MAF Pinout/Testing Procedure - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 10/22/2008, 12:11 PM   #1 (permalink)
Car Audio Mod #3
Circuit's Avatar
Vehicle: 2003 Mazda Protege5
Circuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by allCircuit seems to be well-liked by all
Send a message via AIM to Circuit
Looking for some help from you guys with in depth knowledge of the 3G's MAF (for a V6 if that makes a difference).
I have my MAF left over from my 3G (totaled over a year ago) and intend on using it for an Engineering project.
I need to know what pins go to what on the MAF, and what kind of testing procedures/voltage values I should look for when using it. The MAF will be powered up and hooked up to a data acquisition system, so I need to know which pins are for power/ground/signal etc.
Thanks and +rep to who ever can help!
Circuit is offline   Reply With Quote
Old 10/22/2008, 12:52 PM   #2 (permalink)
Fossilized Member
rc_maniac's Avatar
Vehicle: '03 Eclipse Spyder GTS
rc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regularrc_maniac should be considered a regular
rc_maniac is offline   Reply With Quote
Old 10/22/2008, 01:08 PM   #3 (permalink)
Car Audio Mod #3
Circuit's Avatar
Sweet thanks! That should definitely help! +erep to you!
Old 10/22/2008, 01:41 PM   #4 (permalink)
Car Audio Mod #3
Circuit's Avatar
Also, any way to tell what goes to each pin? Power, ground, etc.?
Old 10/22/2008, 02:38 PM   #5 (permalink)
PharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by allPharmEcis seems to be well-liked by all
Circuit doesn't really know how to read circuit diagrams does he? All the pins are labeled in the diagram above. Study it and you will understand.
PharmEcis is offline   Reply With Quote
Old 10/22/2008, 02:52 PM   #6 (permalink)
Fossilized Member
rc_maniac's Avatar
I guess not.
Old 10/22/2008, 04:46 PM   #7 (permalink)
Car Audio Mod #3
Circuit's Avatar
Didn't look at it hard enough. It's been a long day so far, and I haven't even started class. Thanks guys.
Old 10/22/2008, 07:43 PM   #8 (permalink)
Zero Resistance, LLC
FlashBlueRS's Avatar
Vehicle: 02 DOHC Eclipse RS
That shitty schematic is labeled wrong and doesn't have all the information that you need.
1 5v Input
2 Barometric pressure sensor output signal
3 MAF sensor output
4 BATT +
5 Ground
6 IAT output signal
7 MAF sensor reset signal
Old 10/23/2008, 08:25 AM   #9 (permalink)
Car Audio Mod #3
Circuit's Avatar
1 5v Input
3 MAF sensor output
4 BATT +
5 Ground
6 IAT output signal
Thanks!
Old 02/26/2013, 05:31 PM   #10 (permalink)
Wandered Dude : who are you?
Originally Posted by rc_maniac View Post
I know this post is ancient history but where can I get the rest of the Maf reset signal test procedures?
Wandered Dude is offline   Reply With Quote
