I
![]() ![]() WangsJoin Date: Dec 2001
Vehicle: duh
32 bit XP/Vista and RAM
I have a question. I know the 32Bit OS can't see the full 4Gb of RAM but has anyone ever put that much (or anything over 2Gb) and see how much it actually sees? I'm thinking of adding more to my laptop which is at 2Gb now but if it will only see 2.5 I'll buy a 1Gb chip. if it will see upwards of 3Gb or even use more than that in the background somehow I'll spend the extra $40 for another 2Gb chip.
Advertisement |
Future M.D.
As far as I know, XP could see a full 4gb setup, but that was the max. Vista on the other hand can see much more than that, I'm just not sure how much more.
"This is the land in which we killed Kennedy but let Bush live. For that alone we deserve to burn." |
#6 (permalink) | |
I
Vehicle: duh
4GB vs. 2GB memory upgrade - Windows Vista Forums so I'm not sure wtf reality is. that's why I wanted to see if there was someone here that actually did it. |
I
Vehicle: duh
ok here is what i've found so far on the vista forums.
vista 32bit will go up to 4Gb with something called a 3Gb switch (which I still can't figure out how to do this) but because of hardware and MB configs you might only see from 2.75Gb up to 3.5Gb. the reason is the rest is being used by hardware. Vista 64 home will see up to 16Gb Vista business and Ultimate 64 will see up to 128Gb. |
Vehicle: 2010 Lancer ES
"Tell my tale to those who ask... tell it truthfully, the evil deeds along with the good, and let me be judged accordingly. The rest... is silence..." |
#11 (permalink) | ||
I
Vehicle: duh
#13 (permalink) | |
I
Vehicle: duh
greg you rock.
I got one ? thought. at the end it says this. Quote:
#14 (permalink) | |
As far as I know, every Vista user with 4GB of RAM had to do this. Doesn't seem like a difficult process anyways.
I
Vehicle: duh
no, it seems easy. just weird the way some of it is worded. like the title even implies that you don't need to do it unless you want over 3.5Gb.
I think I'll go order some more from newegg now and give it a try. |
On a somewhat related news, my campus just began distributing Vista and Office 2007. I just walked into IT Help Central today and told them I quit.
#19 (permalink) |
"I dunno" guy
Vehicle: 2009 BMW 328i Coupe
If you have either 64 bit processor (A64 or EM64) PAE is enabled by default and will allow addressing 4GB of memory address space (notice I didn't say RAM, just memory address space). If you don't have it, you have to force enable PAE and that execute protection feature thingamy to enable 4GB memory address space.
Now that's out of the way - XP SP2 onwards, no matter what you do, you only see 2GB of available RAM to your applications. That's MSFT's doing, they hard coded the kernel to do that so that users won't run into issues with badly written drivers. PAE enabled systems requires double pointers (or was it double address jumps, I can't remember for sure) to do DMA, but a lot of driver writers cheat and just assumes no one has more than 2GB of RAM and that all the addresses are strictly <2GB. Vista32 Since the new Vista drivers have to be written from scratch and MSFT actually forces checks on the above issue, they allow more addressable RAM. However, the amount of RAM you will see is affected by how much other types of addressable memory you have in your system. Typical rule of thumb is Total system RAM - total video RAM - PCI address space overhead = Total addressable RAM. So say you have 4GB and you have 2 8800GTX with 768MB each, you will only ever see a MAX of 2.5GB (1.5GB of total video RAM). Sucky eh? On my system with 4GB of system RAM, I see 2GB in XP and 3.4GB in Vista32.
My Blog Last edited by scoliosis; 07/18/2007 at 09:52 AM. |
#21 (permalink) |
&quot;I dunno&quot; guy
Umm... What does it use to display then? If it's one of those onboard Intel GMA stuff, then sure, it doesn't take up the memory address, but it eats up real RAM instead
My Blog |
#22 (permalink) | |
#24 (permalink) |
Do you see it in the Physical Memory part? - Where are we going, and what's with the handbasket? : Who ate my memory?
If you follow the TechNet article into the driver compatibility section, you'll see this paragraph "To constrain compatibility issues, Windows XP Service Pack 2 includes hardware abstraction layer (HAL) changes that mimic the 32-bit HAL DMA behavior. The altered HAL grants unlimited map registers when the system is running in PAE mode. In addition, the kernel memory manager ignores any physical address above 4 GB. Any system RAM beyond the 4 GB barrier would be made unaddressable by Windows and be unusable in the system. By limiting the address space to 4 GB, devices with 32-bit DMA bus master capability will not see a transaction with an address above the 4 GB barrier. Because these changes remove the need to double-buffer the transactions, they avoid a class of bugs in some drivers related to proper implementation of double buffering support."
My Blog Last edited by scoliosis; 07/19/2007 at 06:45 AM. |
#28 (permalink) |
Up to 3.25GB in most cases.
