Zero Resistance, LLC
![]() Join Date: Jan 2003
Vehicle: 02 DOHC Eclipse RS
DOHC head and compression
I was curious about the compression ratio with the new head on my car, so I crunched some numbers and found something very interesting. The head increases the stock 9.5:1 CR to about 10.2:1, maybe slightly more. A .7 jump is pretty good without touching the pistons. This worked out great for me, but FI guys will need to take this into consideration when doing the head swap.
KD0FIZ
Great to know. eRep for you.
- Doug 2001 Eclipse GS HOBOWARS! EFC Mitsubishi-Forums Evolution M Missouri Mitsubishi |
1st 4cyl DOHC 3G
Vehicle: SPYDER GS TURBO
I'll let you know the exact cc of the head next week.
2003 eclipse gs spyder @ 15psi evo 8 Turbo 9.8 hotside FMIC fic 550 Injectors 3" downpipe Rear disc conversion Evo carbon fiber hood Innovate LM1 Wideband ECUFLASH Progrmmed E-01 Boost controller/Programmer Manual Trans Swap prothane motor mount kit Tein S Tech Springs Kyb AGX struts |
Cocknozzle
Cocknozzle
Vehicle: 02 Eclipse Gs
is it possible that there are different compression ratings for different years??? i wouldn't think so as long as it was still the 4g64
I am going to check the manual when i get home but here are 4 websites that say its 9.0 http://www.internetautoguide.com/car...788/index.html http://www.automotive.com/2002/101/m...ons/index.html http://www.automobilemag.com/am/2002...fications.html http://www.automallusa.net/2002/mits...fications.html the official website isn't working but that says 9 too... i dont know anyone done a compression test to know exactly |
I'm just reading what the official mitsubishi service manual says. Doesn't matter anyway. The stock compression isn't even used when determining the compression with the DOHC head. The final compression ratio with the head swap is still in the 10.2 range.
back to the 3G...
Vehicle: 2001 Eclipse Spyder GT
I think the reason that FTG is as concerned as he is, is because he's having his N/A 4 cylinder build done with 9.6:1 compression ratio pistons. While the difference between 9.0 and 9.6 isn't all that much, it is more than the difference between 9.5 and 9.6.
back to the 3G...
Yes, agreed. I have to say myself though too I was surprised to hear that the stock compression is 9.5. The raised compression from the head swap sounds like a nice thing for those who have done it on a N/A car...but yeah, that's a possible issue for those with FI.
Damn, I wish such a swap was possible on the V6. |
imiTatum
An interesting side-effect of the head swap, to be sure!
Thanks for the info, flash. I'd like to hear your input on the thread I just created: http://www.club3g.com/forum/3g-eclipse-rs-gs-specific/78215-tampablues-eclipsed-evo-project-phase-1-dohc-research-post1868864.html I'd love for you guys to contribute... particularly the apparent "pioneer", DNS-EN. I'm sure PharmEcis and many others on here have tons of knowledge and trivia they could add, too...
My Ride, gradually evolving... My ambitious "Eclipsed(EVO)" plans for my GS: PHASE 1 -DOHC research__(n00bish fumblings) First documented AWD 3G_(local inspiration) messing w/ Evo 8 gear____(turbo options) See where I'm going with this? ...right back into debt. |
1st 4cyl DOHC 3G
The kia dohc has a 56cc chamber. I'll have some pics of my head later today.
1st 4cyl DOHC 3G
The head swap actually lowers compression from 9.5:1 to 8.5:1 the stock head chamber size on the sohc is 47cc the kia dohc is 56cc
I left piston height constant between the eclipse and optima motors when I calculated compression. This skewed my results because they are different. Once DNS gets the exact chamber size of the sohc motor, we will know for sure.
#17 (permalink) |
Vehicle: 2000 RS
the 4g64 has a 9.0 to 1
the 4g69 has ths 9.5 to1 is there a way to gauge the compression?
stock RS. 16.1 in 1/4 mile car on diet, but still stock = 15.58 2006 FASTEST ECLIPSE RS/GS STOCK 2006 FASTEST ECLIPSE RS/GS N/A 2008 NEW RECORD, RS/GS N/A = 15.2 2009 DOHC + 10psi = 14.0 @ 101.89 MPH 2009 DOHC + 15psi = 13.3 @ 108 MPH |
#18 (permalink) |
1st 4cyl DOHC 3G
#20 (permalink) |
Vehicle: 2000 RS
well lets figure it out, we know the CC of each head, kia, eclipse, and evo, all we need is the volume when the piston is at the bottom, anyone know this?
#21 (permalink) |
1st 4cyl DOHC 3G
I already posted the figures not my problem if you don't like the answer.
#22 (permalink) | |
Vehicle: 2000 RS
PS the sky is green, you dont like it tuff. prove your answer.
#23 (permalink) | |
1st 4cyl DOHC 3G
(syringe + oil) * plexiglass/w small hole drilled in top = actual cc of head
#24 (permalink) | |
1st 4cyl DOHC 3G
BTW I don't have to prove my answer your the only one saying I'm wrong you prove yours I really don't give a shit.
#25 (permalink) | |
Vehicle: 2000 RS
and i am not an asshole, i am an engineer, and i have to prove all the time, why i say something is the way it is. i am just asking you to show your work on how you got the ratio's
#26 (permalink) |
Vehicle: 2000 RS
as you can see, i said we know the CC of each head. i want to know the volume of each chamber so we can use that number and the CC's to get the compression ratio, which is what some one was asking for.
