#121 (permalink) |
Vehicle: 2000 eclipse gt
wow this is a helpful thread and i feel pretty good about the number i put down...did a dynapack back in january
2000 gt aem cai magnaflow c/b bosh plat +4 plugs magnacore wires 3 runs and peeks were 183 hp 5539 rpm and 196 ft/lb at 4370 rpm |
#122 (permalink) |
My snail is bigger!
Vehicle: turbo V6 Galant
2001 V6 Galant
4 speed auto RIPP Stage 3 SDS @ 16 PSI RPW Shorty Headers 2.5" exhaust with Magnaflow HFC and Race Series muffler GTS Plenum 6G74 Throttlebody 301 HP @ 6500 RPM 245 torque @ 6500 RPM These numbers are at 4400' and 88 degrees on a Mustang Dyno without a weather station, so I look the liberty to correct the numbers for altitude and temperature: 364 HP @ 6500 RPM 296 torque @ 6500 RPM
530 WHP Turbo V6 Galant
GT35R | Fully built block | P&P heads | Manual swap |
#126 (permalink) | |
youre numbers are so low because you have an auto.
just another n00b watching n00bs even MORE DUMB than myself blowing their shit up one start up at a time. |
#129 (permalink) |
N my Flippy Floppies
Vehicle: 2001 Eclipse GT PP
2001 GT Sporty
89 degrees Mustang Dyno Stock run: 151whp/153wftlbs Tuned and reflashed: 175whp/177wftlbs Correction to Dynojet numbers (using 12% increase *who cares*) 196whp/198wftlbs Still some more tuning to go. Thanks LogicGate for all the hours spent tuning.
JIC Muellerized... Secsiness 2001 GT PP A/T 205whp/203wft-lbs Tuned by LogicGate, Sponsored by Tearstone |
#130 (permalink) |
Turbo/Haltech V6
Vehicle: 00 Eclipse GT-T
Here is the sheet and a vid from the last time I put my car in the dyno.
2000 GT 5spd Stock intake with cone filter Magnaflow fart can 8.8.1 compression pistons fidanza flywheel ![]() YouTube - Chato's 3G in the dyno
Rudeness is a weak person's imitation of strength. |
#132 (permalink) |
Stage 1 SDS @10 psi!
You just need to tune for the mods you have. The ECUFlash would be prefect. Those numbers are not that bad for a Sporty.
#134 (permalink) |
Appalachian State
I know most people do the ECU reflash after I/H/E, but I only have the intake and exhaust, would I see much of a performance increase from an ECU reflash?
*I really don't want to go through the hassle that comes with headers, that is why I really don't want to purchase them. |
#135 (permalink) |
Vehicle: 2001 Dodge Stratus R/T
I'm somewhat scared to see what mine are. I think what people are going to discover as time goes on is that Megan Racing headers don't really gain that much performance, hence being so cheap. I was stupid and jumped on the bandwagon ASAP and actually ordered a set for my christmas present; Only really noticed a slight throttle response, and not much more.
The tune however, has been the best thing on my sporty over all, Oh and Ashbrooke, aren't SAFCs a dumb idea to have with our cars, because of the fact our ECUs learn their way around everything, including intake/exhaust. just my .02 cents though. |
#137 (permalink) |
Damn right a stock car could benefit from the Flash. As other members have said, the true power is in the Timing maps. You need to know what you are doing, though.
#139 (permalink) |
Vehicle: '00 Eclipse GT
I live in Denver (so I'm at roughly 5300ft elevation). In the next week or so I'll be ordering a Borla cat-back exhaust and RIPP long-tube headers.... so in a '00GT I'd expect to see around 160, MAYBE 170 WHP if I'm really lucky. Would that estimate be at all accurate? The regional threads are a bit slow, and seeing as this is the dyno thread, I figured it's a legitimate question.
#140 (permalink) |
Today I went to Dyno Jet for my Eclipse measure HP...
Here the results Eclipse 2001 GT v6 Intake and Filter kyN Max Power= 150.05 HP Max Torque=165.06 Run Conditions+ 82,74 F Humidity= 26% SAE: 1.14 (I dont know what is this for) I feel the horse power numbers were slow... What do you think about it? I was waitng a least 160 , 165 Or its ok just to have the intake and filter ?? thanks |
#141 (permalink) |
02 GT MT 3.5L
Vehicle: 02 MItsubishi Eclipse GT
I guess I can add mine in here.
