need help asp
i just put a turbo on my 2002 eclipse gs i am having a problem with boost ....as soon as i go to lay in to it the wastgate opens and the bov lets out but if i easy in to it i can get about 5 to 10 pounds but slowly then it lets out but i cant get any high rpms it is a t3 t4 can someone please help
#2 (permalink) | |
Turbonetics DSM manifold Turbonetics T3/T4 AAI intercooler & charge piping Greddy Emanage Blue 440cc injectors Pocketlogger and PLX wideband Tsudo 2.5" Catback Hook'em Horns! |
well it seem like i am running rich ......but when i push the car and boost starts to come it just seems like the car wants to die at the same time the wastegate is open. me and two of my friends that are turboed put it on ...i just have not felt any big boost .....and at idle my car ruff it jumps from 1000 to 1500 and keeps bounceing .....anything you can think of any thing i should look at
Check your wastegate actuator. It might not be clamping down good enough and is blowing open under the sudden boost situations. Easing into it might allow it to seal enough so that you build some boost.
What are you using for tuning? Are the plugs the right heat range/gapped properly? Like I said the more details on your setup the better.
#6 (permalink) | |
ASSHOLE!
if so
http://www.myspace.com/mustangfreak1983 |
