Suspended Seller
Cocknozzle
Vehicle: 2000 Eclipse
A Few Alarm Questions
I am going to be installing my Remote Start/Alarm System. (Autopage 915)
I am wondering if I need to do anything to bypass the factory alarm? Also wondering what is a good place to put the Valet Switch on the Eclipse? And are these wire colors for an 2005 correct? 2000-2006 Eclipse wiring diagrams |
"S" Car...Gooooooo
Vehicle: 03 GT-T
Those wire diagrams seem to be fine as far as I can remember. If your car has teh factory security, I would recommend using ONLY the "arm" and "disarm" wires on the vehicle hooked up to your lock/unlock on the DEI this way the doors will lock/unlock as well as arm/disarm the factory system all without having to worry about the pulse timings. Or else hook up the arm to arm, disarm to disarm, lock to lock, and unlock to unlock. This will however sometimes do strange things with the priority unlock timing. No matter what, though, remember to get a transponder bypass for the chip key (unless it's been disable in the ECU). GL.
Suspended Seller
Cocknozzle
Thanks for the fast reply.
I don't have the Key Fob to the factory remote cause the dealership didn't have one when I bought the car. So I can unlock and lock the car fine because it's disarmed. I already have the Transponder bypass module. Will it still do "weird things" (can you please go into depth about that?) Even though the factory alarm is disabled? |
"S" Car...Gooooooo
Vehicle: 03 GT-T
^^^^this.
Those are the most important to ensure that the factory alarm will arm when you lock with the remote, and disarm when you unlock with the remote (DEI). Even without the factory fob, if you lock the doors using the inside door switch, you are arming the factory system. When you unlock it with the key in the door cylinder (as long as the "sensor" inside isn't broken) you are disarming it. Under normal circumstances, this all happens seamlessly and without much to-do. If you use only the "arm" and "disarm" wires on the cars' ETACS (according to the diagrams) with the DEI's "lock" and "unlock" outputs, not only does this functionality remain entirely intact and transparent to you as a user, but the lock and unlock functions on the vehicle will operate as if you were using a factory fob! Note: you MAY need to program double pulse unlock - depends on the specific DEI unit and whether or not your car had priority unlock enabled to begin with. Good luck with the install.
Suspended Seller
Cocknozzle
@Fliegendaffe - so just hook to the factory arm/lock and disarm/unlock?
@Svenhoek - I don't mind it arming when I press the lock switch from the inside, I hardly/Never ever do it. I have the DEI 556UW transponder bypass module. What you mean by Double Pulse Unlock? And thanks for all your help fellas. eRep! (If I don't have to spread around) EDIT: what is the DBI slot for? It shows it on the wiring diagram next to the LED Indicator ( far right )
Smart Ass
Vehicle: 2013 Lancer ES 5sp
Hook up every wire, arm to arm, disarm to disarm, unlock to unlock, lock to lock, etc.
Double pulse means it sends 2 unlock signals in short succession. Toyotas always needs this but some other vehicles need it as well. The reason you might need this is if when you hit the unlock button on your key fob it only unlocks the driver door, hence priority unlock (a "security" feature from the factory). Make sure you have a second key for the 556u, you will have to place it in there. The dbi slot is a data port. It is more than likely a slot for the brain to talk to a bypass via data instead of wire to wire. You don't have to worry about that slot.
Suspended Seller
Cocknozzle
Ahh okay gotcha.
Alright I don't think I'd want the double pulse anyways. So if I click unlock twice it'll unlock both doors? And yes, I have a Key with the chip to stick it in there. The problem is I only have one key. What I was thinking of doing was making a spare(with no chip) and just keep my key with a chip into the transponder and use the spare just to open doors(if my remote dies) and use it to turn the ignition when I use the remote start. Speaking of my remote battery dying, if it dies, I have to use the valet switch to disarm it, so what is a good place to put the Valet switch in an eclipse? Cause I don't want someone to break into my car then just press the valet switch. |
Suspended Seller
Cocknozzle
Ohhh reallly? ...damn.
The fuse box is probably the spot. EDIT: Also what is a good constant 12V power source? That is under the driver side steering column Last edited by El Guapo; 06/29/2011 at 02:41 PM. |
"S" Car...Gooooooo
Vehicle: 03 GT-T
Unless you wire up the 556U with your one chip key in it, to activate anytime that the ignition is turned on (thus circumventing the key security) you MUST have at last two chipped keys. One for the bypass (556U) and one to start the car. The door lock is irrelevant at this particular point in time.
