#61 (permalink) |
Damn I look good
Vehicle: 07' GT Spyder 6spd mt
What turbo would you need to do that with. One thing thats been holding me up on just going ahead and bossting my car is the install time. But if what they claim is true, 8 or soo hours doesnt seem soo bad. I'm sure someone could built their own kit cheaper though.
Last time I checked, no one gave a damn. |
Advertisement |
#62 (permalink) | |
Stage 1 SDS @10 psi!
Personally, I can understand not wanting to have long down-time, but if you are going to FI a car not designed for it, then things need be be checked over and over. |
#64 (permalink) |
pro auto detailer
you idiots are missing out on how i never said anything about the 6cyl. you just presume that my commentary is aimed your way just cuz this thread is in the 6cyl section. now are you guys done yet? jesus you guys can be lame sometimes.
concerning the filter, yeah thats the problem. and you can do this or that to make sure moisture/suspension travel isnt a problem but would that be trading one problem for another? in a normal turbo kit, you dont have to worry about those things =D i dunno, something tells me only in specific cases/for certain cars would this really be the way to go. its like i said earlier, most of the money for half the hardware. what theyre really selling, imho, is the concept of convenience. no turbo kit for yer car? no problemo! install our leet STS kit.. it lets you use the turbo for a muffler!#$
The Phalse Chronicles: detailing tips, tricks, and how-to's http://www.club3g.com/forum/show-shine/74660-answers-common-myths-long-post.html |
#65 (permalink) | |
Turbo Buick > you
#67 (permalink) |
Kampfbereit
Please cease flaming in this forum, leave it to OT. Anymore posts like this from you will simply be deleted.
Russ Sanderlin - Twitter - Facebook - Blog Mitsubishi Eclipse - Generation Gap Eclipse Tech - 2012+ Eclipse - 2006-2011 Eclipse Forums - Mitsubishi Mid Atlantic - Mitsubishi Florida |
#68 (permalink) |
The one thing that is intriguing me about this system, that no one has mentioned, is that it would be the ideal setup for Super and Turbo charging at the same time.
With my SDS setup, adding the STS would not be that difficult. |
#70 (permalink) | |
#71 (permalink) |
Damn I look good
It seems to be an all around cheaper method of boosting once you have a engine that will handle it. Even with the cost of the piping I'm sure it would in way cost more than buying an intercooler and turbo manifold. Maybe I'm wrong or missing something but it appears that all you need is a turbo that would work with a setup like that, pump for the oil or I believe someone else said that there is a turbo that doesnt require that since you can just lube it yourself when needed, piping to your intake, plus all your other standard turbo acc. like gauges and enginge management.
I'd love to try it out on my car. I might read a little bit more into it. See if I can built my own kit. I'd be happy with just 5psi.
#72 (permalink) |
Your Reality Check
As stated before....
It is a great set up and there is little to NO different in Lag compaired to the engine mount location everyone is custom to. The one question that I have had about the set up, that I have never have been able to get an answer for. How does it hold up in a rain storm or wet condition? When the water hits the housing, you would think it would crack or shatter due to how hot it is compaired to the cold of the water....
#75 (permalink) |
#76 (permalink) |
Your Reality Check
I can hook you up with the gentleman who has the kit on his WS6 Trans Am, he runs AutoX in my region. We had a nice long chat while in the grid about his kit and how there doesn't seem to be any difference. You could also tell by watching him run that day. Very impressive!
Dont test me, I know what I am talking about!
#77 (permalink) |
Do you really?
#78 (permalink) | |
For that reasoning, it would only be common sense based on the distance between the turbo and the TB, the routing of the piping, there's got to be some drop in efficiency. How much is the question... |
#79 (permalink) |
Your Reality Check
I have the skillz! ![]() As far as the piping, I'm not sure, I could talk with him and see what he has his looking like. Maybe get him to snap some photos and such. When we were chatting, I tried to look under for a better look, but want unsuccessful due the the fact that the car was on the ground!
#80 (permalink) |
have any of you even bothered to read squires website?
yes, length of pipe matters im sure...but they have kits ranging from hummers, to corvettes, to MOTORCYCLES. this isnt some hacked up, backyard job...they have PROVEN numbers; just, its on CERTAIN vehicles. |
#82 (permalink) | |
That is fine, but those kits are offered with piping included. So, there will be some consistent hp numbers there... The only offering for the 3g is the universal kit without piping. The way you route the piping can effect performance. That would be my concern. |
#85 (permalink) |
imo, i think if the piping is put up with the least amount of travel, then you would have hot air, right. so the more piping the cooler the temp. remember this is just a thought and has no real numbers to back it up. just thinking that if the air has more distants to go then it would cool it down.
#86 (permalink) | |
I'm not slamming the product, but I think some reality has to be considered. I think it would be difficult to spin the turbo past 25 psi with the turbo that far back. |
#87 (permalink) |
Kampfbereit
I don't think the STS is a product, STS sells an idea.
