Go Back   Club3G Forums > Performance & Tech Forums > Eclipse Performance
Old 10/26/2006, 03:21 PM   #1 (permalink)
Hirogen's Avatar
Hirogen : who are you?
Journal of 3G Tuning
So I've been working with FlashBlueRS for a few nights and decided to create a blog for my progress. I have a zip at the top of the post with all my logs and ROMS in it so you can see for yourself what is effecting what. I tried to explain in detail the process we used and a glossary of terms is at the top.
ALSO I need a better host, let me know if you can help me out.
You can find the blog here:
http://3gtuning.blogspot.com/
Hirogen is offline   Reply With Quote
Old 10/26/2006, 03:26 PM   #2 (permalink)
GSKNIGHT's Avatar
Vehicle: 02 sherwood green GS
GSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okay
Great stuff! I can see this turning in to a very valuable tool. Keep it coming.
Edit: So 3-4 is a healthy knock count?
GSKNIGHT is offline   Reply With Quote
Old 10/26/2006, 03:30 PM   #3 (permalink)
Hirogen's Avatar
Yeah 3-4 should not be a problem at all, stock under WOT I had 2 tops. According to Flash around 40 you are nearing damage.
Old 10/26/2006, 04:02 PM   #4 (permalink)
Vehicle: '00 Passat 1.8T
01SpyderGT seems to be okay01SpyderGT seems to be okay01SpyderGT seems to be okay01SpyderGT seems to be okay01SpyderGT seems to be okay01SpyderGT seems to be okay01SpyderGT seems to be okay
I appreciate the effort into the blog. Flash def knows his stuff and he obviously cant take the time to help everyone personally. So this helps give some insight. keep it up!!
01SpyderGT is offline   Reply With Quote
Old 10/26/2006, 08:27 PM   #5 (permalink)
SCC-PHOTOGRAPHY.com
HIJACKER's Avatar
Vehicle: 04 NSX, 10 Murano, 08 Alt
HIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends hereHIJACKER has a few friends here
What you did on V1.1 and 1.2 I think is EXACTLY what DNS-EN did with mine when he reflashed it.
HIJACKER is offline   Reply With Quote
Old 10/26/2006, 09:10 PM   #6 (permalink)
TheFranchise's Avatar
Vehicle: 2000 Mitsubishi Eclipse
TheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends hereTheFranchise has a few friends here
10 knock counts might warrent a timing retard; not 3 counts, especially not NA.
TheFranchise
2000 Mitsubishi Eclipse GT
2007 Nissan 350Z Grand Touring
1991 Nissan Sentra SE-R
3G Boosted Since Jan 2003, Beating on the 3G since 2000.
ALL NEW 2007 CLUB3G SCREENSAVER
TheFranchise is offline   Reply With Quote
Old 10/26/2006, 10:28 PM   #7 (permalink)
Ah yes...
Clipse3GT's Avatar
Vehicle: 00 GT RIPP STG.3 & EVO X
Clipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wideClipse3GT is recognized club-wide
Send a message via AIM to Clipse3GT Send a message via MSN to Clipse3GT
Clipse3GT is offline   Reply With Quote
Old 10/27/2006, 10:15 AM   #8 (permalink)
Hollywood
Guest
Posts: n/a
Originally Posted by Hirogen
Observing that log, Flash and I decided to add .02 to all values in the "acceleration enrichment" table. Note: in accordance to the logs, my acceleration put anywhere from 80-95% of load on my engine so the ".02" was added to 80-100 load in ECUFlash.
I'm a little confused about the accel enrichment. You said that you added .02 to 80-100 load in ECUFlash. My accel enrichment table only has 2 columns for data: 1 for RPM's and 1 for the enrichment multiplier. How do you add enrichment to a specific load % ?
Old 10/27/2006, 11:51 AM   #9 (permalink)
Hirogen's Avatar
Good call Hollywood, I fixed that typo thanks. Im always open to suggestions.
Old 10/27/2006, 02:18 PM   #10 (permalink)
Hollywood
Guest
Posts: n/a
Looks good, thanks!
Old 10/27/2006, 02:24 PM   #11 (permalink)
Vehicle: 2002 Galant GTZ
Xrs2 : who are you?
Send a message via AIM to Xrs2
I have some hosting you can use if you want. Just PM me.
Xrs2 is offline   Reply With Quote
Old 11/10/2006, 10:04 AM   #12 (permalink)
GSKNIGHT's Avatar
Hirogen, any updates on your tuning?
Old 11/10/2006, 12:59 PM   #13 (permalink)
Hirogen's Avatar
Funny you should ask GS, I just finished a new post as of 1 minute ago. As always you can find it here at
Logs, ROMS, and Software located at
**Compliments of Xrs2
3gtune.thevod.org
Old 11/11/2006, 06:43 PM   #14 (permalink)
ondarun134's Avatar
Vehicle: 2001 Eclipse Spyder GT
ondarun134 can pretty much be considered an idiot by all
Send a message via AIM to ondarun134
i dunt get it feels like advanced geometry class
ondarun134 is offline   Reply With Quote
Old 11/11/2006, 07:51 PM   #15 (permalink)
Hollywood
Guest
Posts: n/a
You are logging WAY too many parameters. You don't need them all. You're losing bandwidth and you may be missing knock spikes in between counts. Also, you should have done your stock run up to redline, not just 4500.
You should log RPM, TPS, Knock, O2, Timing, and maybe Airflow. Log vehicle speed if you want to use the Dyno feature.
Old 11/14/2006, 01:00 AM   #16 (permalink)
Stage 1 SDS @10 psi!
repforenzo seems to be okayrepforenzo seems to be okayrepforenzo seems to be okayrepforenzo seems to be okayrepforenzo seems to be okayrepforenzo seems to be okay
Nice Job!
repforenzo is offline   Reply With Quote
Old 12/03/2006, 10:10 PM   #17 (permalink)
Just Married 05-15
LogicGate's Avatar
Vehicle: 2001 Eclipse GT Spyder
LogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okay
Send a message via MSN to LogicGate
Has there been any progress here?
LogicGate is offline   Reply With Quote
Old 12/04/2006, 11:34 AM   #18 (permalink)
KD0FIZ
buckethead's Avatar
Vehicle: '01 GS & '95 GS-T
buckethead : who are you?buckethead : who are you?buckethead : who are you?
Send a message via ICQ to buckethead Send a message via AIM to buckethead Send a message via MSN to buckethead Send a message via Yahoo to buckethead Send a message via Skype™ to buckethead
I havn't seen any updates either.
buckethead is offline   Reply With Quote
Old 12/19/2006, 12:42 AM   #19 (permalink)
Hirogen's Avatar
I have a good tune at the moment, but now that finals are over I have a bit more time on my hands to do a little more tuning, hang tight guys. This was originally just to help people get started and just get the hang of what was going on.
Old 12/19/2006, 09:11 AM   #20 (permalink)
SPYDEY MF!
ARACHNO's Avatar
Vehicle: 2007 Mazdaspeed 3 GT
ARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends hereARACHNO has a few friends here
hirogen...everything sounds awesome man. BTW, could you re-upload that old greddy evo2 sound clip video of yours? I searched for it on .org but your server is down.
ARACHNO is offline   Reply With Quote
Page generated in 0.74917197 seconds (100.00% PHP - 0% MySQL) with 11 queries
