#122 (permalink) |
turbo? unf unf!
good job on the awd swap! horrible job on the looks of the car, but everyone has diff taste..
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project |
#123 (permalink) | |
Ass To Mouth
Also, I have a suggestion instead of having "Evolution" on the back, why don't you change it to "GSX"? I think it would be MUCH more fitting. |
#124 (permalink) |
Vehicle: 2000 RS
update?
parts list with how to?
stock RS. 16.1 in 1/4 mile car on diet, but still stock = 15.58 2006 FASTEST ECLIPSE RS/GS STOCK 2006 FASTEST ECLIPSE RS/GS N/A 2008 NEW RECORD, RS/GS N/A = 15.2 2009 DOHC + 10psi = 14.0 @ 101.89 MPH 2009 DOHC + 15psi = 13.3 @ 108 MPH |
#129 (permalink) |
LOVES OHIO STATE
Don't worry about what some of the idiots here say. The car is damn sick man. Im not big on the silver swirl on it, but its your car. If it makes YOU happy then that is what matters.
The only thing I would change on that car is either go wingless or get an EVO Combat Wing. Oh, and BTW, I think your other projects are kick ass too! |
#131 (permalink) | ||
imiTatum
![]() As an aside, last time I saw Mike (bluebomber) he mentioned something I found interesting. The modding on this car actually began with that aftermarket bumper. He replaced the OEM one with this EVO style front, repainted, and... well, you see where it went from there. ![]() Quote:
We need to display this local innovator on the homepage for a month. Colorado COTM FTW!!
My Ride, gradually evolving... My ambitious "Eclipsed(EVO)" plans for my GS: PHASE 1 -DOHC research__(n00bish fumblings) First documented AWD 3G_(local inspiration) messing w/ Evo 8 gear____(turbo options) See where I'm going with this? ...right back into debt. |
#132 (permalink) | |
imiTatum
Oh, and...
Parts list: (from Post #29) Quote:
Bolt everything up, and... make it work! ![]() (...he had to modify the front crossmember to accommodate the larger tranny, and modified the steering rack as well...) |
#134 (permalink) |
imiTatum
Yeah. Thus his use of "to begin with".
![]() We four bangers basically have a detuned Evo engine with a longer stroke under our hoods. Mike has capitalized on this. I can't wait until he gets that Evo VIII head on there to finish the transformation.
#136 (permalink) |
The Stubborn One
Hrmm, plot thickens :P, I'm working on doing this conversion too myself on my 02' eclipse GT. I had a couple questions though, like why didn't he use a GSX Drive shaft *I'm not sure if it will match up with an evo tranny yet cause nobody can give me a spline count* and when he said 2G control arms in the parts, is that just the rear, upper and lower, or all around, all control arms?
A LOT OF WORK TO BE DONE!!!! |
#137 (permalink) | |
imiTatum
B) 2G control arms are for the rear along with axles & brake assembly. Front is stock. 3) If you're "working on doing this" using the evo tranny on your GT... Stop! Won't bolt to your block, unfortunately.
Last edited by 00TampaBlueGS; 08/26/2007 at 03:20 AM. Reason: clarifying point 'A' :p |
#138 (permalink) |
The Stubborn One
Thanks for that note! lol. Maybe there are other possibilities for a tranny, possibly montero 4x4 or sumthing... Thanks for the heads up though!
Does the evo tranny just not have the same bolt patter, or is it too small or too big for the bolt holes?
A LOT OF WORK TO BE DONE!!!! Last edited by Wingo171; 08/27/2007 at 12:08 PM. Reason: more questions |
#140 (permalink) |
"Suck my unit"
Vehicle: ...coming soon
You could bolt up a VR4 tranny, the 3KGT's have the same block as our cars. Thats the easy part, knowing it will mate to the block. The hard part would be how to mount the tranny and AWD system under the chassis.
#141 (permalink) |
Administrator
Nice work. I don't care for the visual aspects of the car, but to each their own. I do, however, think the "Evolution" sticker is in poor taste, but again, it's your car.