#27 (permalink) |
I wouldn't tell anyone you are an engineer when you can't do this simple problem solving. Critical thinking is very important as an engineer.
All the specs you need are in the service manuals. Everything besides the size of the dish in the piston. Which is where i made my mistake because the pistons are different. Then you need to know how to find the volume of a cylinder. Middle school math. |
#28 (permalink) |
Vehicle: 2000 RS
well my good budy, i do not have a service manual. i bought the car used, and also had no floor matts
also did you see my question about that ECU?
#30 (permalink) |
1st 4cyl DOHC 3G
Well Mr. Cocknozzle do a search for compression ratio calculators like the rest of us nonengineers.
#31 (permalink) |
Vehicle: 2000 RS
why are you snapping at me man?
this guy wantted to know the actual compression with the kia head, i was just trying to help him out. and if anyone knows why i am cocknozzled, please let me know, it happend in my forum where i did weight redux. i did nothing to get it.
#32 (permalink) |
ASSHOLE!
i think its because your a cocknozzle just a crazy guess tho
http://www.myspace.com/mustangfreak1983 |
#34 (permalink) |
Volume of the cylinder would be 2.4 / 4 right? heh
#37 (permalink) |
I was trying to give the other guy his middle school math lesson.
#39 (permalink) | |
#41 (permalink) |
turbo? unf unf!
you can't figure out compression ratio exactly without using a burette, varsol, and actually measuring it.
as far as i recall the FSM has a mistake in it. it says 9.0:1 and 9.5:1 in a different page which me and napalm clearly showed a while ago. flashbluers: you're running the stock pistons with the evo head? how'd you get them to clear? dns-en: so i guess the evo head is quite different from the kia head if the head volume is 56cc? we measured the evo head at a stock 43cc and 41.5cc after we surfaced the head
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project |
#43 (permalink) |
turbo? unf unf!
ah nice, cause there was less than 0.020" clearance on the intake valve when we did a valve to piston clearance with my dished ross pistons for the 4g64 that had no valve pockets in them. so i don't understand how people are running stock pistons with the evo head
#45 (permalink) | |
Vehicle: 2000 RS
dam, why did i not see this before.
#46 (permalink) |
turbo? unf unf!
be careful, i would really suggest you measure the valve to piston clearance on both intake and exhaust valves -- super crucial
#48 (permalink) | |
OMFG
![]() I never said anything about calculating c/r becuase its kinda pointless beyond a very quick, and rough guesstimate. But anyway. Yes, Ive always known the 2.4Liters as the volume of the assembled motor, from the top of the piston at BDC to the blocks deck multiplied times four. Which would be exactly the measurement you would need to estimate the c/r. |
#50 (permalink) | |
1st 4cyl DOHC 3G
#52 (permalink) |
Vehicle: Galant GS
TDC=Swept Volume(same as BDC) divide by Compression ratio minus 1:
TDC=Swept Volume/(Compression Ratio-1) Swept volume equals (bore^2)*stroke*(0.7854)] So swept volume for the 4G64/G4JS is 587.656cc Since the kia optima has a compression of 10.0:1===> TDC=587.656/(10.0-1) =65.295cc The kia head cc is 56cc so subtract that number from the TDC: 65.295cc-56cc=9.295cc Now the trick part: gasket volume. Gasket volume is the same for measuring a volume for a cylinder object: volume=(pi)*height*(radius^2) So if 86.5mm=8.65cm/2=4.325cm for radius and height is the gasket thickness. Assuming the gasket thickness is 0.042" is 1.0668mm or 0.10668cm. Volume for the gasket for one cylinder is 6.269cc Subtract the gasket volume from the remaining TDC: 9.295cc-6.269=3.026cc, assuming the piston to deck height is near or at 0mm. Since this is a positive number, it indicate that the pistons are dished. So if anyone considering swapping the optima pistons, the compression ratios are: 4G64 w/SOHC: 11.44:1 4G64 w/Evo DOHC: 12.24:1 And compression ratios with the stock pistons(9.0:1CR): 4G64 w/Kia DOHC: 8.5:1 (Correction: 8.1) 4G64 w/Evo DOHC: 10.0:1(Correction: 9.5) Last edited by mysticj; 06/17/2008 at 07:30 PM. |
#57 (permalink) | |
Mysticj i was reading through your first post again and what about optima pistons with the optima head? or was this part "4G64 w/SOHC: 11.44:1" a typo? and meant to be 64 w/kia DOHC?
Brandon - Fully Built 64/63 Galant |
#58 (permalink) |
Vehicle: Galant GS
Yes, the 64 w/kia DOHC...kia pistons with kia head is the same as a stock kia: 10:1cr.
The 4G64 with Optima(G4JS) pistons with the stock 4G64 SOHC head should yield compression around 11.44:1. The 4G64 with the same kia pistons with an Evo head should yield compression around 12+. I hope I clear that up from you about swapping the optima pistons into a 4G64. btw...the cams for the sonata(don't know about the optima) starts off 'okay' and later become shitty...the99-2000 G4JS sonata is 252 intake/262 exhaust with 9.5mm lift on both cams; the 2001-03 has the same intake cam but exhaust has 244 exhaust with 9mm lift and the 2004-05 has 248 intake/exhaust. I know the jdm evo 8(unsure about the usdm) cams are 260 intake/256 exhaust with 10mm intake and 9.5mm exhaust lift. Last edited by mysticj; 08/24/2007 at 10:28 AM. Reason: update |
