Crankshaft Position Sensor Location??? - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 05/19/2011, 04:23 PM   #1 (permalink)
thekingofvtec : who are you?
I have a 2002 Spyder GT, 5-Speed
i've narrowed the issues down to the CPS. Cranks, getting fuel, won't start. Behaved completely normal, then the next morning, would do nothing more than crank.
Sources have told me you must remove the timing belt to replace it on the 3.0 V6. The timing cover is already off, but i just had this thing timed a couple months ago, not wanting todo it again.
ANY HELP?
thekingofvtec is offline   Reply With Quote Quick reply to this message
Old 05/19/2011, 04:27 PM   #2 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
mitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regular
ya, replace the sensor. this happened to me, but when i was on the freeway. not very fun.
take of the timing belt cover and the motor mount on that side and it is the wire that is in the middle of it. right next to the small oil pump belt i believe.
not a fun job i might ad. good luck
mitsu3g01 is offline   Reply With Quote Quick reply to this message
Old 05/19/2011, 04:33 PM   #3 (permalink)
just the timing belt cover? not the actual belt?
Old 05/19/2011, 04:37 PM   #4 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
im pretty sure your gonna have to take the belt off. cant remember i did the job a long time ago.
Old 05/19/2011, 04:41 PM   #5 (permalink)
ECLIPTO
davila825's Avatar
Vehicle: 00 eclipse gt
davila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends heredavila825 has a few friends here
wtf are you talking about! there is no need to take off mount. and there is no oil pump belt.
1.) locate the cps sensor wiring. it runs on top by the timing cover. I believe its mounted on the intake manifold.
2.)take off wheel and all accessory belts.
3.)take off crank pulley
4.) take off lower timing cover
5) then you should see the cps sensor secured by two 10mm bolts
6.) the wiring is run through the lower timing cover, so its kinda tricky
7.) make sure you run the wire correctly because you run the risk of it rubbing on the timing belt thus exposing live wire and ultimately ruining the new cps
refer to How To: Change the Timing Belt on the V6 *WITH PICTURES*
MY CAR:
davila825 is offline   Reply With Quote Quick reply to this message
Old 05/19/2011, 04:44 PM   #6 (permalink)
@davila ok, so it doesnt sound like a very intensive process...?
the timing cover is already completely off. so no need to remove the belt?
Old 05/19/2011, 04:48 PM   #7 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
just noticed for a gt. so what belt is inside the perimeter of the timing belt? and when i did mine, taking off the mount is easier, unless you have the hands of a five year old.
Old 05/19/2011, 04:49 PM   #8 (permalink)
ECLIPTO
davila825's Avatar
now that i think about....while your down there you might as well do 60k service, if you haven't already....if you decide to do it.. i suggest.....new timing belt, new timing belt tensioners, water pump, cam and crank seals, heck while your at new drive belts. just a suggestion it will save a lot of trouble further down the road. i am speaking from experience. well good luck and keep us posted on how it goes
MY CAR:
Old 05/19/2011, 04:51 PM   #9 (permalink)
already been done. it has 80k miles on it. everything down there is practically new. everything was put on except the cover. but for the CPS, no need to remove the belt?
Old 05/19/2011, 04:53 PM   #10 (permalink)
ECLIPTO
davila825's Avatar
well if your replacing the timing belt then removing the mount is essential.
the only belts on the gt are three. the timing belt is inside the timing cover so you dont see that. there are two that go around the crank pulley. one for the power steering and the other goes to a/c and alternator
taking off the drive belts does not involve taking off motor mount
MY CAR:
Old 05/19/2011, 04:54 PM   #11 (permalink)
ECLIPTO
davila825's Avatar
no need to remove timing belt, but you do need to remove the two drive belts to gain access to the cps
MY CAR:
Old 05/19/2011, 04:59 PM   #12 (permalink)
ahhh okay thanks. thats what i needed to know. timing belts disturb me, between Mitsu's and Honda's, its enough work.
Old 05/27/2011, 12:20 PM   #13 (permalink)
Update...
Replaced CKP sensor, code went away, then came back. Still wont start.
Camshaft Position Sensor maybe... but its getting spark. If the sensor inside the distributor is messed up, would it still spark???
Old 05/27/2011, 01:11 PM   #14 (permalink)
ECLIPTO
davila825's Avatar
you say the code went away, did you unplug the battery for 10-15 min to clear the codes? how long was it gone for?
MY CAR:
Old 05/27/2011, 02:46 PM   #15 (permalink)
yea i cleared the codes out. umm after attempting to start it for about 5 mins, it came back. but... i think i found the issue.
so i discovered the spark plugs were wet from gasoline, so i decided to change them, figuring spark would suffer, so i took off the upper intake manifold to get to the rear plugs, and just out of curiosity looked down into the lower manifold, and... the intake valves were wide open. EVERY SINGLE ONE OF THEM.
so i turned the crank a few times, all of the rocker arms, cams move, but seems the valves don't. the valves and pistons never made contact during this process, so idk what the hell is going on. even if the timing was off, which i don't believe it is, it still doesn't explain why ALL of the intake valves were open at the same time.
*cries* *wants to beat car with hammer*
Old 05/28/2011, 12:28 PM   #16 (permalink)
Vehicle: 2001 eclipse gt
anthony4901 : who are you?
EXACTLY ... CPS IS SO SIMPLE ...
anthony4901 is offline   Reply With Quote Quick reply to this message
Old 05/28/2011, 03:42 PM   #17 (permalink)
ECLIPTO
davila825's Avatar
read the entire thread before you post noob!...hes already replaced the cps.
MY CAR:
Old 05/29/2011, 01:24 PM   #18 (permalink)
lmao.
Old 06/01/2011, 08:58 PM   #19 (permalink)
UPDATE: All of the intake valves are bent! Not really sure how, the timing belt didn't break, and from what i'm told, the car was running.
I played around with it, turning the crank, and at no point did all the timing marks line up, so i'm just going to assume its previous owner was a complete idiot. and a liar. lol
Old 06/15/2011, 11:53 PM   #20 (permalink)
ECLIPTO
davila825's Avatar
so where you driving it with bent valves?
MY CAR:
Old 11/23/2011, 05:48 AM   #21 (permalink)
Vince86 : who are you?
This car wouldn't be in Monongahela, PA would it?
Vince86 is offline   Reply With Quote Quick reply to this message
Old 02/17/2017, 08:38 AM   #22 (permalink)
Knight86 : who are you?
I have 03 Mitsubishi ECLIPSE looking for the crank sensor location
Knight86 is offline   Reply With Quote Quick reply to this message