02 GT M/T 196.5whp - 223.14wtq 3.5 swap, i/e, AEM alt pulley (doubt that did anything), Quaife LSD (not a power adder, but Ill add it), and ECU flash. Runs 14.5 at the 1/4 mile. Mine is the Titanium one. |
#142 (permalink) |
GS-Turbooo
I'm almost embarrassed to post this, but since my new set-up (2008) is almost done, here goes nothing...
2006-2007 set-up: 2003 GS AT stock motor @ 8psi via 16g with crappy piggy-back tune (never again will I go piggy back...) ![]() ewww... look at that crappy a/f ratio Last edited by CloudINC00; 06/30/2008 at 01:25 AM. |
#143 (permalink) |
Turbo/Haltech V6
2000 GT 5spd Turbo
8.8.1 comp pistons stock heads Haltech E8 EMS crappy 2.5" down pipe 325whp @ 16psi ![]() Here is the vid: http://www.youtube.com/watch?v=YI8XrWmef4U
#144 (permalink) | ||
Just Married 05-15
I am 100x glad you are using Haltech E8 EMS, that baby rocks! Love it and awesome job! |
#147 (permalink) | |
Turbo/Haltech V6
I'm hoping that when I get that 3" down pipe, the car will be close to the 400whp range at the same psi levels with the stock heads. Ones those built heads get fixed, I will finally see the full potential of my set up.
#148 (permalink) | |
Just Married 05-15
I can't wait to see Cloud's results too. Chato how was the knock?? did you get any? What fuel where you using?
#149 (permalink) |
Turbo/Haltech V6
No knock problems at all. The car was tuned using 93 octane pump gas. The guys that tuned my car have their own way to check for knock and they told me that it was a reliable tune. I was told by some experienced tuners that when you have forged internals and a lot of work done to the car, the noise frequencies change and a knock controller won't read accurately anymore.
#150 (permalink) | |
Just Married 05-15
What turbo and trim are you using? If you where willing, check out the MIVEC heads. They will help that turbo and engine breath how it was meant to be from factory. You can then tune the MIVEC with V-Manage or use a stage controller to activate it, but V-Manage is so much better and give you more control. I know $$$ doesn't grow on trees but keep the idea in mind.
#151 (permalink) | |
Turbo/Haltech V6
I'm using the Master Power T04 turbo part # 810007 (turbine A/R .68 Comp. A/R .70) (Compressor Wheel trim .45 and turbine wheel trim .63) I already have built heads with RPW stage 2 turbo cams waiting for new oversized intake valves. I'm not too crazy about the Mivec heads. The only good thing about having Mivec heads is that the idle won't be rough. Also, if I had Mivec heads, the Haltech E8 would be able to manage them too, but I'm sticking to my built SOHC heads for now.
#153 (permalink) |
2002 GT 5-spd
AEM cold air Diamante throttle body(65mm) Diamante intake manifold Megan Racing headers Borla cat-back ECU tune 186whp/190wtq I think it could've been better, but I'm relatively satisfied. Here's the video. YouTube - SoCal3G Dyno Day (18 Oct 2008) - 2k2ocgt |
#154 (permalink) |
Vehicle: mitsubishi eclipse gts
Man, looking at these numbers I am getting scared to dyno my Eclipse. I got a 5spd Gts with Megan headers, Greddy exhaust, "Custom made cold air intake" (lol don't ask). My ass dyno tells me around 200whp but I am afraid that it is horribly wrong. ![]() I'll find out next week and I'll post it up. I am saving up for a Jet Chip
#156 (permalink) |
My snail is bigger!
2001 Galant 6G72 again...
Garrett GT35R, 0.82 A/R hotside Fully built lower end - CP 8.8:1 forged pistons - 3SX forged rods - brand new VR-4 crankshaft, balanced - studs, and some more studs P&P'd heads 3" mandrel-bent exhaust with Magnaflow muffler Lots more... 406 WHP / 374 lb-ft ![]() |
#157 (permalink) |
well, got Lucy dyno'ed the other day. Not too bad considering im STILL rich on WOT. i was only about 12.0 at the leanest on the lower half of the map. was going to 7:1 or so above 5000. Still, she posted 189whp and 201wtq with a fairly flat torque curve. i pulled a crapload of fuel out between each of the 3 pulls and i was STILL rich lol
got more work to do i guess.Im considering taking Lucy back to get tuned there as the tuner HAS worked with Megasquirt before. (slowmotion performance in Columbus) i was also able to lean out the highway cruise and off throttle section so im hoping to bring my MPG up too. the hump in the torque curve makes me wonder though... Mods stock GT motor/heads 5-speed SA-EMS (Megasquirt-II) LC-1 WBo2 headers CAI 2.5" mandrel bent exhaust, HFC, Magnaflow muffler A/C Delete 0w20 AMSOil full synth.
