Go Back   Club3G Forums > Performance & Tech Forums > Eclipse Performance
Old 08/13/2007, 11:52 AM   #61 (permalink)
Spooling & Foolin
skinnyGT's Avatar
Vehicle: Turbo GT
skinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regularskinnyGT should be considered a regular
Send a message via AIM to skinnyGT
I'd add to your rep but it wont let me. anyhow great write up. damn my 2000 and the unflashable ecu.
skinnyGT is offline   Reply With Quote
Old 08/13/2007, 06:07 PM   #62 (permalink)
Just Married 05-15
LogicGate's Avatar
Vehicle: 2001 Eclipse GT Spyder
LogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okayLogicGate seems to be okay
Send a message via MSN to LogicGate
Na! don't worry about that, that thing is over rated! I know a couple of people here with rep up the yinyang and they suck Yet I appreciate it
I'm working on the post just need to structure it and put it all together. Is not much I've just been busy
Also check the last post on 1st page about "Injector's Guide" which gives you almost all the calculations except Injector Pulse Width which is also coming up!!! But be very warned! It might be a little math intense!
LogicGate is offline   Reply With Quote
Old 08/13/2007, 07:20 PM   #63 (permalink)
Zero Resistance, LLC
FlashBlueRS's Avatar
Vehicle: 02 DOHC Eclipse RS
I find a lot of people don't realize that tuning can not fix a car in poor mechanical condition. I get countless PM's like "Hey, my car makes a loud knocking sound, can I flash that out?" or "My car keeps stalling, can EcuFlash fix that?"
If you have a stock or mildly modified car and you have running issues and/or check engine lights, EcuFlash is not the answer. In some cases, the problem causing check engine lights and drivability issues can be compensated for by tuning, but it is just a bandaid that covers up the real issue.
A car should be in perfect mechanical condition before tuning. No vacuum/boost leaks, good ignition components, good O2 sensors, etc.
Old 08/14/2007, 09:33 AM   #64 (permalink)
N my Flippy Floppies
Special_K's Avatar
Aqua Slug Champion!
Vehicle: 2001 Eclipse GT PP
Special_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club existsSpecial_K is one of the reasons this club exists
Send a message via AIM to Special_K
Question for the learn'd people with reflashing. When the ECU is reflashed, does it take a period of milage or engine running before the system totally recal's itself? I know for instance when your SES light is on, and you disconnect the battery for a while, it takes a 100 miles or so before the the system comes back to par. Is this the same after a reflash???
JIC Muellerized... Secsiness
2001 GT PP A/T 205whp/203wft-lbs
Tuned by LogicGate, Sponsored by Tearstone
Special_K is offline   Reply With Quote
Old 08/14/2007, 09:41 AM   #65 (permalink)
Just Married 05-15
LogicGate's Avatar
Yes. Here is the information about it.
GENERAL INFORMATION
Computer Relearn Procedures
All Models
* PLEASE READ THIS FIRST *
The following general procedures are to be used if
driveability problems are encountered after power loss or battery has
been disconnected. These procedures may provide an aid in eliminating
these problems.
To reduce the possibility of complaints, after any service
which requires battery power to be disconnected, vehicle should be
road tested.
COMPUTER RELEARN PROCEDURES
Vehicles equipped with engine or transmission computers may
require a relearn procedure after vehicle battery is disconnected.
Many vehicle computers memorize and store vehicle operation patterns
for optimum driveability and performance. When vehicle battery is
disconnected, this memory is lost. The computer will use default data
until new data from each key start is stored. As computer memorizes
vehicle operation for each new key start, driveability is restored.
Vehicle computers may memorize vehicles operation patterns for 40 of
more key starts.
