13.9 @ 102 Auto 4 Cylinder - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Driving & Driving Tech Forums > Drag Racing Tech
Old 05/20/2012, 10:24 AM   #1 (permalink)
smed112233's Avatar
Vehicle: 2003 Eclipse RS
smed112233 : who are you?smed112233 : who are you?
I finally did it! I went down to the local track last night to try and beat my previous best time of 14.0 from last year. I finally squeaked out a 13.9 @ 102 mph. I managed a 2.1 60' on my regular old street tires also. I'm pretty sure I am the first auto 4 banger to hit 13's.
For those of you that do not know my car, I have an '03 Eclipse RS auto running an evo 8 16g turbo setup. Boost is set at 18 psi and I am still on the stock motor (block & head) along with a stock automatic transmission. Tuned by 2000rs-turbo.
Night started out great, my first pass of the night I ran a 14.2 @ 103 mph with an awful 2.38 60'. I was eager to race the new 5.0 stang that lined up next to me, needless to say he was a little bit faster. I was happy as 103 was the highest speed I've ever trapped but I wasn't satisfied with the time. I cooled the car off and aired down the front tires to about 25-26 psi. My next pass I hooked a bit better and pulled off a 14.0 @ 102.6 mph with a 2.22 60'. I knew 13's were very possible so I cooled the car off again and dropped pressure down to 23-24 psi and made another attempt. I had been launching on the stall building about 1-3 psi on the two passes. So on my third attempt I made sure to build about 3-4, maybe 5 psi for my launch and managed to cut a 2.11 60' and hit 13.9 @102 mph!
I had reached my goal so I decided I was done beating on the car for the night. The car launched amazingly tho, with my prothane inserts I did not experience any wheel hop once so ever. Unfortunately my laptop had died on the ride down so I have no logs of my runs. I was also running a rom with a little less timing up top then I normally do, but wasn't able to switch at the track. I threw in a couple gallons of 100 octane also to ensure there was no knock at all. Will mid 13's be next? I'm hoping so.
Oh, and this thread is pointless without proof, so here are some time slips
smed112233 is offline   Reply With Quote
Old 05/20/2012, 10:31 AM   #2 (permalink)
what kind of WHP/WTQ are you seeing. I remember Ben smoked 2nd or 3rd gear in his auto around 300 TQ
Old 05/20/2012, 12:55 PM   #3 (permalink)
smed112233's Avatar
Last summer I dyno'd 271 whp and 304 wtq on the VD.
Old 05/20/2012, 12:59 PM   #4 (permalink)
passport applied for
tomsoutdoor's Avatar
Vehicle: 03 spyder gts
tomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by manytomsoutdoor is well-liked by many
And with an auto!! Congratulations..
The Lawnmower Man!!! Need Parts?
tomsoutdoor is offline   Reply With Quote
Old 05/20/2012, 02:35 PM   #5 (permalink)
If you're keeping the auto, I'd really suggest either some work done to it or a bigger fluid cooler. Some more line pressure and less accumulator will do wonders for fluid temps and shift times. The faster it shifts, the less heat on the clutch packs. If you're running an external trans cooler be sure to get a temp switch plumbed in to turn on a fan to draw air past and/or get a manual switch inside so you can cool it down at idle between runs.
Old 05/20/2012, 07:55 PM   #6 (permalink)
2000RS-Turbo : who are you?2000RS-Turbo : who are you?2000RS-Turbo : who are you?2000RS-Turbo : who are you?
Thats a low 13.9 too!! 13.8 would have been the next run! Cant wait to do a few things we were talking about. Whats next, 12's with the auto??? Just have to wait and see.
Records:
Tuned-Fastest 4cyl Auto 3g 13.92s @ 102mph (smed112233)
Email tunes chick here
http://www.club3g.com/forum/rs-gs/14...ail-tunes.html
2000RS-Turbo is offline   Reply With Quote
Old 05/23/2012, 06:02 AM   #7 (permalink)
N my Flippy Floppies
Special_K's Avatar
Vehicle: '01 GT PP / '13 X MR PP
Special_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club exists
Send a message via AIM to Special_K
Looks real legit. I have a how to thread up in the garage section specifically for addition of an external tranny cooler. Pretty simple install and it has helped me run lower temps when autocrossing and/or road racing. Check it out, link below:
HOW TO: Install a Tranny Cooler with Tranny Filter
JIC Muellerized... Secsiness
2001 GT PP A/T 205whp/203wft-lbs Now with 255 goodness
2013 Evo MR PP Stock
Tuned by LogicGate, Sponsored by Tearstone
Special_K is offline   Reply With Quote
Old 06/03/2012, 08:34 PM   #8 (permalink)
smed112233's Avatar
I can definitely see the benefits of running an external trans cooler with something like road racing or autocross, but will it really do all that much drag racing? Yes the trans temps will climb during the run but it is over so quickly, so its not being consistently beaten on and continuously heated up. Some transmission work would be great tho, the stock transmission does shift slowly. However to my knowledge there are no aftermarket shift kits or anything of the sort for this platform? Not that I have seen anyways.
Old 06/17/2012, 09:07 AM   #9 (permalink)
Vehicle: 2003 Eclipse GTS SDS
spec1sef : who are you?spec1sef : who are you?
What kind of tires were you using? I struggled with traction on the track.
spec1sef is offline   Reply With Quote
Old 07/11/2012, 10:18 PM   #10 (permalink)
smed112233's Avatar
I was using a set of dunlop direzza dz 101's. 225/45/17 around 22 psi.
