Ticking noise in engine bay - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 10/28/2011, 06:48 PM   #1 (permalink)
kyle920's Avatar
Vehicle: 2000 Eclipse GT Turbo'd
kyle920 : who are you?
Hey I was wondering if anyone knows or have any ideas on what this noise could be?
Video won't embed, not sure why?
Oil is full (although not changed in a while)
kyle920 is offline   Reply With Quote Quick reply to this message
Old 10/29/2011, 11:22 PM   #2 (permalink)
kyle920's Avatar
bump
Old 10/29/2011, 11:28 PM   #3 (permalink)
Got Rice Boy's Avatar
Vehicle: 2004 WRX
Got Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by all
Honestly, it sounds like lifter tick, which is very common in mitsubishi engine's.
I'd change the oil if it's been awhile. What kind of oil are you using?
Got Rice Boy is offline   Reply With Quote Quick reply to this message
Old 10/29/2011, 11:29 PM   #4 (permalink)
Tx4Codeman's Avatar
Vehicle: Lure 13.5
That's a little on the loud side for the usual lifter tick...
. Please
Old 10/29/2011, 11:33 PM   #5 (permalink)
Vehicle: 2004 WRX
You would be surprised, this was mine before.
Old 10/30/2011, 12:07 AM   #6 (permalink)
andrzejluko's Avatar
Vehicle: 2002 Eclipse RS
andrzejluko : who are you?andrzejluko : who are you?
Send a message via Skype™ to andrzejluko
I have a similar sound, my buddy thinks it's a lifter tick, I notice that it gets louder near my time to change the oil and gets quieter after I put in fresh oil. That usually works for me...I did some searching and found an article on it, that I have yet to try so I won't vouch for it yet, but I've been looking into it.
"On the 3.5 and (I believe) the 3.0 V6's as well, there is a device in the valve train called a valve lash adjuster (VLA). This device is like a little piston and cylinder filled with oil. It is different from a hydraulic lifter, and functions to keep the slack in the valve train to a minimum as the engine ages. The VLA has a little ball valve held in place by a spring, and uses oil pressure to take in oil and place constant pressure on its valve. Dirty oil from even several oil changes ago (or a previous owner) can leave particles in the ball valve that hinder its ability to remain pressurized. This leaves slack in the system and you hear it as clicking. It is also caused by getting air bubbles past the check valve that is now stuck at the top of the little cylinder, unable to leave via the ball valve at the bottom.
SYMPTOMS: A valve train clatter on startup that does not go away when the engine is warmed. If it goes away, this is not your problem.
Causes
Low oil - now or previously.
Dirty oil - now or previously.
High oil - now or previously (con rods slap the too high oil and "foam" it). Note that high oil can be caused by coolant contamination from a blown gasket, not just by overzealous owners. Parking on a steep hill - now or previously. With the engine off, this encourages the VLA to drain its oil (running steep hills are not a problem, unless it's so steep the oil is getting "foamed" by the con rods).
Parking for long periods - now or previously. Over time they'll drain.
The Fix
Now that I've made you all paranoid, here's the laughably simple fix. The VLA's were designed to respond to a pattern of gentle revving to flush the oil out of the little cylinders (those clever Mitsu engineers, eh?)
1. Warm up the engine.
2. With the engine in neutral, gently rev it from idle to 3000rpm over a period of exactly 15 seconds. Your goal is a constant gradual increase to 3000rpm. At the 15 second mark, drop the throttle (foot off the gas) to idle. Now let it idle for 15 seconds to complete one 30 second cycle
3. Repeat the 30 second cycle in #2 from 10 to 30 times. If the problem persists after 30 cycles, this is not your problem. It fixed mine after only 5 cycles - total silence."
The website is here.
Mitsubishi Tech - Minute Mod: The 5 Minute Lifter Noise Fix
If you try this and it works let me know.
andrzejluko is offline   Reply With Quote Quick reply to this message
Old 10/30/2011, 12:33 AM   #7 (permalink)
Exacerbated Member
WorldWind's Avatar
Vehicle: 2kFsGt5sp/TbPP
That doesn't sound like lifter tick to me but it's hard to say because the engine is running so far above idle.... what rpm is the engine running at? The number of crank revolutions per knock should be a clue to the origin.
Your car sounds like the inside of a old time MRI machine.
WorldWind is offline   Reply With Quote Quick reply to this message
Old 10/30/2011, 12:52 AM   #8 (permalink)
Vehicle: 2000 Eclipse GTX
Sounds like tick to me. This sounds crazy but do an oil change with Rotella full synthetic. Its a diesel oil and it cleans your shit OUT. Took care of the lifter tick on my friends 3g. A normal oil change didn't do it, but rotella did. Since its made for diesel its made for a much greater capacity to absorb grime and such and keep the engine clean because diesel is so much dirtier so on a gasoline engine it kicks ass. I'm waiting for my dad to cave and do the Odyssey with this stuff so I can see it work for myself.
