brake and battery light on - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 03/12/2011, 11:06 PM   #1 (permalink)
Nego's Avatar
Vehicle: 2004 Mitsubishi EclipseGS
Nego Nego Nego Nego Nego Nego Nego Nego Nego Nego Nego
Exclamation brake and battery light on
2004 Eclipse GS Manual 2.4l sohc
60000 miles
Problem: My battery & brake light both turned on and i just got a new battery and didn't fix it i don't think the brakes are messed up since they are not making the squeaky sound. I noticed that while driving when accelerating it starts to flicker the higher the speed the more it flickers if i accelerate so can anyone help,
Nego is offline   Reply With Quote Quick reply to this message
Old 03/12/2011, 11:09 PM   #2 (permalink)
Got Rice Boy's Avatar
Vehicle: 2004 WRX
Got Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by all
Check the negative on the battery, mine was loose, and if i hit a bump or accelerated my lights would dim and the battery light+ebrake light would come on.
Got Rice Boy is offline   Reply With Quote Quick reply to this message
Old 03/12/2011, 11:12 PM   #3 (permalink)
CreepnIn The Shadows
3gEclipse86's Avatar
Snake Champion! Simon Champion! Moon Lander Champion! Aqua Slug Champion!
Vehicle: 15 STI
3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all3gEclipse86 seems to be well-liked by all
Send a message via AIM to 3gEclipse86
If all your connections are tight, have your alternator checked out. When that light comes on it's indicating it's either not charging or it's overcharging.
do i need turbo for BOV chirp sound? or can i jusst install the bov alone my frend wanted to kno
does anyone know anyway I can put a turbo on my 01 spyder gt. i don't want it for power i want it for the car shows. so anything would help. maybe i would like to get on it from time to time..
3gEclipse86 is offline   Reply With Quote Quick reply to this message
Old 03/12/2011, 11:14 PM   #4 (permalink)
DTP
DTP's Avatar
Vehicle: '00 Mitsubishi Galant
DTP : who are you?
Your alternator I'd probably shot. I had to replace mine bit even a month ago.
Check connections, if those are good, then it's the alt.
Do you have a voltmeter?
Sent from my iPod touch using Tapatalk
Brought to you by:
DTP is offline   Reply With Quote Quick reply to this message
Old 03/12/2011, 11:17 PM   #5 (permalink)
Nego's Avatar
Ill double check the battery negative cable but i don't think that's it since i just tighten up when i changed the batt. earlier today and i still have to check the alternator even tho i really don't think that's it but we'll see i guess
Old 03/12/2011, 11:20 PM   #6 (permalink)
Nego's Avatar
Hmm ill check tomorrow on the alternator still IF it was to be that why would the brake light come on!??
i will check connections tomorrow and see but im preety sure they are good
and no i dont have a voltmeter
Old 03/13/2011, 09:24 AM   #7 (permalink)
DTP
DTP's Avatar
DTP : who are you?
Not sure to be honest. It may be the way the car is programed to alert you? Someone will chime in with the real reason.
After you check the connections, get advance to do a load test, and that'll give you your answer right there.
Brought to you by:
Old 03/13/2011, 11:47 AM   #8 (permalink)
Nego's Avatar
Yea im bout to go to advance and see whats up
--El Transformer
Old 03/13/2011, 06:09 PM   #9 (permalink)
Nego's Avatar
well my alternator went bad.....i hope it fixes the brake light also
--El Transformer
Old 03/13/2011, 06:11 PM   #10 (permalink)
It could also be a loose or slipping belt.
Bitter is online now   Reply With Quote Quick reply to this message
Old 03/14/2011, 04:55 PM   #11 (permalink)
Nego's Avatar
Well, to fix this problem had to get a new alternator and new brakes. Also the reason why my car wasn't sucking up the battery was because the alternator was throwing more volts than necessary. Problem solved..
--El Transformer
Old 03/21/2011, 12:54 PM   #12 (permalink)
Vehicle: 1998 Mitsubishi Galant ES
MarcinPL89 : who are you?
It means your alternator is bad i had the same problem on my 98 galant bttery and brake come one when i replaced it went away.
MarcinPL89 is offline   Reply With Quote Quick reply to this message
Old 03/21/2011, 01:00 PM   #13 (permalink)
finesse49ers's Avatar
I think he's figured that out by now.
This is what I'm about:
Old 03/21/2011, 01:02 PM   #14 (permalink)
Aple juic is my beer
Drunkoffjuic's Avatar
Vehicle: 02 GT 3.8L, 07 Jeep GC
Drunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club existsDrunkoffjuic is one of the reasons this club exists
Send a message via AIM to Drunkoffjuic
Welcome to a week ago when he posted "Problem Solved"
All images appearing on club3g.com posted by user "Drunkoffjuic" aka Eric Nemcek, are the exclusive property of Eric Nemcek and are protected under the United States and International Copyright laws.
The images may not be reproduced, copied, transmitted or manipulated without the written permission of Eric Nemcek .
Use of any image as the basis for another photographic concept or illustration (digital, artist rendering or alike) is a violation of the United States and International Copyright laws. All images are copyrighted © 2006 - 2016 Eric Nemcek .
Drunkoffjuic is offline   Reply With Quote Quick reply to this message
Old 03/25/2011, 05:16 PM   #15 (permalink)
joeyzambo's Avatar
Vehicle: 00' Eclipse GT
joeyzambo : who are you?
Yeah, i had this same problem too, it confused the shit out of me and then my car wouldnt start so i realized the alternator was dead.
joeyzambo is offline   Reply With Quote Quick reply to this message
Old 01/31/2012, 02:27 PM   #16 (permalink)
KCMor01gt : who are you?
