Clunking noise in rear when going over bumps - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 09/12/2009, 12:58 AM   #1 (permalink)
ok4u2nvmy3g's Avatar
Vehicle: 03' Eclipse GT
ok4u2nvmy3g : who are you?
ok so this is a problem that has been going on for awhile and its annoying!!!
I "believe" it started after one of the coldest days in the winter. Its almost like something in the rear suspension locked up. I know its not the struts I had those replace because when my mechanic tried to take off the rear springs they were like jammed on.
I googled my problem and the best answer was the connector plate from the strut to the car itself, but that was also check...
Any ideas would be very helpful in fixing this problem!!!!
ok4u2nvmy3g is offline   Reply With Quote Quick reply to this message
Old 09/14/2009, 01:12 PM   #2 (permalink)
Pissed
zakmartin's Avatar
Vehicle: '08 350Z Touring
zakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends herezakmartin has a few friends here
1. Check to make sure your spare tire is tightly secured to the floor.
In your opinion, was your mechanic reliable? Do you think he did an adequate job checking everything? Springs should not be "jammed on" to their seats. If memory serves me correctly, there should be a pad between the spring and the connector plate. Also, check all your rear bushings. A busted bushing could cause a clucking sound.
zakmartin is offline   Reply With Quote Quick reply to this message
Old 09/14/2009, 02:54 PM   #3 (permalink)
Titanium Spork
scarr's Avatar
Vehicle: 2001 spyder gs
scarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by all
1) STRUT 2) HUB and BEARING 3) KNUCKLE
4) UPPER CONTROL ARM 5) FRONT ARM 6) FRONT BUSHINGS
7) REAR ARM 8) TRAILING ARM 9) COIL SPRING
10) DUST SHIELD 11) STRUT BUMPER 12) CUP
13) SPRING INSULATOR 14) STRUT MOUNT 15) STABILIZER BAR
16) BUSHINGS 17) BRACKET 18) LINK
19) CROSSMEMBER
there is a breakdown of what SHOULD be there. it is from:
OEM Mitsubishi Parts
tha might help you to make sure you even have all the parts.
zakmartin, the part you were referring to is the spring insulator, i think. so memory does serve well.
scarr is offline   Reply With Quote Quick reply to this message
Old 09/15/2009, 06:07 PM   #4 (permalink)
Vehicle: galant
wardak33 needs to be reminded to breathe.
Send a message via AIM to wardak33
Did you check your sway bar end links?
1999 Mitsu. Galant- 2.4L SOHC-BONE STOCK...for now at least
wardak33 is offline   Reply With Quote Quick reply to this message
Old 09/16/2009, 09:06 AM   #5 (permalink)
Drastic Racing
00Clipse's Avatar
Vehicle: 2003 Evo VIII
00Clipse : who are you?00Clipse : who are you?
Get underneath of it and see if anything loose/broken. In the future don't assume that just because you had something replaced that it's completely out of the equation. If someone comes to me after taking there car someone else and says oh I just had this replaced at so and so's garage, that's the first thing I check. I'd say more than half of the time that's there problem. He could have left out the rubber bushing between the spring and the strut top. He could have forgot to tighten the bolt down all the way. 100 things that could have went wrong with the strut replacement.
00Clipse is offline   Reply With Quote Quick reply to this message
Old 09/16/2009, 09:09 AM   #6 (permalink)
mditt8671's Avatar
Vehicle: 2004 Spyder GTS, Titanium
mditt8671 : who are you?mditt8671 : who are you?mditt8671 : who are you?
Send a message via AIM to mditt8671
Make sure your muffler is secured.
mditt8671 is offline   Reply With Quote Quick reply to this message
Old 12/04/2009, 09:07 PM   #7 (permalink)
Vehicle: GT Spyder
Steel Dreams is similar to TE
endlinks
spray some wd40 on your rear endlinks and drive over a bump. If the noise goes away or is diminished you need new ones (the wd40 wont last)
Steel Dreams is offline   Reply With Quote Quick reply to this message
Old 12/04/2009, 10:11 PM   #8 (permalink)
Flip! What the zip?!
Hijinx's Avatar
Vehicle: 2010 Genesis Coupe
Hijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends here
This. Check his work. I had to double check my own work, because I had this exact problem.
This ish right here...! This ish right here...!
It's called cryptochronophililite!
Hijinx is offline   Reply With Quote Quick reply to this message