However, you should get rid of what sounded like the HK$ SSQ BOV.
Special thanks to Mike W & Scot Gray at Road///Race Engineering ---- Make your car turn... MUELLERIZE IT! |
#145 (permalink) |
Vehicle: 03 AWD DOHC Turbo GSX
The Evo trany holds the starter at the bottom by the oil pan and the evo 8 oil pan has a notch for the starter to fit there, so now as far as using the evo turbo I no longer have the starter in the way.
#151 (permalink) |
I could be wrong but I am pretty sure in a turbo configuration the less back pressure you have the quicker the the turbo will spool, I barely notice any turbo lag with my set up, and if I loose a little torque to make the car look that much better thats fine with me.
They are Sport Max wheels.
#155 (permalink) | |
Psychotic
Blue is your car still runing? on a galant board some is claming your car is broken down.
#156 (permalink) |
Yeah still is running nothing is broken all is well, I don't know where someone would have heard that. I just work so much I don't have a lot of time to have fun with it, that and my tags are expired which doesn't help either.
Also I limit the driving till I can find an ACD pump for the transfer case to work properly.
#157 (permalink) | |
Psychotic
#158 (permalink) |
It been a while since my last update, so heres whats next.
I will be doing the evo head swap and heres what I will be working with: ![]() ![]() ![]() ![]() For the record yes the valve cover is damaged and I am currently in search of a new one. Also I am getting ready to fabricate a tubular cross member for the awd conversion at my recently opened shop, which will correct for the evo knuckles deference for alignment and better located the sway bar and create easier access to the P/S rack and lines. And of course create a few copies to sell.
#159 (permalink) |
As far as the head swap goes I am finding it hard to find an answer on one thing, I know I can use the evo timing belt as long as I use adjustable cam gears, but do you need the adj. cam gears if you use the 94 galant dohc timing belt?
#162 (permalink) |
Christopher Pearce
Very nice. What sort of performance gains are you anticipating with the Evo headswap in conjunction with your turbo?
Christopher R. Pearce Information Sciences and Technology Information Context: People, Organizations, and Society (ISPP) The Pennsylvania State University |
#164 (permalink) |
this car will basically be a stronger evo once you get that swap complete.
just another n00b watching n00bs even MORE DUMB than myself blowing their shit up one start up at a time. |
#169 (permalink) |
Dover White Pearl RS
Congrats on COTM!
Current Mods Injen CAI CMF Header/Hi-Flow Cat Invidia N1 Cat-Back 13" LS1/Cobra Brakes KYB AGX/TEIN S-Techs ST Rear Sway Bar GT Front Strut Bar 18" Black Racing Pro N-1 Wheels Sonar Projectors w/4300K HID Sportronic Conversion AVIC D3/XM Radio/NavTraffic Black TYC Tails GT Side Skirts Ready To Install RMDSM Front Sway Bar Firm front; poly rear mounts 5pc Black Grillecraft |
#171 (permalink) |
Congrats on COTM! Ride is great!!
AEM Intake,Short Shifter,Magnaflow Exhaust, Speedhut Gauges with Aluminum Bezel,Blue Underglow Kit, Momo Shift Knob,Custom System,Motegi DP6 rims,Goodyear essenza tires 225/40/r18,Carbon Fiber Taillights,Rear Clear Corners |
#172 (permalink) |
jDm tYt3, y0!
Vehicle: 2003 Eclipse GS
Amazing car, shows the community that AWD can be done, and has been. Thanks for paving the roads for the 3G community! For the record, this car should have been COTM a long while ago.
#174 (permalink) |
The GLR 4x4
Congrats on cotm. Very well deserved and happy new year.
http://img170.imageshack.us/img170/7...gnatureem3.jpg |
#175 (permalink) |
Vehicle: 2000 RS
I vote car of the year!
#177 (permalink) |
He was saying car of the year, not just car of the month...
