o2 sensor replacement, i think theres 3, but how do i know which? - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 03/10/2011, 05:55 PM   #1 (permalink)
flyimages's Avatar
Vehicle: 00' Eclipse 6G75
flyimages : who are you?flyimages : who are you?flyimages : who are you?
Send a message via AIM to flyimages
Question o2 sensor replacement, i think theres 3, but how do i know which?
Looks like i have the service engine light on, had it checked, o2 sensor, did a search for parts, i see about 3 o2 sensors, how do i know which one?
1. Rear. Upstream sensor (located before catalytic converter)
2. Down-stream sensor (located after catalytic converter)
3. Front. Upstream sensor (located before catalytic converter)
well i finally got it the code is, P0141 heated oxygen sensor - bank 1, sensor 2 "H02S12"
flyimages is offline   Reply With Quote Quick reply to this message
Old 03/10/2011, 06:53 PM   #2 (permalink)
V8 > 3G
skinnyGT's Avatar
Vehicle: racecar
skinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by all
Send a message via AIM to skinnyGT
If you had it checked they should have told you which one it is bad. There's also 4 sensors if your car has pre-cats.
skinnyGT is offline   Reply With Quote Quick reply to this message
Old 03/10/2011, 08:21 PM   #3 (permalink)
finesse49ers's Avatar
What was the code? Obviously it doesn't do you any good to get the codes checked if you can't even tell us the code. Get the code again and then repost it so we can help you.
This is what I'm about:
Old 03/10/2011, 09:10 PM   #4 (permalink)
flyimages's Avatar
sorry, i had my bro take it to get tested, he failed to mention the code, well i finally got it the code is, P0141 heated oxygen sensor - bank 1, sensor 2 "H02S12"
oh btw, im assuming my car is cali spec? checked under the hood on the sticker on the passenger side, which shows cali spec, and the mfg date on door shows june 2000.
Old 03/11/2011, 03:35 PM   #5 (permalink)
flyimages's Avatar
took a screenshot of the location, cany anyone confirm if its the "Rear. downstream sensor (located after catalytic converter)?"
im also assuming its the bottom sensor directly before the cat with the red arrow pointing to it?
Old 03/11/2011, 09:18 PM   #6 (permalink)
Yes that's Bank 1 Sensor 2.
Old 03/11/2011, 09:26 PM   #7 (permalink)
flyimages's Avatar
here's the avail o2's im seeing available, i narrowed it down to bosch only, so far i think it may be the "Bosch Part Number: 13412, Application:
Oxygen Sensor | AutoZone.com
Old 03/21/2011, 06:34 PM   #8 (permalink)
vintageant : who are you?
Code I just had pulled is P0141 O2S Heater Ckt Malfunction 1/2. AAP sales guy said I should replace both upstream and downstream (that's 2), but above thread suggests there are 3 or 4.
Brand new to this Forum, so all assistance appreciated.
2000 Eclipse GT 112K miles
vintageant is offline   Reply With Quote Quick reply to this message
Old 03/22/2011, 10:13 PM   #9 (permalink)
Get some!
DoubleOughtGT's Avatar
DoubleOughtGT : who are you?
I'm getting a P0170 and P0171 code on mine. The dealer said it was both my bank 1 sensors. I haven't replaced them yet so I'm not sure.
Is the P0141 a code I'll be getting next if my sensors are bad??
DoubleOughtGT is offline   Reply With Quote Quick reply to this message
Old 03/22/2011, 10:21 PM   #10 (permalink)
flyimages's Avatar
its just the 1 rear o2 sensor downstream after cat.
Old 03/22/2011, 10:27 PM   #11 (permalink)
You do as I told the OP and change Bank 1 Sensor 2.
Check for a vacuum leak and also look at your MAF to see if it's dirty. It may need a cleaning.
Old 03/23/2011, 08:54 PM   #12 (permalink)
Thanks, guys! Diagram states right bank, and Finesse states bank 1. Does right =1 and left =2?
Old 03/23/2011, 09:41 PM   #13 (permalink)
You change the one with the arrow pointing to it.
Old 03/24/2011, 08:55 AM   #14 (permalink)
hates "smart" people
primula's Avatar
Vehicle: 2006 TSX
primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.primula is God.
On the eclipse, yes.
Right = bank 1 = nearest to firewall
Left = bank 2 = nearest to radiator
primula is offline   Reply With Quote Quick reply to this message
Old 03/24/2011, 09:03 AM   #15 (permalink)
primula's Avatar
Vehicle: 2006 TSX
Alternative would be Denso.
I beleive it is part number : 234-4656
Old 03/24/2011, 09:29 PM   #16 (permalink)
Great, thanks! Will tackle this weekend.
Old 03/26/2011, 09:40 AM   #17 (permalink)
Get some!
Thanks man. I cleaned my MAF and no more codes!!
Old 03/26/2011, 11:30 AM   #18 (permalink)
You're welcome.
Old 03/26/2011, 04:50 PM   #19 (permalink)
Went to AAP and didn't realize how many choices of downstream O2 sensors there are. They listed a Denso OEM for $90, but not in stock and a 'universal' for $68, which I think means splicing wire which I'd rather avoid. I bough neither pending further input from you expert guys!
Old 03/28/2011, 09:16 AM   #20 (permalink)
Usc529 can pretty much be considered an idiot by all
rear upstream o2 sensor replacment
YouTube - 2001 Mitsubishi Eclipse Gt rear o2 sensor removal
Usc529 is offline   Reply With Quote Quick reply to this message
Old 04/03/2011, 04:02 PM   #21 (permalink)
hiimchad suckshiimchad suckshiimchad sucks
does anyone know which sensor is on the front of the exhaust manifold in a 4cyl? is it bank 1 sensor 1?
hiimchad is offline   Reply With Quote Quick reply to this message
Old 04/03/2011, 05:54 PM   #22 (permalink)
Titanium Spork
scarr's Avatar
Vehicle: 2001 spyder gs
scarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by allscarr seems to be well-liked by all
yes
you got questions? we got answers:
If you want it done right, follow scarr's advice 100%.
scarr is offline   Reply With Quote Quick reply to this message
Old 04/03/2011, 06:03 PM   #23 (permalink)
Originally Posted by scarr View Post
yes
thank you
Old 04/05/2011, 01:55 PM   #24 (permalink)
Lbriptide21 : who are you?
I guess there is a first time (post) for everything. I just researched and replaced my bank 1 sensor 1 and 2. My two codes were bank 1 sensor 2 heat failed and the dreaded warm up cat below threshold. Anywho both downstream sensors are the same for both banks, but the upstreams are two different part numbers. I used the borsh universal since autozone was out of oem plugs. The universal was actually easy to replace. No soldering required. You remove the sensor, measure out the old one, cut the new one same size. Strip the wire ends and you twist them into connectors then into this little plastic box it comes with it splices on your old connector which plugs into the port. Took about 15 minutes a piece to make. As for removal of bank 1 sensor 1. I used an o2 socket to a long extension. I removed it when the car was warm so the bung was expanded. As for bank 1 sensor 2, removed passenger wheel, left the black plastic on, sprayed with pb blaster and used another longer extension so my ratchet was in the wheel well. Used my knee to apply addition torque (had no breaker bar) and removed it. This cleared both my codes. 20 mi later no codes, and I have smog this weekend.
Lbriptide21 is offline   Reply With Quote Quick reply to this message
