#481 (permalink) |
Legendary Member
They do. The 'Rom Info' tab looks fine as well (besides the fact flash method: mitsukernelocp).
On this page: ECUFlash Definition Files and ROMS mitsubishi roms can be downloaded. An 03 Gt Auto rom is on that list as well, but the Memory Model for that ROM is SH7055. I would hate to try flashing over this ROM (after adjusting immobilizer) and if successful have a car not run with the different memory model.
http://www.club3g.com/forum/members-...-03-3g-gt.html |
#482 (permalink) |
i see in the forum here that the right cab for my 2001 eclips gt would be
Open Port 1.3M right because i was told 2.0 as well but it says evos and i am confused now if some one can give a hint what are the differences in Limitless Designs - OpenPort 1.3R Universal USB Cable Datalogging and EcuFlash Reprogramming Cable. and that Limitless Designs - OpenPort 1.3U Universal USB Cable Datalogging and EcuFlash Reprogramming Cable. thank you every one |
#483 (permalink) | |
Rotary fanatic
Vehicle: 2001 Dodge Stratus
Make sure you get it with the reflash cable for Mitsu.
01 Stratus R/T: 5spd, 6g74 swap, N2o 75hp |
#488 (permalink) |
Head Swap Baby!!!
I have a quick question for the guys who have been tuning for a while. I've been working on my tune for a couple days now and Ive noticed that my knock is very inconsistant. I mean I will have a readings at exactly the same load and rpm and I will be getting mostly 0 knock but have a few that are like 4 to 6 counts. Should I worry about these odd knocks or just ignore them? Also why doesn't knock in the 100+ load range show up in the maptracer (i know its there cause i see it in the graphs).
#491 (permalink) |
Legendary Member
Let me guess. You can pull the ROM, but when attempting to flash you get "no kernel available for SH7052"?
#492 (permalink) |
Not quite, the definition file simply does not show up in ECUFlash when pulling the rom. I have tried different versions of ECUFlash, redownloaded the definition files folders from here and 80940004 simply doesnt work.
Again, any help would be appreciated. |
#493 (permalink) |
Legendary Member
I am using v1.42 on Vista.
This is where my definition files are placed. Program Files (x86)->OpenECU->EcuFlash->rommetadata->mitsubishi->eclipse->xml files.
#497 (permalink) |
COULD ANY ONE HELP UNDERSTAND HOW TO TUNE ECU
HAVE TAXTRIX 2.0 I HAVE READ OUT MY ECU WITH NO PROBLEM I HAVE DATA LOG MY CAR PERFORMANCE WITH EVROSCAN 2.6 COULD ANY ONE HELP HOW TO TUNE IT OUT ONE I DATA LOG IT I ORTHER TO DO THE CHANGES TO THE ECU THANKS I ARUNNING TO REACH I COULD SEND THE DATA LOG AT LEAST TO TELL ME WHAT IS GOING ON WITH THE CCAR THATS AGIAN
#500 (permalink) |
Vehicle: 2000 Eclipse GT 6G74
Where can I buy an openport 2 cable? Anyone know? Tactrix says it is sold out and I haven't been able to get ahold of them via phone/email.
2000 Eclipse GT |
