SES and Blinking Neutral Light - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 02/01/2011, 02:30 PM   #1 (permalink)
Roguefrenzy : who are you?
I saw similar but not quite the same threads before posting this.
2001 Eclipse GT Automatic
95,000 miles
No modifications added
Owned it less than 2 years
I put it into gear and it would rev then jump into the gear.
Had "front" speed sensor replaced then the ECU replaced. (Supposedly it was burned and appeared as though some liquid had spilled on it.) That didn't fix the problem so it was taken to a different mechanic who noticed the plug in which the speed sensor connects was cracked so the whole wiring harness had to be replaced.
I got the car back. It no longer "jumps" into gears but instead it puts itself into 3rd gear with SES light and blinking neutral light. SES light comes on as soon as the engine starts the blinking neutral light doesn't start until after it is put into drive. It usually thuds its way into 3rd after a minute or 2 of driving.
Error codes: PO134, PO175, PO732, PO733, and PO734.
Any help would be appreciated. I tried searching and found no results for PO732-PO734 on these forums but I could have just missed them.
Roguefrenzy is offline   Reply With Quote Quick reply to this message
Old 02/01/2011, 02:36 PM   #2 (permalink)
finesse49ers's Avatar
OBD-II Check Engine Light Trouble Codes
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
This is what I'm about:
Old 02/01/2011, 02:48 PM   #3 (permalink)
Sorry, I saw what the codes indicated I just haven't read about anybody else with these problems nor any solutions to these codes. That's what I should have said and I should have posted what the codes meant too.
PO134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
PO175 System Too Rich (Bank 2)
Please excuse anything I left out, its been a very long 7 month ordeal with nobody knowing what the hell is wrong with my car. Thanks for linking that website though, I'll be saving that for future reference.
Old 02/01/2011, 03:32 PM   #4 (permalink)
Oh there have been people with this problem. Use P0 (zero) not PO when searching and you'll see a few threads. Transmission Slipping It could be an electrical wiring problem since you replaced the whole harness, a bad torque converter or worse case scenario the gears are messed up.
