Go Back   Club3G Forums > Performance & Tech Forums > 3G Eclipse RS/GS Specific
Old 07/31/2008, 02:45 PM   #1 (permalink)
steadly2004's Avatar
Vehicle: Stratus 2.4L
EVO ROM, download it here
After may complications from other mixups, I believe this ROM to be a good alternative for people looking to tune. It is a stock EVO ROM, 94170008 with the immobilizer deleted and some of the periphery settings changed. This will not throw codes, unlike some previously distributed ROMs. I hope everyone can benefit from this.
Tuning and changing anything in the car's computer will always carry inherent risk. I assume no liability with what you do to your car. Do not attempt this alone if you haven't the experience. This should only be used on off-road vehicles
This ROM has been pulled from the EVO ECU that I currently have installed in my car. I also started to get the injectors dialed in. Everything else will need to be edited/changed over from the origional eclipse ROM, or it can be tuned from scratch. I highly suggest that anybody using this ROM utilize a logging program (evoscan or mitsulogger) along with a wideband to adjust their timing and fuel maps. These are stock EVO maps and as such have fuel/timing for a 2.0L engine. This means the same map will most likely run lean on our engine and have too much timing wich could cause knock. A proper tune from a professional or qualified friend can assure you safety and longevity.
I suggest changing over or dialing in:
injector scaling
injector latency
MAF - size (and possibly scaling/smoothing)
(I'll add others when I think of them)
Also if you're already using an EVO ROM (other than 94170008) and just want me to adjust the periphery, I'll be glad to do this for you or teach you how to do it yourself. I have moved everything over to Tephra's ROM (94170015 ver 5.10), which is a completely different ballgame alltogether. I have added the download below.
I am in the process up uploading Tephra's ROM, along with the XML file to go with it. Please note that the tune on this is specific for my car. Also here is the link if you want to download the unmodified (stock-maps) version with his mods, get it here. TephraMOD V5.10 - evolutionm.net
The folder link is my ROM and XML. There is a tuned and untuned map. The tuned map is for observational purposs only. If you try and upload this and run 14psi, you most likely will go lean and blow up your car. I would suggest that you stick to downloading the one with the perhiphery changed and tuning it yourself. The tephra's source is unchanged from what you would download from evolutionm.net in his thread. You will still have to change the XML to go this route, which isn't very hard.
Update 11-25-09 Tephra's ROM
I uploaded Tephra's V7 ROM, It has the periphery changed and all. Also beware poeple are experiencing throttle hang, I have had throttle hang since I upgraded my intake/TB, not a big deal. I canged over the ROM after the install and have noticed no difference.
The major difference in Tephra's ROM is BIGMAP, which is increased resolution for the fuel/timing maps (freaking awesome) And gear dependent boost. They utilize a ratio of RPM/speed to determine which gear you're in and then you adjust the wastegate solenoid duty cycle to control boost. This is a feature only available in standalones until now. I want to eventually utilize this, but you have to wire in a boost solenoid, I"m too lazy for now.
Only use this ROM if you understand what you're doing. Don't enable no lift to shift unless you've wired in the second clutch switch. There are many more options available in this ROM that I won't utilize. Please ready up here for your education and the health of your vehicle. Swapping over to speed density is an option, but you'll have to add a JDM/EVO10 boost sensor and a temperature sensor (not you'll have to use a different version of Tephra's V7).
http://forums.evolutionm.net/ecuflas...hramod-v7.html <------READ UP BEFORE USING THIS ROM
If you have a tuned EVO ROM, you can swap over without re-tuning using the included BIGMAP translator. Its an excell spreadsheet. Works pretty well. BE SURE TO CHANGE THE AXIS, and paste the grey values into the extra squares on the axis. This is necessary otherwise it will be averaging values you don't want in there. I also suggest checking a few random squares to make sure its averaging correctly.