Customers often complain of driveability problems during
relearn stage because vehicle acts differently then before being
serviced. Depending on type and make of vehicle and how it is
equipped, the following complaints (driveability problems) may exist:
* Harsh Or Poor Shift Quality
* Rough Or Unstable Idle
* Hesitation Or Stumble
* Rich Or Lean Running
* Poor Fuel Mileage
These symptoms and complaints should disappear after a number
of drive cycles have been memorized. To reduce the possibility of
complaints, after any service which requires battery power to be
disconnected, vehicle should be road tested. If a specific relearn
procedure is not available, the following procedure may be used:
Automatic Transmission
* Set parking brake, start engine in "P" or "N" position.
Warm-up vehicle to normal operating temperature or until
cooling fan cycles.
* Allow vehicle to idle for one minute in "N" position. Select
"D" and allow engine to idle for one minute.
* Accelerate at normal throttle position (20-50%) until vehicle
shifts into top gear.
* Cruise at light to medium throttle.
* Decelerate to a stop, allowing vehicle to downshift, and use
brakes normally.
* Process may be repeated as necessary.
Manual Transmission
COMPUTER RELEARN PROCEDURES Article Text (p. 2)1997 Mitsubishi Diamante
* Place transmission in Neutral position.
* Ensure emergency brake has been set and all accessories
are turned off.
* Start engine and bring to normal operating temperature.
* Allow vehicle to idle in Neutral for one minute.
* Initial relearn is complete: process will be completed during
normal driving.
Some manufacturers identify a specific relearn procedure
which will help establish suitable driveability during relearn stage.
These procedures are especially important if vehicle is equipped with
and electronically controlled automatic transmission or transaxle.
Always complete procedure before returning vehicle to customer.
Old 08/14/2007, 11:15 AM   #66 (permalink)
A few miles of closed loop driving should be good enough to give the fuel trims time to adjust. The tranny shouldn't have to relearn because you aren't rewriting any of that data. Similar to how it doesn't have to relearn the idle.
Old 08/15/2007, 03:22 PM   #67 (permalink)
qnz
Galant-Turbo
Vehicle: 2003 Galant
qnz : who are you?qnz : who are you?
Send a message via AIM to qnz
what are the vaules you look at Logic when adjusting the baseline tune.
qnz is offline   Reply With Quote
Old 08/15/2007, 03:56 PM   #68 (permalink)
Just Married 05-15
LogicGate's Avatar
I look for irregularities in the stock logs vs tuned log. Also look for things that might need correction and improvement. I look at the logs through Excel by Engine RPM vs Knock Sum/Speed/ etc..
ECULoad
Load Calculated
Knock Sum
Engine RPM
Speed
Coolant Temp
Battery
Timing Advance
Accel. Enrich.
AFR Map
Wideband A/F Ratio
EGRTemp
Fuel Trim Low
Fuel Trim Mid
Fuel Trim High
02 Feedback Trim
Throttle Position
almost all the sensors
Old 08/16/2007, 11:10 AM   #69 (permalink)
Just Married 05-15
LogicGate's Avatar
I want to make sure people read this!! Make sure your car is healthy before even think about tuning your car!! If you are having knock because you flashed your rom, flash back your stock rom and give it some time to relearn and readjust. Monitor your car by logging. If the problem persists then take it to a mechanic or try to find the problem. ECUFlash does not FIX engine problems. What is normal knock you say?? From my experience 1 to 3 knocks is normal. If you are gettings almost 10 knocks find out why and how to fix it. Again ECUFlash will not fix mechanical problems. I'm not posting this because of X person, but its directed towards everyone and anyone interested in tuning their car.
Old 08/16/2007, 11:37 AM   #70 (permalink)
You know, I really think the 4 bangers come stock with a tune that produces upwards of 10 counts. I really wish ecuflash was around when my car was stock. I had already done the head swap by time i started messing with it.
Old 08/16/2007, 03:13 PM   #71 (permalink)
01 Spyder GT Sporty
Jambolito's Avatar
Vehicle: 2001 Spyder GT
Jambolito : who are you?Jambolito : who are you?
