P0401/EGR Question - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 06/11/2011, 10:00 PM   #1 (permalink)
Vehicle: 2003 Eclipse GT
Newmanfan : who are you?Newmanfan : who are you?
P0401/EGR Question
Hi Folks,
So the other day my SES light came on, and when I scanned it with a code reader, it gave me a P0401.
As has been suggested in other threads on this topic, I decided to clean the vacuum hoses as a first step to see if that solves the problem. Sure enough one of the hoses going to the vacuum control valve was clogged, and I found a little metal object inside of it, which I removed. This part almost looks like something that goes somewhere, but I have no idea where it came from.
I've only driven 50 miles since removing the object and so far no SES light. take a look at the images and tell me what you think.
Thanks
Newmanfan is offline   Reply With Quote Quick reply to this message
Old 06/11/2011, 10:05 PM   #2 (permalink)
is there a hole through the center? It could be to restrict vacuum to slow the actuation of the valve or something.
Old 06/11/2011, 10:09 PM   #3 (permalink)
There is, but it's very small. when I removed the hose, I couldn't blow through it before removing the object.
Old 06/11/2011, 10:59 PM   #4 (permalink)
Tx4Codeman's Avatar
Vehicle: Lure 13.5
I have never seen that on any 3G I've worked vacuum hoses on.
. Please
Old 06/11/2011, 11:11 PM   #5 (permalink)
Vehicle: 2000 Eclipse GTX
Me neither and I've done 2 sets in the last 2 weeks.
Old 06/12/2011, 09:12 AM   #6 (permalink)
DIRTYWILL2001's Avatar
Vehicle: 02 Stratus RT
DIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFODIRTYWILL2001 Really needs to MTFO
bitter is right. the restrictor might have become clogged.
that part is documented in the service manual.[IMG][/IMG]
DIRTYWILL2001 is offline   Reply With Quote Quick reply to this message
Old 06/12/2011, 01:49 PM   #7 (permalink)
Very interesting!
I guess I should try to clean it and put it back! I didn't think to make note of which way it goes. I would guess narrow end toward the vacuum control valve?
I'm glad I didn't lose it since it's only 2mm x 4mm!
Just out of curiosity, if I had to replace this, is there a part number? I have a copy of the Mitsubishi ASA program, and it doesn't even list this part.
Thanks
Old 06/14/2011, 01:35 PM   #8 (permalink)
anyone happen to know which way this restrictor should go back in?
thanks
Old 08/01/2011, 04:48 PM   #9 (permalink)
Gigaclips : who are you?
My car had that thing in the same line !! i need to replace the Vacuum Control Valve idk where to buy...Mits service dont have it they need to order it they said in a month....
Gigaclips is offline   Reply With Quote Quick reply to this message
Old 08/03/2011, 04:08 PM   #10 (permalink)
FWIW, I've left mine out since I started this post, and have had no problems, no SES light. Car runs great!
Old 08/04/2011, 08:54 PM   #11 (permalink)
that's good -.- my car sill has the god dam check light on for p0401 i change the EGR The EGR Solenoid the Control Valve check all lines look fine i clean them out sill reads the code Note all new parts are Original from the dealer...any ideas?
Old 08/24/2011, 09:23 PM   #12 (permalink)
artefakto : who are you?
i had that same little thing clogged in the hose , did u put it back??
artefakto is offline   Reply With Quote Quick reply to this message
Old 08/24/2011, 09:30 PM   #13 (permalink)
finesse49ers's Avatar
2 posts above yours:
This is what I'm about:
Old 08/30/2011, 05:16 PM   #14 (permalink)
GTbro's Avatar
Vehicle: 02 GT Eclipse
GTbro : who are you?
Did that solve your problem? I have the same code and tried different things.
GTbro is offline   Reply With Quote Quick reply to this message
Old 09/25/2016, 10:10 PM   #15 (permalink)
Ps3mn1 : who are you?
Hello all,
I'd like to say I been dealing with the P0401 Engine code for a few months and I finally nailed it! First I had the P0403 and I replaced it with a new Dorman EGR Solenoid and the P0403 light went away and I now had the P0401 code. I tested the old Solenoid using the vacuum pump to see if it held air when you plugged the top of the solenoid. Well it was leaking internally so I went back to the auto parts store and got a replacement solenoid, I bought a BWD brand solenoid which when I tested it with the vacuum pump it held air, so I knew the part was good to go. Installed it, it was easy because it's only held in by 1 bolt. Went for a cruise and within 2 miles the engine light came on again. I didn't even get back home before the engine light came on. Got home and ran the scan tool and I had the same P0401 code. I read somewhere that there is a Restrictor inside the hose with the white dashes, it's a very short hose that's connected the the EGR Vacuum. I took out the Restrictor with a tiny phillips screwdriver, re connected the white dashed hose, cleared the engine code, and went for another cruise. I took the same path which is under 5 miles and I made it back home and I still had no engine light.
So two things happened, the First Dorman Solenoid was bad. Replaced it with a working BWD Solenoid. And I took out the Restrictor in the White Dashed hose.
This has solved my P0401 Code!
Hope this helps!
Ps3mn1 is offline   Reply With Quote Quick reply to this message
