T-Money is T-Money
Vehicle: 03 Eclipse DOHC GS-T
New Project for 2012
So I have nearly everything I need for the AWD swap, minus a couple things here and there. I won't be starting the conversion right away as I would like to have everything before I begin. Also I need a little inspiration/motivation.
Heres What I have: modded front subframe Front evo knuckles w/hubs Front evo axles Evo 8 transmission evo 8 starter evo 8 rear diff GSX rear non-lsd axles GSX rear subframe GSX rear knuckles/hubs GSX gas tank w/harness Rear GSX Diff bushings 4/3/2012 Bostonhatcher's rear diff mounts 4/3/2012 Update: 4/3/2012 Been doing some research and was reading about the differences in the DOHC head swaps and it turns out using the evo head bumps your compression to 10.5:1. Which is very high for the 20 psi I'm pushing. I've been talking with Greg and I'll be sending him my motor for a full build while doing this swap. here are some pics this might look familiar to some ![]() ![]() ![]() ![]() ![]() things I still need evo 8 clutch evo flywheel slave cylinder transfer case exhaust driveshaft optional but will be getting as well coilovers brembos Last edited by Osirisfool; 04/03/2012 at 02:53 AM. |
T-Money is T-Money
T-Money is T-Money
Received Boston's rear diff mounts and a set of subframe bushings.
Turbo plans I'll be going with an stock Evo 8 manifold ported by map performance and the ATP stealth gt35r turbo kit. If anyone is interested in my A.A.I. Turbo parts keep a look out they will be for sale very soon