Old 10/30/2011, 12:59 AM   #9 (permalink)
kyle920's Avatar
Will do the oil change and the VLA solution and let you guys know the result and if the noise goes away.
Old 10/30/2011, 08:15 AM   #10 (permalink)
All right sounds good, keep us updated.
Originally Posted by Silvertune View Post
Do an oil change with Rotella full synthetic. Its a diesel oil and it cleans your shit OUT. Took care of the lifter tick on my friends 3g. A normal oil change didn't do it, but rotella did. Since its made for diesel its made for a much greater capacity to absorb grime and such and keep the engine clean because diesel is so much dirtier so on a gasoline engine it kicks ass.
This is weird...seems like it would fuck up the engine, but okay. I'm assuming he'd still go with 5w-30 on the oil? Or do they not have that. I was looking it up on Shells website and didn't see a 5w-30. You should find out what your friend used on his 3g.
Old 10/30/2011, 08:22 AM   #11 (permalink)
Diesel engine oil will not harm your engine, I run it in my Celica which is MUCH more sensitive to oil than the 6G72.
Typically a good quality synthetic diesel oil will contain a higher level of anti-wear additives as well as much more detergent and suspension additives since diesel engines have alot more fuel wash down on cold starts and all that soot gets into the oil that has to be kept in suspension as well. Only thing you risk is damaging the cat converter if you burn oil, since some of the anit-wear compounds are not friendly to the catalyst material. If you don't burn oil any more than normal, don't worry about it. If you do, well you're going to ruin the cat anyways.
Old 10/30/2011, 01:31 PM   #12 (permalink)
kyle920's Avatar
Yeah I don't have cat's on my car anyways so I don't think it will harm anything.
Old 11/02/2011, 10:32 AM   #13 (permalink)
Get a chance to try anything yet?
Old 11/02/2011, 01:05 PM   #14 (permalink)
kyle920's Avatar
Not yet, trying to fix a oil leak before i change out the oil and everything. Did change out the spark plugs though with some NGK IX Iridium and it runs alittle better. But hopefully have the oil leak issue fixed today and then ill try out the other things tomorrow.
Old 11/02/2011, 01:42 PM   #15 (permalink)
I hope you gapped those plugs. NGK doesn't do that from the factory and you'll want tighter then stock since you're boosted.
Old 11/02/2011, 01:56 PM   #16 (permalink)
kyle920's Avatar
actually i didn't. About what should they be gapped too with the turbo?
Edit:
Does about .030" - .025" sound right?
Old 11/02/2011, 02:20 PM   #17 (permalink)
Depends on your boost but I'd go .030". Unless you're running over 12 psi I wouldn't go any lower.
Old 11/03/2011, 12:43 PM   #18 (permalink)
kyle920's Avatar
Yeah I'm only running 8 psi, so I'll regap them and see if runs a little better.
Old 09/03/2012, 10:25 AM   #19 (permalink)
Mattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by many
Lifter tick?
MVI 0109 - YouTube
Mattt is offline   Reply With Quote Quick reply to this message
Old 09/03/2012, 10:27 AM   #20 (permalink)
Put half a can of seafoam in it and drive around for half an hour then flush the crank case.
Old 09/03/2012, 10:42 AM   #21 (permalink)
Then 1/2 qt auto trans fluid, run for 500-1500 miles, change, see how long it stays gone for. It may stay gone for a long time, it may come right back. If it comes right back, your lifter's internal seals are in the pooper and the lifters need to be changed/rebuilt to get rid of the tapping.
I've always wondered, could you convert to solid lifters? Solid hunk o metal there (well hollow) with a little bucket with a shim inside it at the end.
Old 09/03/2012, 11:12 AM   #22 (permalink)
3G eclipses
fvasconez62's Avatar
Vehicle: 2001 GS
fvasconez62 : who are you?fvasconez62 : who are you?
how did you fix this? my car been doing this for months now havent gotten around to see what it is.
fvasconez62 is offline   Reply With Quote Quick reply to this message
Old 09/03/2012, 11:31 AM   #23 (permalink)
I think it's been outlined in the thread above if you read.
Old 09/03/2012, 11:20 PM   #24 (permalink)
Danielv2008's Avatar
Vehicle: 04 STI
Danielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regularDanielv2008 should be considered a regular
I don't think so because you wouldn't have the proper valve clearance and it would be difficult/time consuming to adjust
Danielv2008 is offline   Reply With Quote Quick reply to this message
Old 09/03/2012, 11:48 PM   #25 (permalink)
Not really, look at a SOHC Honda setup.
