Vehicle: 03 Eclipse GT
4 channel amp and speakers
Im looking to upgrade my factory speakers. As of now i have a kenwood headunit and a kenwood mono amp powering a Type R sub. I gathered from searching that using aftermarket speakers on the stock infinity amp will mostly likely be a downgrade since most speakers are 4 ohm stable, not 2.
So im looking at getting a pair of 6.5 kenwoods up front and a pair of 6x9s. What would be the best way to power the 4 speakers? I was thinking about getting a 4 channel amp but would that mess up the HU since i have a metra wiring kit? What would be the easiest way? |
nope, it wouldn't mess anything up, in fact, you're halfway there by already having a aftermarket deck. just pull a 4ch/2-2ch rca's to the new amp location + power, remote, and ground, and simply ditch the rca cable portion of the mitah adapter.
The never-ending project, my '01 Spyder GT more projects then time! when 'bright' reverse lights don't cut it exterior led upgrades--75% (led tails, turns, third brake, plate light, reverse light) interior led upgrades--10% (gauges and hvac next, dome light completed) whats next? ford raptor(for the lightbar!!).. |
You cryin' boy?
Vehicle: 03' GTS Spyder
Go ahead and run 4 channel RCA's and speaker wire, best to do it all at once than have to go back.
Sent from my iPhone using AutoGuide.com App |
OK so pull the Metra RCA cables and run 4 RCAs from the 4channel amp to the Headunit? I guess since im mounting the 4 channel next to the mono amp, id be able to splice into the mono's remote turn on and use a power and a ground distributor, correct?
#9 (permalink) | |
Shocker Lite
If you experience any dimming (like, headlight dimming when the bass hits) get a big 3 upgrade kit and you will be good to go. No need for a new battery or alternator. |
| Thread Tools | |