I'm having the same problem, I've had the car for a year and they've been on ever since. I figured if it was the alternator it would have gone bad by now... any other sugguestions other than checking connections and volts to alt. ?
KCMor01gt is offline   Reply With Quote Quick reply to this message
Old 01/31/2012, 02:49 PM   #17 (permalink)
Tx4Codeman's Avatar
Vehicle: Lure 13.5
Take your vehicle to Autozone and have them test your alternator and battery.
. Please
Old 02/01/2012, 09:05 AM   #18 (permalink)
HRT
HRT seems to be okayHRT seems to be okayHRT seems to be okayHRT seems to be okayHRT seems to be okayHRT seems to be okayHRT seems to be okayHRT seems to be okay
Takes 10 minutes and it's Free, why not.
HRT is offline   Reply With Quote Quick reply to this message
Old 02/01/2012, 09:23 AM   #19 (permalink)
(b)org banugee
citm2000's Avatar
Vehicle: 2008 Mazdaspeed 3
citm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by allcitm2000 seems to be well-liked by all
Send a message via AIM to citm2000
I had this issue once and it wasn't related to my battery, alternator, or battery cable. I was pulling my hair out trying to nail it down. Eventually I got codes for my cam and crank position sensors as well. The culprit? The ground that goes between the plenum and the firewall.
I had run a new one to replace the brittle and broken one during my plugs/wires/gaskets replacement and hadn't torqued it down enough. It came undone. I had also used a higher gauge wire because it was all I had at the time.
The fix? I torqued down the bolts for the ground. Then I ran another ground from near where the O2 sensors connect on the driver-side front plenum straight to the negative terminal on the battery. It was good after that.
Who is John Galt?
Mein Gasfuß der wird mächtig schwer.
citm2000 is offline   Reply With Quote Quick reply to this message
Old 02/08/2013, 01:32 AM   #20 (permalink)
Vehicle: 02 Eclipse GT
ECLIPSE6G72 can pretty much be considered an idiot by all
I had my alternator checked at auto zone and they said it was good checked cables and battery postals everything is good everytime i drive it the lights battery and brake come on them everything starts to dim then car dies and all i did was replace the clutch any help
ECLIPSE6G72 is offline   Reply With Quote Quick reply to this message
Old 02/12/2013, 04:13 PM   #21 (permalink)
gneugen : who are you?
Giving this thread a bump.. I've had a similar issue multiple times in the past year. I've gone through 4 alternators, all with the same issue.. the voltage regulators keep getting fried. I've taken them out and had the parts store test them on the bench and they all put out charge, but the voltage regulators basically go bad and fry the battery (too high of voltage). I took it into a shop and specifically asked them to check for wiring issues since it was, at the time, the third or so alternator I had burned through and they said they didn't see any issues that would cause this to keep happening. Of course it happened again. I installed a new alt maybe 2 weeks ago and already I'm seeing the brake/battery light flickering on from time to time so I know what's coming soon enough.
Hopefully someone here has some insight where I can check under the hood for issues that might cause this problem. Here's hoping!
gneugen is offline   Reply With Quote Quick reply to this message
Old 02/12/2013, 06:23 PM   #22 (permalink)
You sound like you have a poor grounding system.
Old 02/19/2015, 11:09 PM   #23 (permalink)
Vehicle: '03 Spyder Eclipse GTS
Latiniceman : who are you?
I am having this battery/brake light issue now as well. Just had my clutch and transmission replaced and assumed the mechanic either shorted a wire somewhere or didn't properly re-assemble a ground harness somewhere. Could you please post a pic of this plenum ground wire and it's location? I am not sure what a plenum even is. Thanks
Latiniceman is offline   Reply With Quote Quick reply to this message
Old 02/19/2015, 11:11 PM   #24 (permalink)
Pshyc
3g_bishi's Avatar
Vehicle: 03 Eclipse GTS
3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay3g_bishi seems to be okay
Plenum is the upper intake manifold.
3g_bishi is offline   Reply With Quote Quick reply to this message
Old 02/20/2015, 12:35 AM   #25 (permalink)
Cone Killer
DSM208's Avatar
Vehicle: 2003 Eclipse GTS
DSM208 seems to be okayDSM208 seems to be okayDSM208 seems to be okayDSM208 seems to be okayDSM208 seems to be okayDSM208 seems to be okayDSM208 seems to be okay
I've been through 2 alternators now. Same issue with the two lights. However, i think my issue had to die with the fact that we broke the alternator plug removing the original one. Had to wire in a new one, so there may have been some issues contributing from that in my case.
DSM208 is offline   Reply With Quote Quick reply to this message
Old 04/30/2015, 09:12 AM   #26 (permalink)
DCR
DCR : who are you?
i have a 2002 eclipse, have a problem, both brake and battery light come on when RPM reach 2500 and over, then they flicker... my stereo starts cutting in and out then just cuts off, then when i use my turning signal my rpm needle starts jumping along when i push the brake peddle, i shut the car off and then it wouldnt start... i just replaced my battery, alternator, ground cable and negative battery cable and its still giving me this problem... what is this problem???
DCR is offline   Reply With Quote Quick reply to this message
Old 04/30/2015, 09:22 AM   #27 (permalink)
DCR
DCR : who are you?
i have a 2002 eclipse and the battery and brake light come on with the RPM reaches over 2500, the stereo starts cutting in and out and then just cuts right out.. then when i use my turning signal my rpm needle starts jumping along when you press the brakes, i turned the car off and it wouldnt start back up, i just changed the battery, alternator, ground cable and negative batt cable and it never fixed my problem.. i dont know what else could be the problem...