Setscrew and locking nut, adjusting lash is as easy as slipping in a feeler and setting it. I don't see why something similar couldn't be machined for the SOHC 6G7x rocker arms. Get a bit of steel, thread it, bore the rocker arm, press it into the rocker arm where the lifter sat, bore the hole at the top of the rocker a little larger, spin the hardened steel set screw down the threads, put a lock nut on and voila! Heck, you could probably use the body of a lifter for that.
Old 09/04/2012, 07:45 PM   #26 (permalink)
Vehicle: 04 STI
That wouldn't exactly be "easy" Seems like more work and risk than it's worth!
Old 09/04/2012, 07:48 PM   #27 (permalink)
Sounds like an awesome project to me, a true one of a kind. Any lightening of the valve train is good.
Old 09/04/2012, 07:53 PM   #28 (permalink)
Drewski0523's Avatar
Thanks Bitter, Its gone for now. The problem was the front of the car was on jack stands for 3 days so the oil completey drained out of the top end of the engine. I threw some fresh oil in it and ran it for 5 minutes. Tick went away
Drewski0523 is offline   Reply With Quote Quick reply to this message
Old 09/06/2012, 10:30 AM   #29 (permalink)
Vehicle: 2001 Eclipse GS
AnonymousDog : who are you?
...of course, you're offering for comparison what is, IMHO, one of the best designed, easiest to service top ends ever!
AnonymousDog is offline   Reply With Quote Quick reply to this message
Old 04/09/2013, 05:06 PM   #30 (permalink)
Chaos
lif315chaos's Avatar
Vehicle: 03' Mitsubishi Eclipse GT
lif315chaos : who are you?
I know this post is old but i'm curious if anyone has tried this fix at all?
lif315chaos is offline   Reply With Quote Quick reply to this message
Old 07/11/2013, 09:18 PM   #31 (permalink)
fclass308's Avatar
Vehicle: 03 GTS
fclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends herefclass308 has a few friends here
wow
Last edited by fclass308; 07/11/2013 at 09:21 PM. Reason: post moved while replying????
fclass308 is offline   Reply With Quote Quick reply to this message
Old 07/16/2013, 09:45 PM   #32 (permalink)
Foolin : who are you?
Thumbs up I had this a couple weeks ago
i didnt read the thread so i dont know how this turned out for you, but all i did was throw some engine flush in it right before my last oil change. after, i threw a can of protectant in. no more clicking....
Foolin is offline   Reply With Quote Quick reply to this message
Old 08/05/2013, 02:59 PM   #33 (permalink)
Vehicle: 2000 Eclipse GT V6
cnam : who are you?
My 2000 Eclipse GT always has the lifter noise near the end of 3000 miles oil change interval. Will a Mobil 1 5W-30 High Mileage or 0W-30 be better for this?
cnam is offline   Reply With Quote Quick reply to this message
Old 08/05/2013, 03:03 PM   #34 (permalink)
blackspydergt's Avatar
blackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regularblackspydergt should be considered a regular
Run some marvel mystery oil and some Lucas in te gas. I'd go with 5w
blackspydergt is offline   Reply With Quote Quick reply to this message
Old 04/05/2016, 11:40 AM   #35 (permalink)
Mathieu : who are you?
Hey guys! I have an 03 2003 ecliose gts 3.0l. I have a similar problem. I used to have them ticking noise on start up until I cleaned my valves and used synthetic 5w30 and it went away... now closer to my oil change (just about 6000km, usually I do every 5000km but oil level is good and not really dirty) it started doing this really loud knocking noise at idle. When I would Rev it over 2000rpm it goes away. When it drops down back to idle, roughly around 750rpm the ticking/knocking noise comes back. I told this to my teacher (btw I'm in my sexond year of auto mechanics trade course) and he told me to bring my car in so we could check. When I went to bring it in the noise was gone. Now there's just a faint tick/knock when it idles. Can anyone she'd some light on this? I tried to post a video of it but I dunno where to post or upload a video here. If anyone has any idea what is causing this it would really be appreciated. It's a great car I've had for alost a year and by far my favorite!! Would hate to have to get rid of it. Thanks.. any information would greatly be appreciated!!
Mathieu is offline   Reply With Quote Quick reply to this message
Old 04/05/2016, 11:50 AM   #36 (permalink)
http://s1276.photobucket.com/user/Mathieu_Jean/media/Mobile%20Uploads/20160323_120805_zpszbpp6vhq.mp4.html?filters[user]=132335253&filters[recent]=1&sort=1&o=0hey guys this is the videal of the sound my motor does hope the link works.
