| View Poll Results: interior dash color | |||
| titainium grey |
16 | 72.73% |
| metalic Blue |
6 | 27.27% |
| Voters: 22. You may not vote on this poll | |||
hey guys i was wondering and wanted to get some peoples opions on what color to paint the interior pieces of my car, I have a Titainium 2003 Eclipse Gt an i have a bunch of blue accent lights like the radio buttons an some neons around the cabin but i didnt know if i should paint it like a neon blue color or go real custom and match it to the outside color n paint it titainium grey with the mitsubishi diamond sprayed into it . just let me know what u think.
ADAM BROCK Last edited by TNECLIPSE03; 02/05/2010 at 04:58 AM. |
damitsumasta
Vehicle: 2001 Eclipse GT-T67
Youll regret it if you paint it. I did on my last car and now the only thing in the interior is two seats a steering wheel and a shift knob. So, DONT DO IT!
PRE-RACING.COM AUDIO PLUS |
SCC-PHOTOGRAPHY.com
![]() Join Date: Jan 2006
Vehicle: 04 NSX, 10 Murano, 08 Alt
Either match the color or leave it alone.
Interior Painting - $0.00 : Sport Compact Customs, Online Store The process that it's done is VERY detailed. If you think it's a simple as pulling the parts out, priming and painting - you're very wrong. It's more work than painting a body panel on a car. Requires a lot of sanding prep work, flex agents, and baking. This is titanium pearl: Installed - would be the same as this:
Shata Scatta Shred!
+1 Hijacker - It is pretty big job to do, check out my ride you can see little of blue ive done be real careful i almost did to much myself. Ill add silver to mine also to hopefully make things little better. The process although not as complicated has hijackers does take some time and alot of steps to do it right like I did it.
Member Ride <Link> ::114k Miles /w Mobil 1 Everything Synthetic::K&N Air Filter ::24 Brand New Valve Lifters ::03 Eclipse Rinolined Filler Neck ::Exedy Clutch/Pressure Plate ::Fidanza Flywheel 9.5lbs ::Repairs - Belts, Master/Slave clutch cylinders |