IDEALLY, you run battery power straight from the battery, but usually if you get a VERY SOLID connection on the 12V wire at the ignition harness under the steering column you should be fine; it's just not quite as secure or tamper-proof. |
Suspended Seller
Cocknozzle
and how would i go about that?
and i heard that it isn't good to run the alarm straight to the battery cause it just screams "alarm!". Are you saying i should ire it in with all the other wire or what? |
"S" Car...Gooooooo
Vehicle: 03 GT-T
Well yes, and know. Truth be known, if someone wants into your ride, no alarm is going to keep it from happening. Most of the deterrent is actually from it being noticeably alarmed with LED's etc anyway. The less than professional thief will usually just keep looking for a car without a system, unless of course there's some reason they want yours specifically. If you'd rather just tap your power feed from the ignition harness under the steering column, that's fine. In fact it's where most installers do go anyway because it's faster and cheaper than running 10ga up to the front.
The reason for running power straight from up front is two-fold. 1) Less chance of voltage variations supplied to the alarm module (if the proper gauge wire is used, fused of course). This helps to eliminate a the potential of the alarm not "seeing" what's going on properly, which based entirely on varying voltage signals. 2) When routing the power wire up to the front, it is usually much easier to conceal where it is going to/coming from. This helps with slowing down the would be thief if they decide to just cut power to the alarm system only (also where sirens with back-up batteries come in handy). If you want to completely circumvent the transponder chip key without flashing the ROM to disable it by using the 556U, then here's the best way to go about it: On the 556U there is the three wire harness with the ring; install as per regular instructions. There is also the six pin harness. On this one, connect both the black and the blue wire to ground on the car. Then instead of connecting the red to 12V constant, connect the red wire on the 556U to the ignition wire on the car. What this does is turns on the bypass box coils every time it sees the ignition switch in the car turned on. So basically, if the key cylinder turns, then the cars sees the transponder key that's installed in the box. NOTE: If you do this, DO NOT, EVER, use a chipped key in the ignition to start the vehicle again. The ECU will likely see a transponder conflict (two keys at the same time) and not run for you. Use only the generic or non-coded keys from that point on. |
Suspended Seller
Cocknozzle
Once again, Thanks a bunch!
On the 3 pin harness I just wrap it around ignition? And that's it? So I just found a Relay in the box and connects to a 5 pin harness with 4 wires ( yellow,white,red and violet) I don't see anywhere in the manual about these wires. It looks like for the headlights but just wanna be sure. Can take pics if needed. On the wires that I don't use (I.e. Second starter output, diesel wait to start input,ignition 3 control output, trunk output, etc.) Just leave them alone? |
Suspended Seller
Cocknozzle
I have a few more questions:
1)what is the (brown wire) ACC/Heater (+) output for? do i need it? 2) do i ground all the wires that say ground? i.e. Ground Output while running, Ground Output while armed, Ground output when disarmed 3)I CANNOT FIND THESE WIRES IN THE MANUAL! i never seen them before. i just found them. here are pics: wire colors are white,red,Violet, and Yellow and theres a resistor(?) that goes from Red to White wire. anyone tell what it is for? ![]() Relay plugs into connector. ![]() What relay says on it: ![]() Thanks in advance |
#17 (permalink) |
Moved On
Just look at the post I made in the wiring diagrams thread. It has everything labeled for you. It's DEI's directwire printout for the eclipse. Match wires up. The only thing that goes to chassis ground is the black system main ground. Ground while running etc. you don't need to hook to anything. Unless you have a ground while start that needs to go to the 556u. Not sure if you have a status wire on that or not. Usually a blue wire on DEI systems.
#18 (permalink) |
i used to have a rs-1000. just flip to the middle of the manual that describes what each wire does-- on the 1000, those grounds needed to be connected to activate that specific feature.
as for the relay-- that little black peice is a diode. it will only allow power to flow one way across it. i was hoping someone else would chime in about how to connect it-- it has been a long time since my last alarm install... i believe i used that on remote start portion, and had to buy 2 more for the door locks, but it has been at least 3 years and 2 alarm systems since installing the relays...
The never-ending project, my '01 Spyder GT more projects then time! when 'bright' reverse lights don't cut it exterior led upgrades--75% (led tails, turns, third brake, plate light, reverse light) interior led upgrades--10% (gauges and hvac next, dome light completed) whats next? ford raptor(for the lightbar!!).. |
#19 (permalink) | |
Smart Ass
Sent from my DROIDX
#23 (permalink) | |
"S" Car...Gooooooo
Vehicle: 03 GT-T
As I stated before, the additional relay is for "starter kill". It is ntended to be installed in- line withthe cars starter wire( in ignition harness). This is used to disable the starter circuit if the alarm is triggered, as well as while the vehicle s remote started so that I you turn the key too far for take over, you will not re- engage the starter and grind it. |
#24 (permalink) |
"S" Car...Gooooooo
Vehicle: 03 GT-T
If you want to wire in the relay as for the above purpose, here's how it's done.