Added from my post below, just want to make sure everybody gets it
Originally Posted by steadly2004 View Post
OK, little update. The 9653---- whatever ROM has a few issues, throttle hang, rev limit not working and cold start stuff.
Tephra has incorporated most of the "new" features into the 94170715 variant, which worked BEST so far for my car. I haven't used the new Tephra version because my intake manifold is off.
Basically if you're running speed density, use the 9653--- one
If you're running a mass airflow sensor use the 9417--- one
TephraMod V7 - evolutionm.net
here is the original link, feel free to paypal any money to him that you can if you find his software useful, I do every time he comes out with something I utilize.
Old 07/31/2008, 03:12 PM   #2 (permalink)
Eclipse GS Boy
3geclipse^'s Avatar
Vehicle: Eclipse GS TURBO
3geclipse^ : who are you?3geclipse^ : who are you?
Send a message via MSN to 3geclipse^
steady is a great guy and had help many of us in the forum.....with this ROm no more fuel pressure and wastegate codes!!! i been driving my car for three days already and no more check engine light!!!! thanks steady!
Dominican=)
3geclipse^ is offline   Reply With Quote
Old 07/31/2008, 03:36 PM   #3 (permalink)
GT35 pimpin
XwP1ayawX's Avatar
Vehicle: 00 GS-T, 07 Yamaha R6
Hmmmmmmm, I'll give it a try. Stock MAF settings to start? The one I'm using from flash has some wacked out values, but they work
Old 07/31/2008, 04:19 PM   #4 (permalink)
Be sure to copy over your injector settings. The ones on the ROM are for my RC 550cc injectors. Its good for idle so far, but I haven't been able to test the settings out while cruising. (waiting on the clutch)
This will work with the normal definitions that come with ECUflash. I assume that Flash's ROM required you to use his definitions. The values were probably correct, just not visable/adjustable without his definition.
Old 07/31/2008, 05:19 PM   #5 (permalink)
GT35 pimpin
XwP1ayawX's Avatar
Gave it a shot, no codes but my idle was way rich on startup. I had the battery pulled so I let her run for a while and when I came back my afr's were pretty accurate. Haven't tried cruising yet either.
Old 07/31/2008, 06:44 PM   #6 (permalink)
If you have had a tune using Flash's rom, you can copy/paste the fuel and timing maps over pretty easy. Just highlight them all, then ctrl-C. Open the corrosponding map in the new ROM, highlight it all and ctrl-V.
Also what kind of injectors are you using? What scaling are you using?
Old 07/31/2008, 10:56 PM   #7 (permalink)
GT35 DOHC 500wHp
slava's Avatar
Vehicle: 3G turbo
slava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okay
You must spread some reputation around… blah..blah..
You are the man!! Very contributive member helping out 3G community!!!
slava is offline   Reply With Quote
Old 08/01/2008, 08:42 AM   #8 (permalink)
Thanks for the kind words!
Old 08/01/2008, 07:05 PM   #9 (permalink)
MattS00's Avatar
Originally Posted by fasteclipse3 View Post
dont try to use the nlts stuff unless you add the other clutch switch the eclipse is missing
What do you mean? How many switches are on the 4G64 and how many are on the evo?
MattS00 is offline   Reply With Quote
Old 08/01/2008, 08:23 PM   #10 (permalink)
You're correct, NLTS won't work.
However, knock CEL will, as well as Valet Mode, and Map switching if one so chooses.
BUT..... that really will be a discussion for another thread anyway. This ROM has none of those features and is stock with the acception of the periphery settings changed.
Old 08/01/2008, 09:08 PM   #11 (permalink)
Tango Sucka!
Tearstone's Avatar
Vehicle: 02 EclipseGT 91 MR2 Turbo
Stuck
Tearstone is offline   Reply With Quote
Old 08/01/2008, 11:31 PM   #12 (permalink)
MattS00's Avatar
Your question is flawed. It should read "How many switches are on the eclipse and how many are on the evo?"
