Vehicle: 2000 Eclipse GS Turbo
Suggestions for a new intake manifold, high performance motor mounts, torque dampener
I have a 2000 eclipse GS 2.4L with a 5431 Precision turbo pushing 18PSI and I keep snapping stock manifolds in half at the neck do to much torque.. I've been looking forever for an after market intake manifold that will fit the car. I've found some from edle Brock that say they are unversal on thier site http://www.edelbrock.com/. Also how many motor mounts would I need and which ones?
Thanks in advance! Sent from my iPhone using AutoGuide.com Free App |
I'm also trying to find a torque dampener to fit the 4G64 engine. I can only seem to find them for the V6.
Aple juic is my beer
I remember reading about the damper. You ah e to frankenstein a damper from the v6 one and the Evo one.
Sent from my iPhone using AutoGuide.com App |
swap an evo/ptima head. you get a higher flowing head, larger throttle body, and higher flowing aluminum intake manifold.
Hey guys, I have found OEM has just made a brand new intake with a re-enforced flange. Just got it in today and I'm going to install it Saturday and see how it goes. By the way I am boosted I was running 18PSI and I have after market coil overs. I won't be able to lift my engine for the mounts for a while so I also ordered an ingalls torque damper. Thanks for the info guys. Ill post pictures and progress.
Sent from AutoGuide.com Free App |
What do you mean by OEM? Did you mean to put something different company wise or are you saying you got another factory intake manifold with a reinforced flange?
If you truly want an intake manifold to perform and benefit your turbocharged 4g64, I say have a custom intake manifold made. You could use the existing factory intake manifold flange with at least 2-3 inches of all 4 of the port tubes still connected. Then cut more tubes from another factory intake manifold to weld onto the other 4 tubes already on the flange. Or you could use any other tube as long as it's around the same size and same material. Then you could use a fire extinguisher to weld onto those tubes then use the factory intake manifold neck and weld that onto the fire extinguisher end where the throttle body would go. After all that you then just make vacuum ports and other ports needed for any other hoses that connected to the factory intake manifold. Here are threads where it has actually been done. I included all 3 so you can get more pictures and a better understanding of how he did it. 1badrs Comeback 70% complete Just broke 357whp at 15psi ruff intake manifold pics |
[IMG]
![]() New intake. Almost looks stock but it seems much heavier duty. Hopefully it'll do the job.. Sent from AutoGuide.com Free App |
Shocker Lite
Referring to your old manifold: It's a pretty easy fix when you have the right tools. I could make a new flange for the TB on the mill then weld it in place.
However, I wasn't talking about repairing it. I want to cut the stock flange & injector ports off of it, then weld on new runners & a custom plenum. It would resemble most of the aftermarket evo intake manifolds, but cost far far far less. |
#18 (permalink) |
Why if it's unnecessary? That's way more work and money than fixing a manifold ten times.
If you know it's going to brake then take half an hour with the wire brush and half an hour with the welder and hit each seam then put it in with the factory brackets. |
#19 (permalink) | |
REDLINE ALL GEARS
Vehicle: 2002 GT SDS
oh wait nevermind jk im curious how much torque you have to break that. I would weld it and check your mounts |
#20 (permalink) |
Yep. I cracked my intake manifold neck early last year. I took it off, bent the large cracked portion slightly open and prepped it by sanding that area where it will be welded. Took it to Muffler King and told them to weld it. It would have cost $20 but the guys like me so they didn't charge me. It's a cheap and easy fix that will last a good long time.
