#61 (permalink) | |
#62 (permalink) | |
Im hoping and planning on taking atleast 1 additional K Frame to modify, that way we atleast have a working template to make others from.
2003 Eclipse GS-T 5 speed Fed-spec 14 psi |
#63 (permalink) | |
#64 (permalink) | |
I <3 BOOST
Vehicle: 03 gts & 91 gsx
#65 (permalink) | |
Vehicle: 2000 Eclipse GSX
What are you having trouble with? Is there something else I am unaware of? |
#66 (permalink) | |
Evo Driveshaft: ![]() 2g Driveshaft:
#69 (permalink) |
Got the coil cover on and replaced all the valve cover bolts with stainless steel.
![]() I also measured the stroke tonight and it's 100mm so I guess I'll be running the 2.3. Still awaiting a few small parts and then I'll start to tear the car down. |
#70 (permalink) |
droptop sleeper
Vehicle: 2001 Eclipse Spyder
Your build is really coming along. How long has it taken to get this far? I was wondering what your thougths were on the ecu. Are you going to swap the evo comp. in and tune that or leave ur 3g ecm and add a stand alone system and do a full custom tune to the specs you need. Also what were ur biggest problems or snags that you ran into so far and what would you recommend someone else doing to make it easier or avoid those problem in general? |
#71 (permalink) | |
I will swap the Evo computer in and then try to run the Eclipse wiring harness. If there are even a couple of snags that don't work then I'll just use the Evo wiring harness. I have worked on more than 20 DSM's and Evo's and done 800+ hp builds on some of them. I would HIGHLY recommend no one take on this project unless you can do ANYTHING to a car. Welding, rewiring a harness, turning wrenches, rebuilding trannies, rear ends, and motors. You have to be able to do everything to do a swap such as this. If not, then the project just won't be able to be completed or you'll be breaking shit or it just won't run and you'll have to learn how to do whatever you fucked up which could take a long time and you'll be spending lots of money fixing your fuckups. |
#72 (permalink) | ||
Your on the right path! Exactly what im going to do. This might also help... Im planning on getting some really long bolts to replace the ones on the K-Frame. With the motor and transmission mounted (of course steering rack, linkage, swap bar disconnected) i will raise up the K Frame and notch out (better to measure twice and cut once) -But im sure you already had this all figured out. Quote:
Also, nice video you have on youtube....the 25psi run... (thats my car, )
2003 Eclipse GS-T 5 speed Fed-spec 14 psi Last edited by kng nothg; 10/17/2008 at 11:04 AM. |
#73 (permalink) | |
droptop sleeper
#75 (permalink) |
N my Flippy Floppies
Vehicle: 2001 Eclipse GT PP
Hey do you need anymore radiator fans on the back wall
![]() Car is looking good, Im glad you have been keeping up with the pics for this swap.
JIC Muellerized... Secsiness 2001 GT PP A/T 205whp/203wft-lbs Tuned by LogicGate, Sponsored by Tearstone |
#79 (permalink) |
Not really. I already have the subframe notched for the steering pinion that comes out of the steering rack once it's lowered. I bolted up the steering rack and it clears just fine but the fitting that goes on top of the rack needs to be relocated to the bottom like you did or otherwise I'll have to space the whole rack out another 1/2" to clear the transfer case. I was planning on cutting the oval shaped brackets that house the rack and spacing them roughly 1.75" inches down, then rewelding them with the proper support behind it. What did you use for spacing? Have you had any problems with your setup yet?
#80 (permalink) |
YOu arent going to box in that cut out in your subframe? The cabin filter looks nasty, looks like some mouse decided to take a poo in there for ya.
#81 (permalink) |
Vehicle: 03 AWD DOHC Turbo GSX
That's what I was about to say, you need to reinforce what you notched out, that subframe has to handle a lot of stress and the way it sits it will simply fold and mess everything up. The biggest problem I have is not enough clearance in the tunnel with the transfer case. If you take off fast and let off the top of the t-case will knock.