Eclipse 1
Evo 2
The nlts is designed for 2 clutch switches and will thoroughly confuse you when trying to figure out wtf just happened in the log.
Sorry to confuse you. I was in a hurry and I wanted to specifically state the 4 cylinder eclipse. The reason I ask, is that GT eclipse has two clutch switches. One at the top of the clutch travel to cancel the cruise control when the clutch is pushed and one at the bottom so the car will start. Not that any of that matters as I cannot even flash my fed spec GT, let alone use a evo rom.
Old 08/02/2008, 02:14 AM   #13 (permalink)
Eclipse GS Boy
3geclipse^'s Avatar
i used the knock cell flashing and it works perfect!!!
Dominican=)
Old 08/02/2008, 09:08 AM   #14 (permalink)
benpgreen : who are you?
I have been using this for a few months now after I found it on evom with no problems cel flash works great and best of all no more codes.
benpgreen is offline   Reply With Quote
Old 08/02/2008, 09:49 AM   #15 (permalink)
I think there may be some confusion. This ROM doens't have the knock CEL feature or any others. It simply is a stock ROM with the periphery changed.
*note* The last sentence in the first post is stating that I'm planning on changing over to Tephra's ROM in the future.
Old 08/02/2008, 01:06 PM   #16 (permalink)
3GwithVOLKS's Avatar
3GwithVOLKS : who are you?3GwithVOLKS : who are you?3GwithVOLKS : who are you?3GwithVOLKS : who are you?
Ill try this out when I get my car put back together. I dont have a cat though so im sure i will still see an SES come on. I am using evo 9 560cc injectors so id assume to use their injector information and scale them to 513. The latencies you have on there looked pretty close to the ones I had before so ill see how those work and mess around with them if need be.
3GwithVOLKS is offline   Reply With Quote
Old 08/02/2008, 03:27 PM   #17 (permalink)
I think I added about 0.1V across the board, maby 0.2.
If you have EVO9 injectors, you can probably just pull up an EVO 9 ROM and copy/paste everything for the injector settings and be good to go.
Old 08/02/2008, 03:59 PM   #18 (permalink)
Vehicle: 2003 Eclipse RS
S1lverBu11et : who are you?
this is awesome, so we can just download this and use the maps and such for tunning?
S1lverBu11et is offline   Reply With Quote
Old 08/02/2008, 04:52 PM   #19 (permalink)
forgot to ask, is the maf scaling from a 3g or evo?
Old 08/02/2008, 05:18 PM   #20 (permalink)
Ithinkyou's Avatar
Vehicle: 02 GS
Ithinkyou seems to be okayIthinkyou seems to be okayIthinkyou seems to be okayIthinkyou seems to be okayIthinkyou seems to be okayIthinkyou seems to be okay
3g id bet. Has to be
2002 GS 5spd,
Wrx modded 440s
Greddy Type-S
Megan Racing Evo 8 Manifold
Evo 9 turbine
Invidia SS O2 Dump
Custom 3" DP
Catco 3" HFC
Greddy EVO2 modded 3"
Injen LICP
Zietronix ZT2
Prosport
boost
fuel press.
oil press.
oil temp.
EGT
G-Speed CF hood,
Tien S-techs,
ADR fuel bronze 17" wheels,
OLD - 2000 RS 5spd
Ithinkyou is online now   Reply With Quote
Old 08/03/2008, 10:37 AM   #21 (permalink)
Everything is still a stock EVO settings except for the injector and periphery settings. I never changed it for myself because I have an EVO translator and GM MAF, so I need to have it with the stock EVO settings.
Thats why I listed it at the top of things that need to be adjusted if you're going to run it on your car. You'll need to open up the EVO ROM and change the MAF size to 257.7 I think. That will help out the most, then the scaling and smoothing would probably be a good idea to change over also, although it may not be necessary. Logging and tuning it will be a must.
