Go Back   Club3G Forums > Performance & Tech Forums > 3G Eclipse RS/GS Specific
Old 12/18/2008, 09:19 PM   #1 (permalink)
Lusos's Avatar
Vehicle: 03 Eclipse GS
Lusos : who are you?
Servicing an automatic transmission...
I feel really stupid for asking this... In the past, I've done a couple of engine swaps, complete brake jobs (both disk and drum), and even rebuilt a turbocharger. Hell, I'm an undergraduate Mechanical Engineer. However, I have never serviced an automatic transmission. When I changed the fluid in my Isuzu, it was a pretty easy thing. Just drain from the bottom plug, then refill through the speedometer cable. But then again, that was a manual transmission.
I have been wanting to change the fluid in my GS, being that the car has 85,000 miles (had the car since 59,000 miles) and has never had the transmission drained as far as I know. Is it just as simple as draining then refilling? My father keeps advising against me doing this because he claims there are all kind of filters and I need to "flush" the fluid out. Personally, I think he's just overemphasizing it due to the fact that he's never serviced an automatic either. (He claims that we should keep the stock fluid because, I guess out of luck, his Chevrolet with 235K miles has never had the 700R serviced).
What would be the procedure? Just drain and refill. Any help would be appreciated.
Originally Posted by daveyg
The nitrous button is like a really f_ing hot chick with STD's, you wanna hit it, but you're afraid of what the consequences could be...:
www.GeorgiaDSM.com
Lusos is offline   Reply With Quote
Old 12/18/2008, 09:36 PM   #2 (permalink)
Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.Bitter paypaled $25 to ED for this rep.
Send a message via AIM to Bitter Send a message via Yahoo to Bitter
pretty much, drain and refill. adjust the level when hot and in park...
heres how we do it.
drain
fill to cold marks on dipstick with engine off.
start engine
recheck fluid level and add till at cold marks again.
let engine warm up fully and recheck level
add fluid till trans is in hot range
take the vehicle out on the road and let it shift itself through all gears
park on a level surface with the trans in neutral and check fluid level, add if needed.
iirc these transmissions take a specific fluid specification, not dexron/mercon.
and to the 235K mile trans on original fluid, i guarantee his trans will shift alot better with new fluid. that trans is VERY easy to change the fluid and filter on, just drop the pan, put in a new filter, new gasket, put the pan on, and fill up. use the same procedure to obtain the correct fluid level.
Old 12/18/2008, 10:18 PM   #3 (permalink)
def jukie
5dollapizza's Avatar
Vehicle: '00 eclipse gs
5dollapizza : who are you?5dollapizza : who are you?5dollapizza : who are you?
if you have another person handy, after you drain out of the plug, disconnect the lowest fitting on the passenger side of your radiator. have someone start the car for about five seconds at a time. this will get the remaining couple quarts out of the tranny. oh and make sure to have that drain pan under there the whole time.
5dollapizza is offline   Reply With Quote
Old 12/19/2008, 08:34 AM   #4 (permalink)
N my Flippy Floppies
Special_K's Avatar
Aqua Slug Champion!
Vehicle: 2001 Eclipse GT PP
Special_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club exists
Send a message via AIM to Special_K
I believe if you go to tearstone.com, Russ still has the service manual for the 00-05 Eclipse. I used that for my tranny flush and it made it super easy. There are a few steps in the service manual where they have you start the car for 10-15 seconds to drain the fluid out of the torque converter. Let me find the linkie for ya.
JIC Muellerized... Secsiness
2001 GT PP A/T 205whp/203wft-lbs
Tuned by LogicGate, Sponsored by Tearstone
Special_K is offline   Reply With Quote
Old 12/19/2008, 08:37 AM   #5 (permalink)
Special_K's Avatar
Aqua Slug Champion!
http://tearstone.com/eclipsefsm/GR00003500-23A.pdf
Page 23A-347. Good luck.