#158 (permalink) |
Were'nt you aware of the richness? Come on mang! Lean her out and put a smile on your face.
I cant even imagine how imperfect your timing map is if you dont have the fuel dialed in yet. Where did you get the timing maps? You could have boatloads of power hiding and you have the power to bring it out, unlike most people here with little control. Too bad that didnt overlay a/f My guess is that the timing map is causing the hump. Thats the kinda power or torque that you could be missing at certain rpms. Maybe you are losing 15-20ft/lbs in the lower rpms. Would take a LOT of dyno time to get that right though ![]() If it knocks, pull timing back at least a couple degrees in that area when street tuning. On turbo/supercharged cars, its probably not intelligent to add timing till your knock sensor picks something up (of course I dont know if yours is usable right now If you figure it out, high five + share with me!)
#159 (permalink) |
i knew about the richness, but i didn't know it was SO rich. i pulled fuel between each pull. The spark map was donated by a member here from a known good running Tuned car (he was turbo, but i only got the N/A section
its better than my poor attempts at tuning so far) A/F was logged by my Megasquirt, as i didn't have the spare $20 for adding the WB on the pulls.ive been meaning to get around to putting knock-sensing in. there is a unit made by a turbo-volvo guy that interfaces well (and has an LED for dash monitoring) but its ~$60 that i dont have. theres a way to get knock control working with just the MS, but i haven't had the time either (school is a priority). heres the datalog i have from the 3rd (and best) pull
#160 (permalink) |
NorCal3G
AzN-SoLjA 04 GTS 5speed- Invidia Exhuast & AEM V2 CAI
Coulda sworn I posted these in this thread but here goes 1st Dyno 191.8whp ![]() 2nd Dyno 2 months later same mods no changes different dyno 196.69whp - 195.23wtq ![]() Proof that these scans are in my possession ![]() Video Last edited by AzN-SoLjA; 12/25/2008 at 06:09 AM. |
#161 (permalink) |
2 Fast 2 Furious
2002 GT 5-spd Stock
175.7whp/174.4wtq This was done on a Dynapack Evolution RHAS-SP v1.0 Best of 3 Runs. @ Slowmotion Motorsports, Columbus, OH Temp: 77.0*F Baro: 29.1 Relative Humidity 43.5 Speed 77.9 97.8 Acording to the Dyno sheet which my scanner is broken I hit max HP at 4426RPM and Max Torq at 5555RPM Last edited by gamereric1; 03/13/2009 at 11:44 PM. |
#162 (permalink) |
Vehicle: 03 eclipse
ive got a 03gs with APC cai, magnaflow catback, and a sporttronic with stage 1 electronic shift kit. i dont have the ability to go to a dyno, does anyone have an estimate of what kind of power i might have. also if you live in oklahoma, do you know where i can go to a dyno. i live in lawton and there aint shit here.
the godfather has spoken |
#163 (permalink) |
2 Fast 2 Furious
You have the ability, its called learn more about your city. I know of 10 places and people here in Columbus, that could dyno your car. You may need to drive 30 minutes, but pulling numbers out of nowhere doesn't help you find out improvement from addon to addon. It really varies. Even from dyno to dyno. But to try and answer you may get from 130-140
#164 (permalink) |
sludging it up
04 stratus r/t 5 speed on dynojet
aem short ram intake stock exhaust with greddy evo muffler 57 degrees F 47% humidity 29.39 in-Hg only 155.94 hp and 169.73 torque. That was a 3rd gear pull from 2500 to redline 4th gear was only 2lbft torque lower i also believe there was too much oil in the car at the time |
#165 (permalink) | |
Mario...............
Vehicle: 2001 spyder gs
if an hour or 2 is too far to drive... what will the price do to you? dynos are not cheap. |
#166 (permalink) |
makin territories
Vehicle: 5spd 6g74 powered galant
lol im sure you all know the mods list.