Old 08/12/2008, 08:39 PM   #22 (permalink)
CostaGS88
CostaGS88's Avatar
Vehicle: Mitsubishi eclipse GS
CostaGS88 : who are you?CostaGS88 : who are you?
Send a message via AIM to CostaGS88
I can not get your file to download from "savefile.com" the download will not begin when you click on it, and the download it now link will now either.
CostaGS88 is offline   Reply With Quote
Old 08/12/2008, 09:11 PM   #23 (permalink)
CostaGS88
CostaGS88's Avatar
yep still not working...douche
Old 08/12/2008, 09:34 PM   #24 (permalink)
easy guys. Costa, PM me and I can e-mail it to you bro. Its probably an internet explorer problem, or savefile just sucks, I dunno
I just tried and had problems with internet explorer, but Mozilla Firefox worked perfectly. Maby try firefox?
Old 08/12/2008, 09:38 PM   #25 (permalink)
CostaGS88
CostaGS88's Avatar
easy guys. Costa, PM me and I can e-mail it to you bro. Its probably an internet explorer problem.
Pm'd...you must spead rep before...blah blah blah i hate that hahahah
Old 08/16/2008, 04:52 PM   #26 (permalink)
GT35 pimpin
XwP1ayawX's Avatar
I don't want to clutter this thread, could you check this out? It's using this ROM
Reflash guys
Old 10/29/2008, 08:29 AM   #27 (permalink)
Updated with links to Tephra's 94170015 ROM ver 5.10
bear with me guys, I'm trying to get stuff uploaded to windows live public folder, I think this will be a better place to DL from
Old 10/29/2008, 08:37 AM   #28 (permalink)
EvoAte4Me : who are you?
im running a 94170015 now, does the one you posted have immo delete and all perio files added?
EvoAte4Me is offline   Reply With Quote
Old 10/29/2008, 08:52 AM   #29 (permalink)
The middle one has the immobilizer deleted and knock cel. The periphery has been changed, but I don't think the periphery entries are in the XML. Its ready to rock on a 3g, just needs to be tuned.
I just changed it to the link to the overall public folder, from there pick the middle one
Old 05/19/2009, 01:14 PM   #30 (permalink)
iam12nv4 : who are you?
Just now noticed this, I have been wanting to go with the 15 upgrade as well, thanks, Ill be doing this one tommorow morning
2001 gs 2.4 5spd, balanced & knife edged crank, scat rods, wiesco pistons 9:1, port & polished sohc, 16g 10.5 hotside, ported o2, 3 inch dp dump under car, ecuflashed evo VIII rom (Courtesy FLASHBLUERS), 850cc wrx injectors, Walbro 255 pump, NGK bkr7es, EVO VIII maf, Greddy BOV, autometer EGT, A/F, Boost, stage 3 clutch, All ARP bolts and studs, Zeitronix wideband.
iam12nv4 is offline   Reply With Quote
Old 06/07/2009, 02:32 PM   #31 (permalink)
hastur : who are you?
I am planning to flash the EVO rom to my N/A eclipse.. Can anyone tell me what bits I should disable in the periphery registers to avoid ECU error codes ? My EGR is still up and running so I would prefer to keep it enabled.
Steadly ?
Thanks,
Jeff
2003 Manual RS Eclipse
RPW Camshaft Stage 1 N/A M/T profile
CMF header
Magnaflow Hi-Flow Cat
Greddy SP2 60 mm Exhaust
Custom Magnaflow 14" / 2,5" Resonator welded in
AEM V2 Intake
GT Throttle Body
Magnecor Ignition Wires on Denso Iridium Plugs
Street tuned using EcuFlash and Evoscan
hastur is offline   Reply With Quote
Old 06/07/2009, 06:02 PM   #32 (permalink)
I dunno man. Read up here. They try to define as many bits as possible, I"m not sure if they got the EGR or not.
new feature in ECUFlash 1.35: periphery bits - evolutionm.net
Old 06/15/2009, 06:03 PM   #33 (permalink)
Thanks Steadly it was nice info !