Send a message via Yahoo to Jambolito
wink wink, nudge nudge, say no more lol
Jambolito is offline   Reply With Quote
Old 08/16/2007, 09:17 PM   #72 (permalink)
steadly2004's Avatar
Vehicle: Stratus 2.4L
I just wanted to say
"without this thread, I would be lost"
Old 08/16/2007, 10:15 PM   #73 (permalink)
THIS SHOULD BE A STICKY!
Old 08/17/2007, 03:34 PM   #74 (permalink)
Just Married 05-15
LogicGate's Avatar
Guys I have tried to make time for me to finish it but I haven't had the time. There is a number of information that has been requested and provided that I need to check, verify and research. So I'm pushing it for next week to be finished. I apologize and hope everyone is still finding the information here usefull.
Old 08/18/2007, 10:38 PM   #75 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
Vehicle: '04 Lancer Evolution RS
Benz01GS : who are you?Benz01GS : who are you?Benz01GS : who are you?
Send a message via AIM to Benz01GS
:subscribe: awesome info
BUY MY SHIT!!!
"Save your money, and do it right."
Benz01GS is offline   Reply With Quote
Old 08/21/2007, 02:46 PM   #76 (permalink)
Just Married 05-15
LogicGate's Avatar
Post Edited and moved to:
How to: Tune using ECU Flash and other tuning informatoin
Old 08/22/2007, 08:37 AM   #77 (permalink)
Just Married 05-15
LogicGate's Avatar
This thread is linked to the how to so please feel free to post questions and concerns here about tuning and ECU Flash. Also there are other methods of tuning that doesn't require to lean the AFR.
Like Dragon wrote, we can also work on the timing first and then the AFR. Also for the GT/GTS I can provide the Fuel Maps!
Old 08/23/2007, 01:32 PM   #78 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
I'd like to request information about tuning Auto/Sporties for F.I.
Or any help on creating a stand-alone ROM for F.I. Auto/sporty Galants, Eclipses, and Strats... I don't even know where to start, and what processes to follow.
If you have any info, man, it'd be a HUGE help...
BUY MY SHIT!!!
Old 08/23/2007, 04:48 PM   #79 (permalink)
Just Married 05-15
LogicGate's Avatar
This thread discusses the Airtrek rom that was being used to attempt to have an Evo8 rom used on the GS/RS to view boost conditions and other Evo8 features.
Airtrek ROM Thread for FI RS/GS Auto/Sporty Trans
From what I can see you are already familiar with this page but for others that haven't seen the thread follow the link above.
I can think of a couple of things from the top of my head that the ECU Flash would be useful but we need to discuss it first with Piggyback unit users. To be honest I haven't attempted to backward engineer the software/rom because I have to much on my plate. Also I'm sure Flash has attempted it or started but, its not as easy and quick as people might think. I have seen some evo roms disassembled, maybe we can use their research.
We really would need to find a Computer Engineer that is up to the task and challenge.
Old 08/26/2007, 08:43 AM   #80 (permalink)
Just Married 05-15
LogicGate's Avatar
I've gotten a couple of suggestions for improving the How-to that is on the first post. Feel free to PM with suggestions.
Old 08/26/2007, 11:27 AM   #81 (permalink)
Vehicle: 2000 GT-T
Kobalt82 : who are you?
ECU Flash update gives ability to read H8 processors! Read-only but it's a start and now we can at least get our ROM's defined
EcuFlash - OpenECU
2000 Silver GT-T
MyCarSpace
Kobalt82 is offline   Reply With Quote
Old 08/26/2007, 06:57 PM   #82 (permalink)
Just Married 05-15
LogicGate's Avatar
Thanks! also noticed some problems with the old definitions in this release. Make sure you have the 1.29a or 1.30 installation files and a copy of your definitions just in case.
Old 08/26/2007, 09:16 PM   #83 (permalink)
All of the old definitions for pre 1.31 ecuflash will not work without some modifications. You must go into scaling and change all of the "data endian" settings for evo7base. If it is set to "big" you have to change it to "little" and vice versa. After that everything will work properly.
