#121 (permalink) | |
Your Reality Check
#122 (permalink) |
Aple juic is my beer
Ok, yeah i do have a filter. But i think i may have foud my problem. I had the line that "t's" with the vacuum control valve and the EGR solenoid connected to the manifold instead of the EGR Valve, and the other connection for the EGR solenoid connected to the EGR Valve. Huge mistake in reading the diagram. I just found this out about an hour ago. Im sure that was my problem.
Instead of two lines sucking on the EGR vlave there was only one which would caused Insufficient flow. And i am praying that the Lean problem will go away because of this mistake as well. |
#123 (permalink) |
fat guy tiny car
so i'm about to install this beast and i can't figure it out. i've read this entire thread. looked at the pictures. my TB looks totally different. can somebody tell me what is up with this TB? mine seems to have 2 of these cruise control things on it, these 'bell' looking things. it also has 2 TP sensors. WTF??
![]() ![]() ![]() hopefully i only need 1 TPS because i broke the other when i removed it from the junkyard 'mante |
#125 (permalink) |
Vehicle: Boosted 6g75
^ I have one of those myself. On my 3.5 TB I was able to remove the cruise control bracket without any issues. Unfortunately the one pictured above disassembles differently and when removing this bracket actually removes the throttle cable arm with it. I'm damn near close to taking a grinder to the thing and making it work
EcuFlash Tuning or Mechanical (South Eastern States) Services, CONTACT US HERE. |
#126 (permalink) |
Just the tip
Vehicle: 02 stratus R/t
ok guys so I know I need to remove the cruse control on the throttle body, but it looks like if I take it off, one of the springs for the throttle will come off and maybe even the whole throttle assembly. My question is do I take of just the vacuum piece on top, or the whole bracket. I took some pics, advice would be appreciated.
#128 (permalink) | |
#129 (permalink) | |
Just the tip
Im unsure of the year exactly, but it is in between the 99 and 04 body style.
#130 (permalink) |
Tha Born Legend
Vehicle: 03 eclipse GTU
Hey quick question, I have the 97 diamante mani and tb on my clipse, anybody know where to buy tb shaft seals? Called Mitsubishi they didn't have them, called a lot of ppl . If you don't know what there are there these two small circular seals that blow on evos a lot
UNYQUEZ- tha unborn legend is now tha born legend. Tha best way to measure the greatness of your life, is to count the things in your life no one believes. |
#131 (permalink) |
Black on Black
Spawnamus, I don't know if you have traction control on your car but from what I've read the nipple on the top of the TB that has a "P" in line with it is for traction control. I believe you should plug that unless you're using traction control. Also, before you remove that bracket you should just try to see if it fits with it on, because on mine the bracket fit just fine. Good luck on the install.
#132 (permalink) | |
Just the tip
#133 (permalink) |
I thought the same thing, but it seems the length/angle of the bottom of the bracket is different.
#135 (permalink) |
Tha Born Legend
No one knows where to get throttle body shaft seals for the diamante throttle body? 97
#137 (permalink) |
Tha Born Legend
Same as evo? Well I have the 97 3.5 diamante tb, will the evo seals still work? And no lol stands for Unyquez aka unique lol
#138 (permalink) |
Tha Born Legend
#139 (permalink) |
Tha Born Legend
So trying to confirm that this is what your telling me.
Throttle body shaft seals in the 3.5 diamante tb and 3g eclipse tb are the same as the seals in the evo? All years?
#140 (permalink) |
Tha Born Legend
#141 (permalink) |
I've pulled apart my 74 throttle body. Just a few questions and findings.
![]() The TPS, is my concern. ![]() ![]() Clearly the 3g TPS won't work with this double peg rotator so I will have to wire it up. It looks like it has the same plug... but does it? And if it doesn't, how do the wires match up? I believe this was discussed earlier in this thread but the pics don't load anymore so I can't see what they're talking about to make any sense of it. For anyone building this tb who wants to do the coolant bypass, you can remove the nipples too for space. Its very difficult but you put the nipples in a vice and start turning until the pressed fit comes apart.