Following this, I turned off bit 15 of Periphery2 and no more CEL for over a week now.
Just to say, I noticed the EVO rom doesn't read the airflow the same way the eclipse ROM does (with the same mod setup), thus computes ECUload differently and give a load curve that is somewhat different than what I had before, so I had to retune my AFR using this ROM.
It also measures knock way differently than the eclipse ROM (I guess it's not listening for the same harmonics).
I also have an occasional lump on idle (each 30 seconds or so, when in closed loop).
Other than that, I copied all my tables from my latest eclipse ROM and everything seems to work fine. After tuning the AFR with evoscan to the same level it was before (13.1) and using the same timing than my latest eclipse tune, Evoscan shows me a torque & HP loss along the powerband. I am investigating on this.
Thanks again for the tips !
Jeff
CMF header
AEM V2 Intake
GT Throttle Body
Old 06/15/2009, 08:05 PM   #34 (permalink)
Jeff
Thanks for the input!
I think the best thing would be to get a used MAF for like $80 and slap that on there.
Also, you'll definately need a retune anyway, the map is for a 2liter engine, will need more fuel at the same load point.
I'm not sure about knock, I always trusted it to be accurate enough to run, I wouldn't change the knock tables.
And what do you mean, "lump on idle"?
Old 07/29/2009, 07:10 PM   #35 (permalink)
straight up newb
3g2000's Avatar
Vehicle: 2000 GS
3g2000 : who are you?
hey steadly, would this work for my situation since you have been helping me out. I have the flashable ecu and my check engine light is on. . . .
3g2000 is offline   Reply With Quote
Old 07/29/2009, 07:58 PM   #36 (permalink)
I'm pretty sure it would work. I don't see why not.
Old 08/04/2009, 06:48 PM   #37 (permalink)
southeast 3g:)
mitsubish3gst's Avatar
Vehicle: 2003 GS-T
mitsubish3gst : who are you?
i uploaded evorom on my ecu cranked it up and the car ran much smoother at idle than what it used too. it will not go ove 3000 rpm so im guessing i need to cope some of my 3g maps to the new rom. How would i do that. and also about the maf dialing i cannot do that because it was not highlight for me in ecuflash.
mitsubish3gst is offline   Reply With Quote
Old 08/04/2009, 07:23 PM   #38 (permalink)
Most likely it won't go over 3000rpm's when you're stationary, its the stationary rev-limiter. If you were moving it should go over that.
Old 08/04/2009, 08:35 PM   #39 (permalink)
stgray22's Avatar
Vehicle: 2000 Eclipse GS Turbo
stgray22 : who are you?stgray22 : who are you?stgray22 : who are you?
you need to change your user level to advanced or developer to get into all the maps
stgray22 is offline   Reply With Quote
Old 08/04/2009, 08:41 PM   #40 (permalink)
johnsgalant : who are you?johnsgalant : who are you?
tephras mods also has a valet mod that wont let u go past a set rpm so that may be your issue too... I think u have to mash the gas to 100% throttle for a few seconds or something while the car is in the on position but not running and that will turn it on or off i forget...
johnsgalant is offline   Reply With Quote
Old 08/04/2009, 11:22 PM   #41 (permalink)
southeast 3g:)
Vehicle: 2003 GS-T
I also thought it might be the stationary rev limiter too but there is a setting for that and it was set to 6000 rpm. im set on begginers level on ecu flash so thats probably whats holding me up. Thanx for the help.
Old 08/04/2009, 11:31 PM   #42 (permalink)
I'm pretty sure the ROM I uploaded had the valet feature disabled, but I could be wrong. If not its like 5sec with the throttle at 100% and the ignition set to "ON"
The SES will flash for a couple sec and it will be disabled.