Old 08/27/2007, 01:02 PM   #84 (permalink)
Just Married 05-15
LogicGate's Avatar
Here is the evo7base.xml file with the modifications done to work with the ECUFlash 1.31 which is a really great update.
evo7base.txt
You must change the extension of the file from *.txt to *.xml and save it in this location:
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Instead of overwriting the evo7base.xml with this one, change the extention to *.bup to keep it as a backup.
Edited:
If anyone needs the other evo base xml let me know since I have them all done. Also if there is by any chance some things still not showing right let me know to get them corrected and update the file.
Old 08/27/2007, 02:28 PM   #85 (permalink)
sweet deal Logic, thanks for the updated file!
Old 08/27/2007, 04:39 PM   #86 (permalink)
Not Fast Enough
Doc8224's Avatar
Doc8224 : who are you?
Will I be able to use my rom you are defining for me in 1.31 or will it have to be redefined for it.
Doc8224 is offline   Reply With Quote
Old 08/27/2007, 04:45 PM   #87 (permalink)
Just Married 05-15
LogicGate's Avatar
After you install the new evo7base.xml you'll be able to use ECUFlash and the definitions the same way as the other versions.
Doc8224 I haven't worked your rom, but I will do so now since I have some time. I will email you the definition today.
Edited:
Done, check your email
Old 08/27/2007, 04:48 PM   #88 (permalink)
Not Fast Enough
Doc8224's Avatar
Thanks logic you are a life saver.
Old 08/27/2007, 04:57 PM   #89 (permalink)
Not Fast Enough
Doc8224's Avatar
Also I am having trouble changing it to a .xml file. any help or advice from you guys?
Old 08/27/2007, 05:16 PM   #90 (permalink)
Just Married 05-15
LogicGate's Avatar
First
Install software 1.31
Go to C:\Program Files\OpenECU\EcuFlash\Backup001
Right Click on rommetadata and select Copy
Right Click on the window and click on paste
Overwrite All
Second
Go to C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
There find evo7base.xml
Right Click on it and click on rename
Rename it to "evo7base.bup"
Third
Click the evo7base.txt download
Go to "C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo"
Before you save change the extension from "txt" to "xml"
Then click on save
And your DONE!
Old 08/27/2007, 05:42 PM   #91 (permalink)
Vehicle: 2000 GT-T
Can somebody define this hex for me?
http://travisburks.com/downloads/2000eclipsegtv6.hex
2000 Silver GT-T
MyCarSpace
Old 08/27/2007, 06:12 PM   #92 (permalink)
Just Married 05-15
LogicGate's Avatar
i would love too
Edited:
Is it Auto or Manual?
Old 08/27/2007, 06:29 PM   #93 (permalink)
i would love too
Be careful. I just browsed through the hex code and it doesn't look anything like the 2001+. The Fuel maps jumped right out, but that's about it. It'll take some time to get right.
Old 08/27/2007, 06:58 PM   #94 (permalink)
Just Married 05-15
LogicGate's Avatar
Kobalt just to let you know, It won't take 30min like it is for the 01+ cars. It will probably take weeks.
The code is not the same, I will be watching the progress on the backward engineering of the code.
Old 08/27/2007, 06:59 PM   #95 (permalink)
Just Married 05-15
LogicGate's Avatar
I know I was just posting that to Kobalt lol thnx!
Old 08/27/2007, 07:27 PM   #96 (permalink)
Vehicle: 2000 GT-T
Dammit. Well thanks guys. I really hope you guys can figure it out.
It's a Manual.
2000 Silver GT-T
MyCarSpace
Old 08/27/2007, 08:22 PM   #97 (permalink)
Special_K's Avatar
Aqua Slug Champion!
Dyno Runs to come tomorrow to see exactly how good LogicGate's tunes actually are.
Old 08/27/2007, 09:12 PM   #98 (permalink)
Ooooooo.... he's calling you out.... jk
But I think that the EVO7BASE.XML might have something off with the MAF size, because it reports like double what it did with ECUflash 1.3, I think that maby its just something with the file, but I don't really understand those things.