Old 12/19/2008, 09:29 PM   #6 (permalink)
no need to goto all those lengths, just drain and refill is fine. do that every 30-60K miles and you'll be fine. its a mitsu automatic...its not going to last that long anyways
Old 12/20/2008, 10:25 AM   #7 (permalink)
def jukie
mines got 218k on it. bought it with 190k, although they are all freeway miles and the lady i got it from had a HUGE stack of receipts for all the maintenance she had done..
Old 12/28/2008, 02:11 PM   #8 (permalink)
Lusos's Avatar
Thanks guys. I appreciate all of the help.
To the bat cave! erm.. I mean, my garage!
www.GeorgiaDSM.com
Old 01/01/2009, 08:48 AM   #9 (permalink)
qnz
Galant-Turbo
Vehicle: 2003 Galant
qnz : who are you?qnz : who are you?
Send a message via AIM to qnz
well with old cars like your dads chevy, the old oil is probably holding his transmission together.
qnz is offline   Reply With Quote
Old 01/07/2009, 10:42 AM   #10 (permalink)
Lusos's Avatar
Quick question...
From what I have found, I'm going to need to use Kia/Hyundai/Mitsubishi Diamond III fluid or whatever the hell Chrysler equivalent. Does anyone recommend an equivalent brand? All I can find that matches the standard is Redline, Motul, and AMSoil, each being around $9 per quart. At 8.1 quarts (lets say $9), that's about $85 including tax without the filter and gasket.
Cliff notes: any recommended fluids?
EDIT: Dealer just gave me a quote of $6.75 per quart! Time to see what Kia will charge.
EDIT: Kia ATF SP-III runs at $7.25 per quart. Time to check Hyundai
EDIT: Hyundai wants $6.47 per quart, which is my cheapest route yet.
www.GeorgiaDSM.com
Old 01/07/2009, 04:41 PM   #11 (permalink)
Lusos's Avatar
Wow, I guess looking around does pay off... About an hour after typing the above post, I went to Autozone to see what kind of fluid they had. Low and behold, for only $3.99 per quart they had Costal ATF which "meets and exceeds" Diamond SP-III Mitsuhishi rating.
Yay!
www.GeorgiaDSM.com
Old 01/07/2009, 06:26 PM   #12 (permalink)
03DMeclipse's Avatar
Vehicle: 03 Eclipse
03DMeclipse : who are you?
Send a message via AIM to 03DMeclipse
Yay!
have you gotten the filter and gasket yet?
03DMeclipse is offline   Reply With Quote
Old 01/07/2009, 07:13 PM   #13 (permalink)
coastal is sort of the bottom barrel fluid...
Old 03/08/2009, 11:14 AM   #14 (permalink)
Lusos's Avatar
Sorry for the late follow-up, but some things came up and I had to put the Eclipse on hold.
Anyways, I changed the fluid just like the manual said and everything works great. The car shifts at lower revs (like it did when new) and the shifting is overall much smoother than before. When I changed the fluid it was straight black and there was gunk built up around the drain plug, so apparently an oil change was in order.
I do have a bit of warning to anyone who is about to change their fluid. HAVE TWO OIL PANS. You will need one to place under the disconnected cooler line and another one placed one foot back from the oil cooler nipple. Trust me when I say that it will shoot fluid two feet back under the car. Better yet, have someone there to help you when it is being changed.
Thanks Club3g, you guys have been a toon of help.
www.GeorgiaDSM.com
Old 03/09/2009, 10:14 PM   #15 (permalink)
Vehicle: 2006 Mazda3s
kmfdmz3 : who are you?
got a question for you guys. my girls 01 eclipse rs has about 140k miles on it. its an automatic. she's never changed the tranny fluid. would it still be safe to drain the fluid, pull the pan and replace the filter? or is the fluid keeping the tranny together?
kmfdmz3 is offline   Reply With Quote
Old 06/15/2009, 10:03 PM   #16 (permalink)
Vehicle: 2001 Eclipse GS
rmbootsman : who are you?
Just change the tranny fluid, my car has 170k and I changed the fluid, so no the fluid is not holding the tranny together!
rmbootsman is offline   Reply With Quote
Page generated in 2.24281502 seconds (100.00% PHP - 0% MySQL) with 11 queries