#143 (permalink) |
The throttle position sensor of the 3.5 tb has to be used. The connector from our 3.0 harness does plug right in though.
#145 (permalink) |
Just want to correct my info, the IAC I was referring to as fitting was actually from a 6g74 according to part numbers. Just got switched around in the wrong parts box so it's my bad.
#148 (permalink) | |
Pandora
Hey guys. So I have had the diamante intake plenum installed with no codes for over 6 months now and I got around to buying and installing the diamante throttle body. (since my IAC was failing it was a easy purchase) The install went fine but I would highly sujest that you have 100% working motor mounts (ie not broken or cracked) My motor sat too high and too far back that the map sensor actually cracked in half and dead shorted against my strut bar and the cruise control would rub the firewall. After my beautiful and pregnant fiance helped me install my Prothane motor mounts... The engine sits perfectly. There is a nice gap at the top and back of the engine and nothing rubs. Prothane motor mounts make the full diamante setup go in with almost no modifications except splicing. That is where i am stuck. I am a electrician so i am a little baffled that I am having issues with this. I spliced both connectors. I am not having a IAC issues but am having problems with the TPS signal.
And on a side note... when i put it in sport-tronic of course it bypasses the restrictions that the codes trigger when the tps fails....Man does it hall balls. Throttle responce is much more solid. God I love the way she purrs now. specially full throttle through 1st and 2nd going through tunnels. (cant even imagine what a full exaust setup will sound like later) Thnx for your time.
--Missing my profile. Deleted due to inactivity? Member since Apr 2005. -- |
#149 (permalink) |
Pandora
I think i have it all figured out. my eclipse wiring has pins 2 and 3 flipped compared to the diamante tps. so since i spliced the wires across color for color i actually had 2 and 3 flipped. I now have the wires swapped and the car seems to run perfect!
So if you just use the eclipse tps harness and DO NOT splice the wires... You will be set if you leave the original tps harness. If you cut the wires the two inner data wires may need to be flipped. I now do not have a check engine light p0104 low throttle position. There is a slight issue with my idle but I need to tune the idle screw, throttle cable, tps because they are all out of wack and not adjusted since i took everything fully apart and cleaned.
#151 (permalink) |
That last 3 times this swap was attempted people fucked it up because this thread is a giant ball of conflicting information so I will summarize is ALL right here so there is no more confusion.
6g74 throttle body swap cliff notes: Disconnect battery Must be a none traction control throttle body (TCL tb's have 2 giant bells on them) 6g72 or 6g74 throttle body bolts will work Must use a 6g74 throttle body gasket Must be on a 6g74 manifold (or a spacer to give it a proper sealing surface) Coolant lines are plug and play (if you want them..) 6g74 IAC must be used, 6g74 IAC pigtail MUST BE SOLDERED IN 6g74 TPS must be used but the factory connector plugs right in, NO NEED TO SOLDER Point of significance: Earlier 6g74 throttle bodies came with 2 vacuum ports on the top like your factory throttle body did. If yours have the orange IAC it'll have 2 vac ports and the vac lines are a direct transfer. Some later 6g74 throttle bodies (that came with a black IAC) have THREE vac ports on top. You must look at your 6g72 throttle body to find out where each vac port leads to (before or after the throttle body) and match them to the correct port that leads to the same place on the 6g74 throttle body. THIS MUST BE DONE CORRECTLY OR YOU WILL THROW CODES AND NOT IDLE RIGHT. Its very easy, just look and check your work. On the 3 port throttle body 2 go to manifold vacuum and one goes BEFORE the butterfly and thus is the cause for idling issues since these ports help control your EGR. Unless you need it (boost accessories perhaps?) you can plug the extra port. IAC wire up is straight forward; the PINOUT is identical, only the size of the plugs are different. So, take the orientation of the factory plug and place the 74 IAC