crazy oil leak/spray! - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 10/19/2009, 01:50 PM   #1 (permalink)
flyimages's Avatar
Vehicle: 00' Eclipse 6G75
flyimages : who are you?flyimages : who are you?flyimages : who are you?
Send a message via AIM to flyimages
Question crazy oil leak/spray!
it initially started with a couple drips, now i see about 2x2 inches of spot under my car, see trails of oil. now today driving, my whole engine is smoking, i can see the oil on the bottom on the the front header collector, oil pan, catalytic converter, exhaust pipe.
also, i can see the spray of oil like an upward position from the top the header & valve cover. i've been trying to pin point it but no luck, oil filter is tight. it only leaks when the car is on. i decided to put a a piece of cardboard under the car, it consistently is leaking directly under the oil filter in drips, but not sure where the spray is coming from on top of engine.
any ideas?
flyimages is offline   Reply With Quote Quick reply to this message
Old 10/19/2009, 01:53 PM   #2 (permalink)
Flip! What the zip?!
Hijinx's Avatar
Vehicle: 2010 Genesis Coupe
Hijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends hereHijinx has a few friends here
Did you just get your oil replaced?
This ish right here...! This ish right here...!
It's called cryptochronophililite!
Hijinx is offline   Reply With Quote Quick reply to this message
Old 10/19/2009, 02:02 PM   #3 (permalink)
xxjustin100xx's Avatar
xxjustin100xx : who are you?
Send a message via AIM to xxjustin100xx
Double gasket on the oil filter?
xxjustin100xx is offline   Reply With Quote Quick reply to this message
Old 10/19/2009, 02:16 PM   #4 (permalink)
flyimages's Avatar
oil replace 2 months ago, one gasket. i cant imagine the leaking coming from valve cover gasket, i dont think the spray would be that crazy.
Old 10/19/2009, 02:29 PM   #5 (permalink)
Well if its spraying then the oil is under pressure, that could help pin point the location. But how hard could it be to see oil spraying?
Old 10/19/2009, 02:33 PM   #6 (permalink)
flyimages's Avatar
well i show the oil spray marks, but when i dont see any spraying consistently, when the car is on
Old 10/19/2009, 06:30 PM   #7 (permalink)
I hate stance
XwP1ayawX's Avatar
Vehicle: V-ROD, R6, GST
Its the valve cover gasket. The oil pump pushes a decent amount of pressure plus your rocker arms bouncing around sloshing oil everywhere doesn't help.
XwP1ayawX is offline   Reply With Quote Quick reply to this message
Old 10/21/2009, 01:15 PM   #8 (permalink)
flyimages's Avatar
ok, brought it to shop, it was the oil pressure sender, i expected much worst! thx for your input guys.
Old 10/21/2009, 02:55 PM   #9 (permalink)
BoomGoesTheDynaMitt
MarkSpyder's Avatar
MarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by manyMarkSpyder is well-liked by many
Beat me to it! I had some slight spray issues as well and I had just tapped my oil pan, replaced the valve cover gaskets (front/back), replaced the oil cap, oil filter, and had just added a oil psi gauge. I couldn't figure out where it was coming from for awhile but eventually found it was from the sending unit area. For some reason it was a real b!tch to find by myself. Glad you got her fixed!
FI Build:
In Progress: WAIC, Meth Inj, SDS tensioner, ECUFlash
Completed Perf Mods: Vortech V-5, 6G74 Mani/TB, Ripp Headers, Invidia CB w/ HP II Res, Fidanza F/W, Spec S3, Quaife LSD, ZT2/WB/EGT/Boost, Flashable ECU, A1000-6 FPR, VR4 Rails, Venom 310cc Injectors, Walbro GSS342
Future: Pistons, SDS Pullies
MarkSpyder is offline   Reply With Quote Quick reply to this message
