Kampfbereit
6G72 Turbo Kit Information
I've been working on this on and off for the past month, I basically wanted to get all the information we've learned into one place that we can refer back to when people ask. If there is anything I should add, take out or correct I am all ears.
Thank you Chato, Randy, Mike for the pics, I've just been collecting them over the years. Tearstone Performance - 2000-2005 Mitsubishi Eclipse Turbo Kit
Russ Sanderlin Eclipse Tech - Club, Association, Event and Custom Decals Liberty Maxim - Turbo Magazine Feature |
Vehicle: Boosted 6g75
Thanks Russ. I've been doing some searching of my own lately as well, and this sums a good portion of it up!
EcuFlash Tuning or Mechanical (South Eastern States) Services, CONTACT US HERE. |
Kampfbereit
If there is anything else I should add, please let me know. The way my brain stores information, sometimes I overlook the most obvious or trivial things people might have questions about.
Turbo/Haltech V6
Vehicle: 00 Eclipse GT-T
Nice document Russ! A couple of things I'd like to add is that if people decide to use that Master Power turbocharger, they will need to get a 3" V-band flange and weld it to the 2.5" down pipe. The turbine outlet for that turbo is 3". Also, a 4" to 3" reducer 90 degree coupler will be needed to connet the intake pipe to the compressor.
Rudeness is a weak person's imitation of strength. |
#9 (permalink) | |
Kampfbereit
#11 (permalink) | |
My snail is bigger!
Vehicle: turbo V6 Galant
Good write-up but:
530 WHP Turbo '01 V6 Galant - GT35R | Fully built block | P&P heads | Manual swap
450+ WHP '08 Evo X - full exhaust | 57 # BB-X turbo | meth injection | self-tuned '10 370Z - stockity stock |
Kampfbereit
Oh sweet. I'll update then.
My snail is bigger!
was just giving you shit. I'm catching up right now because I haven't been on Club3G in a few months.
Faster piggy,FASTER!
Vehicle: '03 Galant ES V6 Turbo
those are my pipes - you can delete the one with red lettering, as it is the same as the one with yellow lettering, only without the bags ![]() Also, for the yellow lettering: A Cold Side, connects to MAS, BOV Recirc, and Turbo inlet B Cold Side connects to B and turbo outlet C Cold Side, connects to H and intercooler D Cold Side, BOV Flange, connects to intercooler E Wastegate Recirc F Exhaust Coupler G Cold Side, connects to H H Cold Side, goes behind intercooler/bumper support Not pictured is the long pipe that goes from the intercooler to the throttle body Last edited by WanderingPinoy; 05/14/2009 at 05:28 PM. |
#17 (permalink) |
Kampfbereit
Very good suggestion! I'll do that.
#18 (permalink) | |
Kampfbereit
#19 (permalink) |
Turbo/Haltech V6
Hey Russ, here is some more info about this Master Power turbo. Here is the Comp. map.
![]() As you can see, this turbo's max flow is around 40 lb/min.
#20 (permalink) |
Turbo/Haltech V6
Wouldn't a turbo that flows 40 lb/min max will max out around 400hp? Please correct me if I'm wrong.
#23 (permalink) |
kietzmann
how much would the kit cost?
1st: 2000 mitsubishi mirage=tottaled 2nd: 2001 eclipse gt-14.8 1/4-sold 3rd:1997 cobra svt-13.1 1/4-sold 4th:1992 3000gt vr4-11.4 1/4 @129-1.8 60ft-450hp-sold 5th; 1998 240 sx s14-13.2 @110-sold 6th-1995 5.0 mustang gts-procharged-14psi-10.7 1/4 at 139mph-sold 7th-1996 subaru svx-loud ass kicker system-junked=( 8th; 2004 eclipse gts-all stock for now=) |
#24 (permalink) |
Zed oh six
Vehicle: 2002 Corvette Z06
There isn't a kit being developed. Knowledge from years of piecing kits together is being combined so people can adequately make their own kits.
The cost is up to you and the money it takes for you to make it happen. |
#25 (permalink) |
There actually is a kit available. I just don't stock it and it's built to order. It's not cheap to make so I'm not going to have money just sitting on shelves.
If you are serious about boosting your 3G w/ a turbo, you should be contacting me. Of course, please only do so if you realize what it's going to take (ie don't expect it to be cheap). |
#26 (permalink) | |
Kampfbereit
#27 (permalink) | |
Stage 1 SDS @10 psi!
Dude!
Didn't you read the first few lines of the link?Quote:
#28 (permalink) | |
#30 (permalink) |
If you want the trans to last while you are throwing more heat and power at it, you'll add the cooler. It is like a clutch upgrade is a "must" for the manual cars. The stock clutch my work for a while, but eventually the clutch slips and wears out.
#31 (permalink) |
Kampfbereit
Yes it's true. You use it in addition to your stock tranny cooler. No the stock tranny won't blow at the signs of boost, but it's the temperature of the transmission fluid which will bring it to it's knees.
#36 (permalink) |
Good write up Russ. I see a few pics of my old car in there. I actually miss it some especially right now since the Evo is on jack stands while I finish an install on it. This is the worst timing for a business trip to San Diego or I'd have it done tonight.
#37 (permalink) | |
#38 (permalink) |
Vehicle: 2004 Mits Eclipse GTS
anyone know a very rough estimate for the pricing for all the parts required to put this turbo kit together? not including labor or anything just purely price of parts.
#39 (permalink) |
Kampfbereit
You could potentially do it for much cheaper, but to be safe, I say budget $5K for just the turbo kit. Budget $10K if you want to do it right with the engine and drive train upgrades.
#40 (permalink) |
Vehicle: 2001 Spyder GT
really nice thread so much info its a little overwhelming but anyway down the road i am considering putting a turbo on my car.i am a little worried about mine being an auto the trans was rebuilt less than 5000 ago i know i would have too add a trans cooler.but it is my DD so i still want it too be reliable.nice thread thanks for all the great info
#45 (permalink) |
Vehicle: Evo X GSR
Thanks for putting in the time to get the information together for us! It definitely gets rid of a lot of questions.
Evo X GSR aquired. Now for the long road to the 3G GT Sleeping giant. |
#46 (permalink) | |
