Go Back   Club3G Forums > General Chat Forums > Gaming and IT Discussion
Old 07/04/2009, 10:25 AM   #1 (permalink)
Shogun Master
General Klinger's Avatar
Vehicle: 09 CX-7 + 2010 Corolla S
General Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wideGeneral Klinger is recognized club-wide
Network Problem
Okay guys, I am officially stumped on this and need some help.
I am currently running my Motorola Cable Modem through a Linksys wireless router and then into my Dell XPS Studio desktop. I randomely drop my connection and it's becoming really annoying.
I had Comcast come out, but they said that there weren't any problems with my line. I upgraded the firmware on my router and checked to make sure the firmware on the cable modem are up to date. I changed out my network cable from my router to desktop and still seem to be having issues.
I formatted back to XP Pro because I thought maybe Vista 64bit was causing an issue, but since I had the latest drivers installed for my onboard intel gigabit lan with both systems, I am still having issues.
My desktop is only a few months old. Should I hit up Bestbuy and get a new network card and see if that fixes it? It's the last option I can think of before sending this back to Dell for repairs. Anyone else got ideas?
"kabob, doing your thinking for you, 'cause you can't do it as good as him, since 2001 "
General Klinger is offline   Reply With Quote
Old 07/04/2009, 10:35 AM   #2 (permalink)
Proud :2003:
GTSGUY2003's Avatar
Vehicle: 03 GTS
GTSGUY2003 : who are you?GTSGUY2003 : who are you?GTSGUY2003 : who are you?GTSGUY2003 : who are you?GTSGUY2003 : who are you?
I suggest you bypass the router for now and watch to see if your connection continues to drop. I've replaced several bad linksys routers at work over the last couple years with the same symptoms.
GTSGUY2003 is offline   Reply With Quote
Old 07/04/2009, 10:49 AM   #3 (permalink)
Shogun Master
Well I forgot to add that my wife connects with her laptop all the time without issues. I don't seem to have any connection issues with my iPod touch so I was thinking it wasn't the router
Old 07/04/2009, 10:55 AM   #4 (permalink)
zy
primula's Avatar
Vehicle: 2001 Eclipse RS
primula seems to be okayprimula seems to be okayprimula seems to be okayprimula seems to be okayprimula seems to be okayprimula seems to be okay
linksys routers have tendency to drop the internet connection.
flash it with DD-WRT helps a little.
if you are using BT, port forward it.
disable uPNP on the router & BT.
primula is offline   Reply With Quote
Old 07/04/2009, 11:17 AM   #5 (permalink)
Proud :2003:
GTSGUY2003's Avatar
Vehicle: 03 GTS
Is your wife's laptop wireless? (I know your ipod touch is). If that were the case, you wouldn't rule out the router necessarily, because the issue may be with the physical ethernet ports on the router. It could also be a hidden advanced configuration item on your LAN card (QOS Settings, etc) that's causing the issue.
Old 07/04/2009, 11:21 AM   #6 (permalink)
sunnyD's Avatar
Vehicle: 2003 Eclipse GT
sunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regularsunnyD should be considered a regular
If that's the case, it can't be the modem or router. I would suggest another NIC.
sunnyD is offline   Reply With Quote
Old 07/04/2009, 11:32 AM   #7 (permalink)
sunnyD's Avatar
I would assume if he's having problems wired, he would tried his wife's laptop with the wire as well.
Old 07/04/2009, 11:37 AM   #8 (permalink)
Shogun Master
You assumed wrong Didn't even think of doing that since her laptop works fine on the wireless end.
I am gonna flash to DD-WRT and then try to see if hers will stay connected with a wired connection. If so, then must be something with mine. If not, then I can replace the router. Funny part, this is the 2nd router from Linksys. My first one they replaced because when I was renting a house, the house line was hit by lightning and fried the router. They decided to replace free
Old 07/04/2009, 12:00 PM   #9 (permalink)
Pro-Zerk '09
morbidjester's Avatar
morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!morbidjester Is Mighty Gay!
If you are having problems with your connection dropping or losing data packets 90% of the time it is a router problem.
Ts'i mahnu uterna ot twan ot geifur hingts uto.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Eleanor Roosevelt
morbidjester is online now   Reply With Quote
Old 07/04/2009, 12:06 PM   #10 (permalink)
zy
primula's Avatar
i missed this post.
hmm. if its LAN. it could be the LAN cable itself too.
Old 07/04/2009, 12:46 PM   #11 (permalink)
Shogun Master
Originally Posted by primula View Post
i missed this post.
Tried that
I am gonna reformat back to Vista 64bit, then flash the router
Old 07/04/2009, 06:30 PM   #12 (permalink)
zy
primula's Avatar
like sunnyD said, it could be your NIC as well.
did this just started happening, or have been going on all the while?
Old 07/04/2009, 08:40 PM   #13 (permalink)
Shogun Master
For awhile now. Almost a month
Old 07/14/2009, 07:16 PM   #14 (permalink)
stb05gs's Avatar
Vehicle: 2005 eclipse gs
stb05gs : who are you?stb05gs : who are you?stb05gs : who are you?
Before you waste your money on another NIC... If not already done so check on the back of your system. If you have two lights ( one blinking green and one steady amber colored light) your NIC isn't bad. That is if you are using a regular CAT5 ethernet cable. If it is fiber connector cables there should be two green lights. If you have no lights try a physical connection with the same cable on another system in the house. That should determine if you need a new cable or NIC. Any questions just pm me. I troubleshoot computers 11 hours out of the day.
stb05gs is offline   Reply With Quote
Old 07/14/2009, 09:20 PM   #15 (permalink)
Zedicus's Avatar
Vehicle: Mitsubishi Montero
Zedicus : who are you?Zedicus : who are you?Zedicus : who are you?
bullpoop, ive seen network cards with all the lights on and no one home. ive seen network cards with all the lights looking like they were working and the card dropping 90% of packets it got. if the same computer is doing the same thing across 2 OS's AND other computers on the network all work fine your problem is narrowed down to the physical router, the cable, the computers nic. if possible try changing the port you are plugged into on the router, if YOUR comp still acts funny and youve changed the cable. my bet is the nic.
Zedicus is offline   Reply With Quote
Page generated in 1.43445706 seconds (100.00% PHP - 0% MySQL) with 11 queries