#88 (permalink) |
Phil is on the money.
#90 (permalink) |
They actually sell for kits for specific vehicles... like the C5, mustang, etc. And then they offer the universal kit, sans piping.
It may not be a bad low boost option... Last edited by repforenzo; 11/21/2006 at 03:49 PM. |
#91 (permalink) |
as far as placement of the turbo read page 202 in maximum boost the last paragraph. And if your worried about lag (guys with front mount turbo 3g's)take a string and measure the distance from the turbo down the piping to the intercooler and back to the throttle body. I bet its only ablut 1-2 feet shorter then it would be from the muffler back up the exhuast between the engine and firewall to the throttle body plus you lose 1-3 psi with an intercooler depending on its size.
02 Sporty GT,Premium, Titanium Pearl CAI, Tsudo Cat Back, Anzo Halo Projectors, Black Altezza Tails, Clear Front Corners, HKS Grounding Kit, ECU Reflash, Greddy Turbo Timer, 18" nexxo m20's(gunmetal), KYB AGX, Tein H-Techs, StopTech stage 2 brake rotor upgrade, Carbon Falcon Wing, carbon APR canards, rear strut tower bar, optix blue led accents |
#92 (permalink) |
Damn I look good
Sunday they put that kit on a Vette on the show on Spike, I think it's called Powerblock or something. Went from 345whp to 535whp with 6psi but that a twin turbo setup, which could probably be possible on a few of the 3gs that have had dual exhaust put on them. But thats if it will be able to spool bothe those turbos. They also made a comment at the end about turbo lag, and the guy just said "What lag" then took off.
#93 (permalink) | |
I think too much
On the show, they made the charge pipes go up over the fender wells and through the side skirts up to the front fender wells and the into the engine bay. |
#95 (permalink) |
Convert to MAFT and problem solved.
#97 (permalink) | |
Evo IX
![]() Join Date: May 2004
Vehicle: 06 Evo IX
#98 (permalink) |
And more importantly cools the intake charge far more than what a long intercoolerless pipe can do. A good intercooler can remove 80% of the heat above ambient.
Turbonetics DSM manifold Turbonetics T3/T4 AAI intercooler & charge piping Greddy Emanage Blue 440cc injectors Pocketlogger and PLX wideband Tsudo 2.5" Catback Hook'em Horns! |
#100 (permalink) | |
But let's not kid ourselves. If the same turbos were pulled off the back, and then mounted right to the manifolds with an intercooler, that Vette would make way more than 535 whp. It's really that simple. |
#102 (permalink) |
After reading this there has been one thing that has not been mentioned. it is the fact the cars everyone is talking about (C5, Hummer, Fbody's) are all decent Sized V8 cars. They do not need the low end torque like our cars do to launch like a bat out of hell.
#103 (permalink) | |
#104 (permalink) | |
Plus not matter if your turbo is sitting right of the head, or on your tailpipe, tuning is the more important, part of any NA to FI conversion. And you're on your own with that kit.
#105 (permalink) |
Vehicle: 1996 Stratus
This guy made his own kit and has been using it for a some time now. There's a lot of good info there.
link message board link I've been looking into this as a way to turbo my car. I have no room under the hood for a traditional setup. |
#106 (permalink) |
pro auto detailer
the paragraph he mentions merely illustrates the importance of proper sizing of the turbo based on what youre gonna do. if youre gonna have an sts style turbo, then with the lower exhaust pressure AND heat (since the cats reach lightoff temperature sooner from the 'virgin' exhaust xD) youll have to choose the size and A/R's of the turbo in an STS accordingly, smaller inducer and such.
just cuz one would have lots of room under there where the muffler used to be doesnt mean you can hang some bowling ball under there and expect the engine to be able to spool it anytime soon =D imo, i still say sts is ok, its just not whats best for this particular car.
The Phalse Chronicles: detailing tips, tricks, and how-to's http://www.club3g.com/forum/showthread.php?t=74660 |
#108 (permalink) |
I think this is the video that was brought up:
http://videos.streetfire.net/search/...9000e3a63d.htm They really didn't explain that "fitting on the MAS" very well. I'm curious if they left it open or not. See for yourself. |
#109 (permalink) |
I'm sorry, but why in the flyin fuck would you put something like this on the four cylinder when you can go to somewhere like a pull a part, buy a manifold and a decent turbo for under 100 bucks (if you're trying to save money), and then buy things such as boost controllers, B.O.V., ect. on the internet!!!??? This thing looks like a whole lot of trouble that is not worth 3000 dollars. Plus, the damn air filter is basically RIGHT behind the wheel, throwing dirt, WATER, pebbles, and God knows what right at the intake. The only engine this might be worth putting on would be a 6 cylinder, but even then I would not put my intake filter where it could possible suck up a nice puddle of water.
