BoomGoesTheDynaMitt
Strestout1: Which TB are you using? Just seem odd to me that some Diamonte manifold swappers have the idle surge and others do not...
#156 (permalink) |
BoomGoesTheDynaMitt
Using the Diamonte TB "may" cause you to loose the cruise control, due to fitment issues, correct? Either way, I think I'm gonna try it. With my silencer removed (from here on out) my idle surge can be embarassing at times. It sounds like I'm pumping the gas ( a little) when sitting @ a red light.
#159 (permalink) |
BoomGoesTheDynaMitt
#163 (permalink) |
its been a while since i read through this thread.. but i too, am have the idle surge problem..
i tried swapping the diamante tb.. but i got different idle issue.. there was no fitment issue.. besides bending the valve nipple to seat underneath the strut bar..the issue i had was different internals for the TPS & IAC. the eclipse IAC tip didnt extend as far as the diamante IAC does causing diffenent linement .. and the eclipse IAC motor had different internals (design).. i will try and take some pics next time i disassemble the tb.. |
#166 (permalink) |
BoomGoesTheDynaMitt
What is your different idle issue? I'll be swapping to the Diamonte manifold soon and would like to know what I should expect. Thx!
#172 (permalink) |
BoomGoesTheDynaMitt
Oh, I thought you had the TB installed. Of course you will have idle issues if those are left unhooked! I'm wondering if anyone who has swapped in the Diamonte TB (completely with sensors) is having idle surge.
#174 (permalink) | |
BoomGoesTheDynaMitt
Lemme know the total and ship when you can. I'll try the TB out as soon as it arrives and will post my results/findings immediately. I'll be sure to get plenty of photos during the install too.
#178 (permalink) |
BoomGoesTheDynaMitt
I can't imagine the coolant affecting the idle... I have ZERO heat or coolant issues and I still have the idle surge so I'm guessing its related to something else. Hopefully, if its possible, someone can elaborate on how it affects it. I'm eyeballing those TPS sensor differences though.... I think I recall that since my mani swap I have not seen a TPS of more than 17-20% on my datalogger... I'll have to check that again when the car is startable. (main power harness is ripped out now and I'm in the process of installing 0/1ga.)
#180 (permalink) |
Its funny to me why all you guys go through all this BS trying to get this manifold to work I used a GTS intake and it was basically bolt on and extend a few factory sensors. I bored the factory TB with no fitment or sensor issues. I have not stared my car yet but I can say that the GTS plenum is the best option for our cars. The manifold is basically the same size as this one as well as being able to use most of the factory GT brackets. OK so I get you will be able to get a little more air though this TB is it worth the headache? You can make those numbers up when you go FI. Just a thought.
Hytech Headers Bored TB GTS Intake upgrade w/Varitable runners ECU Flash Dyno results soon. |