Old 09/18/2009, 09:30 AM   #43 (permalink)
For people interested by the ROM and that are N/A please read up..
I decided to finally get back to my original eclipse ROM. Even after copying all my eclipse tables from my own ROM, I still had a few problems with the EVO ROM that wouldn't go away:
1. Rougher Idle. Idle was normal, but had a "lump" each 10 seconds or so where I felt the car would stall.. Didn't really stall but it went close to it.
2. Longer startup. I had to crank the car longer than before to get it to start. This is bad here in Canada because it would suck my battery in no time at -30 C during winter.
3. Stall on low RPMs. When going on low RPM (1000-1500), and pressing the gas pedal up to 30-50% throttle, the car would stall completely and wouldn't pull at all.. Releasing the throttle would let the car back to a normal idle. This problem happened much more often during the warmup period.
So I checked with evoscan and I found that the EVO rom timing is very different than the eclipse timing on startup, and there are many tables that allow adjusting timing during startup. I managed to correct problem #2 and reduce #3 pretty much, but it still happened sometimes in precise conditions that the car would stall on low RPMs, even when warm. Very annoying and even dangerous when starting back in 2nd gear on a stop sign.
The reason for me to use the EVO ROM was to correct a phantom knock issue that I am having, but I finally found the needed tables into my eclipse ROM to reduce knock sensitivity, so I decided to go back to my original ROM because of the drawbacks of using it.
I would not recommend using the EVO ROM on the 4cyl eclipse if you are staying N/A. I didn't feel better performance except maybe I felt the car to be a bit more responsive. I think the EVO ROM main loop is faster because I could log more samples per second with it than my original ROM. Maybe this explains the increased sensitivity. But it wasn't worth all the drawbacks that came with it in my case. Also, the EVO ROM computes a higher air flow than the eclipse ROM, even with the same MAF and MAF settings into the tables.
Jeff
CMF header
AEM V2 Intake
GT Throttle Body
Old 09/20/2009, 12:48 PM   #44 (permalink)
boosted x2
TOwEnZ's Avatar
Vehicle: 02 WRX, 00 RS-T
TOwEnZ : who are you?TOwEnZ : who are you?
Send a message via AIM to TOwEnZ
Does anyone have this file? I tried to link but the site is "updating" or something, and I need the file asap! Thanks
- OwNiN' HoNDaS SiNce '04
ZoOm - ZooM
TOwEnZ is offline   Reply With Quote
Old 09/20/2009, 01:07 PM   #45 (permalink)
boosted x2
TOwEnZ's Avatar
nvm got it. thanks alot!
ZoOm - ZooM
Old 11/25/2009, 03:51 PM   #46 (permalink)
UPDATE 11/25/09 Tephra's V7 added
Old 12/07/2009, 04:58 PM   #47 (permalink)
GT35 pimpin
XwP1ayawX's Avatar
Im still working out the bugs in my injectors. If we swap over to Tephra's we don't have to enable any of the extra shit yet, do we? I can still get a baseline tune before I start playing with the features of T's v7?
Old 12/07/2009, 06:22 PM   #48 (permalink)
Absolutely you can have all the shit turned off, except for the BIGMAP. that can't be turned off
Old 02/03/2010, 10:13 AM   #49 (permalink)
Old 02/14/2010, 08:07 PM   #50 (permalink)
OK, just a little update, I got the 94170715 up and running today, works great. No throttle hang problems, everything seems to be smooth. I did have to add the periphery tables to delete the immobilizer. I'll have to get an uploaded version with the immobilizer deleted for everybody. The rev-limiter works again, lol.
Old 02/21/2010, 03:49 PM   #51 (permalink)
OK, I uploaded the 94170715 that has the periphery changed to allow passing of emission. This ROM does not have the "Force pass emissions" patch, if you need that it can be added following the instructions on evolutionm.net, just search for it.
Page generated in 2.96426105 seconds (100.00% PHP - 0% MySQL) with 11 queries