Trace the wires to the pins on the relay( because I can't see exactly which ones go where by your picture). Cut starter wire in ignition harness, then : Pin 30 (vertical wire by itself)- starter wire (switch side) Pin 87a (middle wire) - starter wire (car side) Pin 85 - ground when armed (gwa) Pin 86 - ignition |
#25 (permalink) |
"S" Car...Gooooooo
Vehicle: 03 GT-T
Oh yeah I forgot. The diode o. The relay is called a spike suppression diode. It keeps a voyage spike from wrecking things in your car when the relay turns OFF. If hooked up properly, the + side of the circuit is connected the the relay pin which has the little "bar" end of the diode on it, while the - (ground) side of the circuit should be hooked to the relay pin without the "bar".
SO. In the above case, you would hook up ignition to the RED to ignition, WHITE to ground when armed, BLUE to Starter (car side), and YELLOW to Starter (switch side). Keep in mind though, that if you do put this in, which IS a good idea, be sure to hook the "starter output" of the module after this relay. ie switch-relay wires-car side. The easiest way to do this is to splice the "30" pin wire (blue) and the starter output wire together, then connect the resulting single wire to the car. The ground while running is usually used to activate the bypass system being used like your 556U. However as you thought that you might just wire that using the alternate instructions, you don't need it. |
#26 (permalink) |
Smart Ass
It actually all depends what harness that wire is in. If the acc/heat wire is in the primary harness with the ign and 12v wires then yes it goes to the acc wire in the ign harness from the key cylinder
Sent from my DROIDX
#27 (permalink) | |||
Suspended Seller
Cocknozzle
you saved my ass on ACC out wire. thanks.sweet, thanks Quote:
so hook up and solder the 30 pin (Violet) and starter output wire together then connect/Solder them to????(what you mean by car?) so leave the 'Ground while running' alone since i am going to bypass the "key security". |
#34 (permalink) | |
"S" Car...Gooooooo
Vehicle: 03 GT-T
Ok. When you go to hook up the starter wire to the car, cut it. One end of the now cut wire will go to the the ignition switch (switch side), the other cut end will go further into the harness towards the starter relay (car side). Correct, for YOUR application, ignore the ground when running wire. |
#35 (permalink) |
Suspended Seller
Cocknozzle
What yu mean by switch side and car side?
Is it safe to bypass and attach wires that aren't meant to be attactched (I.e.transponder bypass) Like nothing will be affected? |
#37 (permalink) |
Suspended Seller
Cocknozzle
ok thanks and Is it safe to bypass and attach wires that aren't meant to be attactched (I.e.transponder bypass so i only need 1 chipped key)
Like nothing will be affected? and has anyone done this before |
#38 (permalink) | |
Smart Ass
Sent from my DROIDX
#39 (permalink) | |
Suspended Seller
Cocknozzle
what kind of toggle switch would i need? like one of these?: Toggle Switch with On/Off Label Plate - RadioShack.com |
#48 (permalink) |
Smart Ass
on the 556uw, there should be a red, black, blue, green, pink, and I believe a purple wire. You do not use the pink, green, purple. Only the red, black, blue. If you are going to use the switch do the following:
Red to 12v source (thick red wire on the alarm brain) Blue to the pink wire (programable output) on the brain (make sure to program it to sensor by-pass output) Black to ground If you are going to use the switch, attach one half of the switch to the red, the other to the blue. If you are not going to use a switch, then put the blue directly on the red and do not attach it to the pink on the brain.
#51 (permalink) |
Smart Ass
If you read the instructions, the pink, purple, green wires are not used in the installation. Only the Red, black, blue have connections that need to be made.
#52 (permalink) |
Suspended Seller
Cocknozzle
bump...
will this work with the Autopage RS915 Remote start alarm i have? http://www.sonicelectronix.com/item_...Up-Module.html |
#54 (permalink) |
Suspended Seller
Cocknozzle
so it'll work?
sorry it doesn't say 556u or 556uw anywhere?edit: are you thinking that is the Transponder interface module for the remote start? cause that is the Window Roll up Module for when i lock my car, it rolls up the windows Last edited by El Guapo; 07/31/2012 at 04:18 PM. |