2000 Galant ES 6g74 swap 11:1 CR CP pistons RPW 264's RPW longtubes Xcessive Manufacturing intake w/90mm TB Greddy TiC exhaust Greddy Emanage Blue *tuned by Warmandscsi* and a few other things....lol 225whp 235wtq on a dynojet dyno 226whp 245wtq on a dynamite dyno
#167 (permalink) |
Drastic Racing
Vehicle: 2003 Evo VIII
2003 Evo VIII
Busher Down Pipe HKS Test Pipe Buddy Club Turbo Back Perrin Intake NOT TUNED Running stock psi 298whp 312wtq Car was Dynoed just before I bought it. After a few mods I'm hoping to hit 400 next summer on a safe tune. I know it's not an Eclipse but it's still a Mitsubishi. |
#168 (permalink) |
Vehicle: 03 eclipse
i now that the nearest one to me is just about 150-200 miles away. driving the speed limit would make that a 2-2.5 hr trip there.
im hoping that when the army moves me in march of next year, there will be a place near me. im trying to go to colorado springs.
#169 (permalink) |
SikStrat-R/T
Vehicle: Stratus R/T coupe
2004 Stratus R/T coupe
Injen CAI Meganracing headers Borla catback exhaust 3.5L swap mani + throttlebody Bosch plat 4 plugs Magstar 8.5 racewires 170 degree thermostat Royal purple oil in everything K&N engine oil filter not tuned not dyno yet i should be around 180 just by looking at everyone elses dyno chart. if anyone lives in jersey and wants to help me tune it ill be more than happy. 1 |
#170 (permalink) |
My snail is bigger!
Hmmph, never updated.
![]() 531 WHP, 551 lb-ft torque, dip at the end was from the ignition cut rev-limiter Mods in link in signature... this was on 20 PSI, 91 octane, no methanol injection, no giggle gas, and most notably stock camshafts Running methanol injection now with 23 PSI. ~580-590 WHP
#172 (permalink) |
Have any of you tried ported cylinder heads. Based on some flow bench testing of the 24v SOHC heads, they respond very well to some porting without increasing the size of the runners. Given that, I would have thought ported heads would be a very popular mod.
#176 (permalink) |
Cocknozzle
Cocknozzle
2000 Fed GT
-9.1 Wiseco pistons -Hardened stock rods -new heads -gts ported upper and lower manifold -Tubonetics T4 @ 7 psi -Turbonetics Evolution Wastegate (recirculated) -Turbonetics Raptor BOV (recirculated) -Precison Front Mount Intercooler Dyno:
#177 (permalink) |
I have the same magnaflow too and love it, you can usually get a used one on ebay or cragislist. I wanted a valid warranty so I got it here. Magnaflow 15964. Also some of the forum sponsors usually have a sale going on. Either way its a great exhaust system, sounds great, and very easy to install.
#178 (permalink) |
01 Eclipse GT
222.4HP@6000RPM and 230.5FT. LBS@3800RPM Mustang Dyno at Lincoln Tech in Mahwah NJ 66 Degrees 28% Humidity K&N Typhoon CAI Custom 2.5" ID Catback w/ Apexi N1 Muffler, precats still on vehicle and testpipe in place of 3rd cat DM firm mounts Ingalls stiffy dampener Clutchmasters lightweight aluminum flywheel Clutchmasters fx300 clutch and tZ pressure plate Nology Wires ZEX spark plugs Zex smart wet nitrous kit (running 50 shot) Next run will include megan headers, no cats, Dynomax bullet muffler for a resonator and existing catback, greddy emanage, RPW cams, Underdrive pulleys, and a ported GTS plenum |
#179 (permalink) |
![]() Join Date: Sep 2003
Vehicle: 00' GT 5 spd
FYI, after switching ECU's and then Flashing, ( very disappointing), I'm now close to 200 HP and 198 Tq..
Don't know what else I can do with staying NA, any ideas would be appreciated!
COLDWELL BANKER RESIDENTIAL BROKER "I'LL ALWAYS HAVE TIME FOR YOUR REFERRALS" 2000 Mitsi. Eclipse GT 5 spd. # 310 TTD |
#180 (permalink) |
pm 4 powder coating
![]() Join Date: Dec 2008
Vehicle: 03 Eclipse V-10 RWD
high comp. pistons, cams, etc.