Old 08/27/2007, 09:22 PM   #99 (permalink)
Special_K's Avatar
Aqua Slug Champion!
I have all the faith in the world that I have picked up a significant amount of power due in thanks to LogicGate. My car is def. still happy with all the tweeking he has done over the past several weeks. Proof will be in the pudding tomorrow evening. *Crosses fingers hoping to be over 200whp/200wftlbs*
Old 08/27/2007, 09:32 PM   #100 (permalink)
Just Married 05-15
LogicGate's Avatar
I wish I could be there to fine tune
Old 08/27/2007, 09:38 PM   #101 (permalink)
Just Married 05-15
LogicGate's Avatar
It might not have taken care of it.....
This one was done by another member in the OpenECU.org site
evo7base.txt I think he got all the settings done. I might have missed a few. Check it out and let me know to otherwise fix it.
Old 08/27/2007, 10:01 PM   #102 (permalink)
I had no luck manually editing the xml files. I could only get it to work when i opened up ecuflash and used the edit feature in the scaling menu.
Old 08/29/2007, 07:06 AM   #103 (permalink)
Just Married 05-15
LogicGate's Avatar
2001 GT Sporty
89 degrees
Mustang Dyno
Stock run:
151whp/153wftlbs
Tuned and reflashed:
175whp/177wftlbs
Correction to Dynojet numbers (using 12% increase *who cares*)
196whp/198wftlbs
Still some more tuning to go. Thanks LogicGate for all the hours spent tuning.
There are the results from clipse_gt dyno. There is around 25whp/wtq increase so far. Currently our problem is getting the AFR right because is running really rich. Like in the How-to, in N/A applications 12.5-12.8 AFR is the goal. Hope this motivates everyone.
Old 08/29/2007, 07:38 AM   #104 (permalink)
Vehicle: 2001 Dodge Stratus R/T
Devin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends hereDevin01RT has a few friends here
Holy S*$%!! That's such an awesome increase, I can't recall all of his mods but that isn't too bad, I'm guessing I/E/H ? Awesome, even with more tuning that is so great... Can't wait to have mine done
Devin01RT is offline   Reply With Quote
Old 08/29/2007, 08:03 AM   #105 (permalink)
Special_K's Avatar
Aqua Slug Champion!
Injen RD CAI
RPW Short Tube Headers
Magnaflow 2.25" Main Cat
Greddy Evo 2 Cat back
Magnecore Wires
Denso Iridium Plugs
Thats about it when it comes to motor mods.
Old 08/29/2007, 08:06 AM   #106 (permalink)
Not bad, not bad at all. 5spd as well? Great numbers, have you had a chance to get on it yet? I'm sure the performance is much more noticeable as well.
Old 08/29/2007, 08:55 AM   #107 (permalink)
Special_K's Avatar
Aqua Slug Champion!
2001 GT Sporty
89 degrees
Mustang Dyno
Stock run:
151whp/153wftlbs
175whp/177wftlbs
196whp/198wftlbs
Injen RD CAI
Magnecore Wires
Denso Iridium Plugs
No its a Sporty. Yes I have gotten on it. Its very noticable over the whole power band. Ill be goin to the track tonight to see how I fair out 1/4 mile time wise.
Old 08/29/2007, 09:29 AM   #108 (permalink)
Aweesome. Definately let us know how you do, I figure a 25whp/tq gain will drop around half a second or so atleast on your overall time..
Old 08/29/2007, 09:38 AM   #109 (permalink)
Special_K's Avatar
Aqua Slug Champion!
We shall see. The good part is I am making peak hp and tq in the lower rpms.
Old 08/29/2007, 04:34 PM   #110 (permalink)
Just Married 05-15
LogicGate's Avatar
Hopefully with all the data gathered in the dyno will be able to increase it even further.
