Go Back   Club3G Forums > Performance & Tech Forums > Eclipse Performance
Old 05/01/2007, 01:53 AM   #1 (permalink)
awalp's Avatar
Vehicle: Flying Saucer
awalp : who are you?awalp : who are you?
Send a message via AIM to awalp
Wideband and ECU logging
I am logging data with my laptop via Mitsulogger, and ecuEdit (if I could get it to work ), but the logging software has the ability to log with the maps an A/F ratio from a wideband gauge. I ordered the AEM Wideband Gauge before I looked into logging at all. My question is, can the AEM wideband gauge be used to log with a laptop, if not, what would be a better setup to log widebands with mitsulogger or ecuEdit, or any logging tool?
Right now the car is just N/A and I'm trying to learn the software and numbers, but it will be turbo in a few days so tuning is important. What would be the best wideband setup or is there a way I can make the AEM wideband work?
awalp is offline   Reply With Quote
Old 05/01/2007, 02:04 AM   #2 (permalink)
awalp's Avatar
in the listing for the AEM UEGO Wideband is shows, "Serial data stream included for output of AFR (RS 232)", how would I go about using that feature?, I can't seem to find any info on AEM's website or google.
so it seems like it can be done
Old 05/01/2007, 10:19 AM   #3 (permalink)
mumbles the madman
2kgteclass : who are you?2kgteclass : who are you?
the installation instructions for the standalone UEGO guage controller that i bought that turned out to be a dud had instructions for wiring the serial output wire into a 9 pin serial connector that can be cut off of any really old mouse or modem or bought at radio shack.
2kgteclass is offline   Reply With Quote
Old 05/01/2007, 10:20 AM   #4 (permalink)
awalp's Avatar
sweet, if I don't get those instructions you should post them up here!
Old 05/05/2007, 12:39 AM   #5 (permalink)
awalp's Avatar
ahh.. I see, one wire has the serial signal, so I can a DB9 (serial port connection), and hook that one wire up to one of the pins and one pin for ground, simple, sweet
Old 05/20/2007, 01:41 PM   #6 (permalink)
Yes... I`m Polish :)
allias : who are you?
How did you make out with it? I tried to install mine AEM UEGO with DB9 and it doesnt send signal to laptop... any tips?
http://pic18.picturetrail.com/VOL880/3719990/10347435/263723080.jpg00 Sterling Silver GS
allias is offline   Reply With Quote
Old 05/20/2007, 02:24 PM   #7 (permalink)
awalp's Avatar
according to the instructions, pin 2 on the db9 port gets connected to the blue wire for the rx stream, and pin 5 is grounded. using a communication setting at 9600 bps, 8 data bits, no parity, stop bits 1, with hardware flow control (what the instructions say but could be a reason is isn't communicating if these are wrong). Also I'd make sure the com port you select in hyperterminal/ecuedit/mitsulogger whatever you're using for logging, is the one that the cable is connected to.
I haven't had a chance to try logging yet, I haven't gotten the o2 bung welded but logging is the first thing I plan on doing.
Page generated in 0.24579310 seconds (100.00% PHP - 0% MySQL) with 11 queries
