IGNITION FAILURE SENSOR BYPASS?
ANyone know what pins to jump to do away with the sensor? I seen somewhere before it was pin 3 and 4 on the harness side but just wanna make sure
2001 gs 2.4 5spd, balanced & knife edged crank, scat rods, wiesco pistons 9:1, port & polished sohc, 16g 10.5 hotside, ported o2, 3 inch dp dump under car, ecuflashed evo VIII rom (Courtesy FLASHBLUERS), 850cc wrx injectors, Walbro 255 pump, NGK bkr7es, EVO VIII maf, Greddy BOV, autometer EGT, A/F, Boost, stage 3 clutch, All ARP bolts and studs, Zeitronix wideband. |
Dover White Pearl RS
Be a little more specific on what exactly you're trying to do. Just saying it's on the harness side doesn't help much since there are quite a few harnesses with quite a few connectors...explain what you're trying to do and we might be able to better help you get there...
Current Mods Injen CAI CMF Header/Hi-Flow Cat Invidia N1 Cat-Back 13" LS1/Cobra Brakes KYB AGX/TEIN S-Techs ST Rear Sway Bar GT Front Strut Bar 18" Black Racing Pro N-1 Wheels Sonar Projectors w/4300K HID Sportronic Conversion AVIC D3/XM Radio/NavTraffic Black TYC Tails GT Side Skirts Ready To Install RMDSM Front Sway Bar Firm front; poly rear mounts 5pc Black Grillecraft |
Ahh...now I gotcha...old age was starting to kick in I guess.
Looking at that circuit, two other ways you can perform the same function, if you don't want to short/solder the two wires together, would be to either cut & cap the wire going into either pin 1, which would keep the sensor from biasing the internal transistor that grounds out pin 43 of the PCM, or you can cut & cap the wire going into pin 2, which all the sensor to function as normal (i.e. the transistor would bias as designed), but pin 43 of the PCM would not be connected to it. Either of those two options I listed would prevent the IFS from triggering the PCM, but allow you to easily reconnect the wire back in to return to the factory circuit, such as if you ever wanted to sell the car...
#5 (permalink) | |
OMFG
But for me, I knew I would never be putting the sensor back in (since its completely useless with teh EMS), so I chose to remove the sensor for good, and also remove the two signal wires from the harness |
#6 (permalink) | |
dragging up an old topic,
can this be done and still have the factory rev/rpm counter work?? i removed the IFS, and bridged pins 3 and 4, the car starts and runs fine, but the rev counter does not work at all. Last edited by Gly; 09/03/2008 at 06:24 AM. |
#10 (permalink) | |
Lift and Separate
http://webpages.charter.net/bosorio/...FS_Removal.jpg |
Vehicle: 2001 Eclipse GS
i know this is like waking up and old tread but i just wanted to know if this can be done in order to bypass the sensor as a temp solution?
apparently my I.F.S. is getting 12V but not supplying 12v to the coils so what do you have? a crappy running car So my question is get this be used as a temp solution until i get a new sensor? |
#13 (permalink) | |
I think mine is broken and causing missfires. Want to know if i can bypass it and se if it realy is broken. |