plug in the same orientation. Transfer the wires one by one so they control the same pin. USE SOLDER AND SHRINK WRAP, this is an extremely active set of wires and no interference will be tolerable so do a good job and make it look nice. Once you reconnect the battery let it idle up to heat so it can figure itself out and just be aware that it'll be tweaking a little bit the first couple times you drive it. Beyond that, enjoy the throttle response and extra ponies across the entire rev range! Edit: Forgot to mention, if you want to use your cruise control you will have to "move" a small section of the firewall back via pounding tool to make room for it as it does not clear. There's room to do the moving, the only way you'll really notice it is if you seriously screw up sheet metal or don't patch up the paint. Last edited by Silvertune; 02/08/2012 at 08:45 AM. |
#154 (permalink) |
DARKSIDE
Vehicle: 2000 Eclipse GT 3.8
i just installed a 74 manifold from a 2002 Diamante, which has an extral vacume line in the back... had to be seald now the car turns off , unless you give it a little gas... but we will see tomorrow....also i have an extra manifold if anyone is interested
It's not how much you are spending on your car that matters, it's how much you have saved and gained doing the work yourself! |
#156 (permalink) |
Vehicle: 2000 eclipse gt
got my 74 intake and manifold on No problem didnt dent fire wall or cut any away hasnt hit yet. did turn egr tube into breather... one problem im geting code p0104 for tps sensor. car runs fine but idle rpms drop low then car dies im runing stock wires on the 74 tps think the tps is bad guys? pics a little shaky but its i was in a hurry ill get a better pic after work today
![]() Uploaded with ImageShack.us |
#158 (permalink) |
Alright ssorry looked like most people said they dented it for cc or to make it fit any idea on if my tps is bad u think I have a spare but its off a tb with traction control has a extra pin
#159 (permalink) | ||
As for the TPS check this out: Quote:
#160 (permalink) | |
#161 (permalink) |
now after fixing it i have no tps code but after 20 miles ses came on for p1400 and p0174. Car also has no top end power drives fine, shifts fine, at 45 I go WOT and the rmps go like i am but the speedomiter barrly moves. any ideas? the ruber of my intake was bent a little i fixed it now and still no power. any ideas? was fine before the swap..tomarrow ill check vaccumes and for leaks in the gaskets.
--==dustin560==-- |
#163 (permalink) |
I was doing research on the throttle body differences since mine has 3 nipples and some people only have 2.
From All-Data, The three nipple throttle body came from a 1997 Diamante ES 3.5L and from 98-up, It came with a 2 nipple. If you bought a diamante manifold + throttle body. If it has 3 nipples on the throttle body, you will notice that the manifold doesn't have 5/16 nipple next to the throttle body (usually for the EVAP purge solenoid).. then you got the manifold from a 1997. The 1997 Diamante used a different size EVAP purge solenoid with a smaller vacuum hose that connects to the throttle body (port P). If you have a manifold that only has two nipples on the throttle body, you got a later model 98+ throttle body and you have that 5/16 nipple of the manifold for the EVAP Purge Solenoid. Some people might have issues if they bought a manifold first, and bought a throttle body at a later date. So if you were planning to upgrade the intake manifold and throttle body. Buy the 98+ Diamante Manifold + Throttle Body. If you bought a 97 intake manifold and throttle body (like I did), You have a few options for the EVAP purge vacuum routing. 1. You will have to cap off the (port P) on the throttle body, drill into the manifold and add an additional vacuum port that will fit a 5/16 hose. 2. Cap off (Port P) on the throttle body Install a "T" the EVAP purge into another vacuum source. (It may work, it may not, depending on the vacuum source) 3. Don't cap the (Port P) vacuum port on the throttle body Run the 5/16 hose from the metal line on the firewall to the EVAP Purge solenoid, 5/16 hose out of the EVAP purge solenoid and install a vacuum hose reducer to a smaller hose and install that line in the Port P of the throttle body. Hope this information helps someone. |