#84 (permalink) |
I have a couple of questions that maybe some of you could answer:
Where are you guys installing your injector resistor packs? I know to follow the red wires from the injectors but I'm trying to get as far away from the engine as possible. Heat kills electrical components which is why the turbo dsm's and evo's have such problems. Has anyone deleted a/c on the 4-cylinder? I need a part number for an a/c delete belt. |
#86 (permalink) | |
I Deliver Porsches
and good luck on the project... and to whoever posted above about an evo swap how-to, the head swap has been documented a while back by flash. but the awd thing i think this guy is goin to do |
#87 (permalink) |
OMFG... Erf.....
i posted up the belt before, you need a 43.5inch belt with 5 groves
, i think the part number was 435k5 for a duralast belt, i've installed my old resistor pack here, if that helps
http://s608.photobucket.com/albums/tt168/DAveStrifeDC/ http://www.facebook.com/profile.php?id=751406568 Video of Bewst 16psi, And GsBabyBoy10! is filming http://s608.photobucket.com/albums/t...rent=Movie.flv Sorry for the rattle my hammers and tools, jack and stuff in the trunk with no trunk interior panels, Last edited by DAve3GEclipse; 11/03/2008 at 06:01 PM. |
#89 (permalink) | |
Awesome news about the belt. Saves time and gets the project moving along faster. Thanks for the help! |
#91 (permalink) |
I got my subframe back from the local fabrication shop. He did a pretty good job. I also had him relocated the intercooler top mounting bracket. This car is going together soooo slowly. It better be worth it.
#92 (permalink) |
Why are you keeping the 5mph reinforcement if you cut it in half? Just unbolt the 2 pieces you have left as they aren't doing anything anymore.
#95 (permalink) |
What was the support welded in place? heh
#96 (permalink) |
2000 gs
check the link out... another member modified the ic an crush bar for better clearance of the ic n reinforced it Winter 2007-2008 progress ... 56k warning
#97 (permalink) |
The intercooler is my new crush bar. I could add reinforcement but I'm too lazy.
Update: Car is now rolling. Had to get it on the ground so that the shop could repair the roof before the snow got here. All I have left is complete fuel system, driveshaft, install bushings on front lca's, a bunch of rewiring, intercooler piping, exhaust,and a bunch of small stuff such as fluids. Right now the subframe sits flush against the bottom of the car but has slight pressure against the transfer case. The rear motor mount still has the bolt through it. It didn't do this when I had the motor on the cherry picker, with the subframe and crossmember attached to the front and rear motor mounts. The motor mount is flexing upwards right now and when I get time later on in the spring I'll revise it by replacing the subframe studs with longer ones and using thick spacers. I can't take away any more subframe to clear the transfer case or else there won't be anything left. |
#98 (permalink) |
Be careful in your shimming because you will be affecting your suspension geometry in the front.
#99 (permalink) | |
The only geometry that will change is the lca will have it's range of motion pointed up higher and the sway bar will probably have to be relocated a second time a few inches forward. |
#100 (permalink) |
I know you're dealing with the engine, but just want to tell you that the rear upper control arms of the GSX are the same as 3g Eclipse, but weaker because they are made of stamped steel. I'd swap your stock ones back, they are a lot stroger /tubular/.
Nice build by the way, i need a GSX rear end myself |
#101 (permalink) | |
Where's your proof? |
#103 (permalink) | |
Too bad I already sold my stock rear upper control arms. |
#105 (permalink) |
T-Money is T-Money
Vehicle: 03 Eclipse DOHC GS-T
this is a really great thread, good job and cant wait to see the final finishing touches, if only the subframe wasnt such a pain in the ass I'm sure more of us would be willing to tackle this.
#110 (permalink) |
No updates.
![]() I haven't worked on it since Nov. 22nd of last year. I was gone on Thanksgiving break, then had finals, then Christmas break. Plus the shop it's at is having the roof repaired and no cars can be in there. I dunno when I'll get to work on it again. The good news is that it is currently rolling so not too much is left
#114 (permalink) | |
This week me and a buddy are renting a 40' x 20' storage garage LOL. We're gonna bring all our tools there and finish the job. Pics are coming shortly... |
#115 (permalink) | |
finally BOOSTED
Vehicle: 19.5 PSI SDS 2004 blk GT
YAY!!
Black on Black Injen SES catback exhaust AEM Cold air intake progress rear sway bar http://bloodweed.mybrute.com |
#118 (permalink) |
GT35 DOHC 500wHp
Vehicle: 3G turbo
Nice man car looks good!! Now snap some closeups of your front subframe and driveshaft!!
Wiring is really easy just have to extend starter wires, TPS and couple of others, depends how u route them. |
#119 (permalink) | |
Those subframe pics I already posted didn't help? |
#120 (permalink) |
GT35 DOHC 500wHp
Vehicle: 3G turbo
It helps allot!! but could u snap different angles of subframe, than subftrame installed and clearance of TC. Also interested how u will mount your drive shaft.
GL finishing it up!! |