Old 08/29/2007, 05:15 PM   #111 (permalink)
Not Fast Enough
Doc8224's Avatar
Thats great news for me. Since I have the same bolt ons and all the intake and head work done. I know I dropped 3 tenths of my E.T. so far with the head work and tuning. I am still trying to find the sweet spot on the top end but with the adjustable cam gears I am trying to find the best place for the power to be at on these motors so I can fine tune using the ecuflash. Thanks again to logic for all the hard work on this stuff.
Old 08/29/2007, 06:01 PM   #112 (permalink)
Just Married 05-15
LogicGate's Avatar
Nice, sounds like you could make some really great numbers. Hope we can start a N/A battle!
Old 08/30/2007, 07:38 AM   #113 (permalink)
So how'd the track go CLIPSE_GT? I wanna hear the results/comparison numbers
Old 08/30/2007, 10:38 AM   #114 (permalink)
Not Fast Enough
Doc8224's Avatar
Yea I would like to get a nice all motor tune going and dyno it just for bragging rights but I realy need it for the spray. I am hoping to hit at least 250whp on the bottle. I imagine I will be well over that but I like to set low goals. less likely to get depressed when I miss em.
Old 08/30/2007, 01:17 PM   #115 (permalink)
Just Married 05-15
LogicGate's Avatar
I think is a pretty good goal. You've definitely have worked to increase the VE, so I'm sure you can make that an more.
I'm interested too
Old 08/30/2007, 01:27 PM   #116 (permalink)
The suspense is KILLING me!! Just think what you're new motor is going to do Logic, it's gotta be eating you up inside! AHH
Old 08/30/2007, 02:31 PM   #117 (permalink)
Special_K's Avatar
Aqua Slug Champion!
I'm interested too
Not that big of an improvement. It could of been the fact that I had 200 lbs of extra shat sitting in my car last night, or it could of been the fact that it was 90 degrees with 100% humidity.
I ran a 16.2 with a 2.433 60'
Stock I ran a 16.5 with a 2.6 60'
So I guess I did pick up 3 tenths of a second and 2 tenths on my 60' but I believe its just a driver error. The car has way more, I just need to learn to launch better. Still none the less, The dyno sheets dont lie, and I def picked up 25whp and 25wftlbs. Al and I will def work towards the 30whp mark now and maybe beyond.
Old 08/30/2007, 02:42 PM   #118 (permalink)
This heat is really throwing off numbers around the nation, just wait a month or two for it to really cool off and see what it can really do ..
Oh, and you have a sporty which never is any fair Get a high stall converter... They take off about 1/2 1/4 mile second on most guys applications.
Old 08/30/2007, 04:27 PM   #119 (permalink)
Just Married 05-15
LogicGate's Avatar
Humm... I'm sure it can be alot better. I was just in the highway when an RSX-S wanted to run over me. I never race, but I wanted to see what was the difference. The car held with him just fine (that means that we stood side by side) which impressed me.
We really need an aftermarket trans cooler. My trans oil is getting to hot, specially in this heat wave and humidity here in Florida.
Edited: About the those 5hp.... I have that nailed, we just need to get the AFR running where we want them to be and its "done". Also I don't care what people say, but 200lbs is 200lbs, I'm sure that affected. I have seen Evo8 and 9 run like crap because they are full of people. My car runs like crap too if there is to much weight in it.
Old 08/30/2007, 05:13 PM   #120 (permalink)
Not Fast Enough
Doc8224's Avatar
That is not bad. take into account that the faster you get in the quarter the harder it will be to get faster (if that makes sense...) What I mean is 25whp got you three tenths in the quarter in the 16sec range, 25whp for me in the 13 sec range will shave less time off. you are working with the right people for tuning that thing but If you get serious about more power, focus on the airflow into the motor, i.e head work, manifold porting or swapping. That is where I have seen the biggest gains. keep working on it, am glad to see a lot of people on here are not afraid to go to the dyno's AND beat it up a little on the strip.
Page generated in 0.88944006 seconds (100.00% PHP - 0% MySQL) with 12 queries