Old 04/28/2016, 07:45 PM   #37 (permalink)
reneebrant666 : who are you?
My ladies 03 3.0 only on cold start noisy only periodic,used some foam and mystery oil went away then again it was cold and noisy in start any ideas it runs great when warm and had a random misfire code throw recently?
Sent from my SM-T210R using Tapatalk
reneebrant666 is offline   Reply With Quote Quick reply to this message
Old 05/31/2016, 03:49 PM   #38 (permalink)
xfactor5 : who are you?
Originally Posted by Mathieu View Post
Were you able to find out what the issue was??? I'm having the same noise on my 2.4L
xfactor5 is offline   Reply With Quote Quick reply to this message
Old 06/01/2016, 06:22 AM   #39 (permalink)
Rex
Vehicle: 2002 eclipse spyder gt
PerezGTspyder : who are you?PerezGTspyder : who are you?PerezGTspyder : who are you?
just try changing your oil full synthetic mobil 1 with a mobil 1 filter. i added marvel mystery oil to my oil change and it went away in less than 5 minutes.
PerezGTspyder is offline   Reply With Quote Quick reply to this message
Old 11/09/2016, 10:28 PM   #40 (permalink)
jehangt3's Avatar
Vehicle: 2003 Eclipse 3.0L GT Red
jehangt3 : who are you?
Send a message via Skype™ to jehangt3
Hi, I like to get someones expert opinion on this. I had a tunup performed and soon after I noticed a knocking/ticking noise everytime the car is started in the morning (it goes away after the engine is heated up) and every time I step on the gas while driving at low speeds. the mechanic who did the tuneup said it could be carbon buildup and recommended I put some Lucas along with my next oil change. I did some research and I feel like Lucas is a thick honey like sticky thing that seems it could cause problems in the future however I could be wrong. I have used Pennzoil platinum full synthetic 5w-30 for the past 2 years and haven't had a problem but i've noticed the oil level goes down a bit lately. Because I have 135,000 miles at this point and my engine is kind of old I'm thinking of running seafoam, flushing the engine and pouring fresh Valvoline max life synthetic blend 5w-30 oil and also adding some reslon engine treatment along with it. my question is this.. because I live in upstate new york where the weather can become freezing cold and because I'm planning to switch from "full synthetic" to kind of thicker "synthetic blend" oil and add reslon engine treatment along with it (which may make the oil even more thicker, correct me if i'm wrong) would it be safe to start my engine in cold winter mornings without causing oil pump issues? and will it resolve my engine knocking/ticking issue. if not.... i'm guessing it could be that the lash adjusters (lifter) should be replaced. please advice & thanks in advance
Jehan Ansar
IT Services
Honor's Haven Resort & Spa
1195 Arrowhead Rd I Ellenville I NY 12428
Direct Line: 845-210-1600 ext: 3178 I Fax: 845-210-3098
Mobile Cell Phone (Sprint): 845-549-5675
jehangt3 is offline   Reply With Quote Quick reply to this message
Old 02/21/2017, 06:54 PM   #41 (permalink)
jehangt3's Avatar
NEW UPDATE, I did my timing belt and noticed misfires P0301 & P0304 after about 200 miles (about a month later) so I changed all NGK plugs, NGK wires, upper intake manifold gasket, distributor cap & rotor, water pump kit, O2 sensors (the whole 9 yards) and got the WRX like sound after work was done in the garage, later they did something and fixed the noise and let me drive away. now i'm getting a ticking/knocking kind of noise when I step on the gas peddle while cruising. I checked this up in another garage and they said it could be the combustion with cylinders and that the engine is old and should be rebuilt/replaced (I was like who has money for that shit) so they suggested I don't drive hard and take it easy on the throttle so i've been driving like an 70 year old grandma ever since. Now i'm getting P0301 again. what should I do here?, based on what I've read from other threads all I found out was to check the timing belt position on teeth, replace coolant temperature sensor, check the distributor cap or gape the spark plugs. any suggestions?
Old 03/27/2017, 11:51 AM   #42 (permalink)
FromTheGrave : who are you?
My eclipse has been doing the same sort of tick, did all the previous stated fixes all the way up to replacing all lifters, noise is still there. It seems to me to be an issue with the belt/pulley assembly that's causing the noise. After some research and hard thinking i believe it just might be the timing belt tensioner, idler pulley or even the harmonic balancer. Just sounds like something is off center and freely slapping around. If anyone else has looked into this could you shed some light on my theory?
Sent from my iPhone using Tapatalk
FromTheGrave is offline   Reply With Quote Quick reply to this message
Old 04/05/2017, 11:34 AM   #43 (permalink)
gclawton's Avatar
gclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFOgclawton Really needs to MTFO
Most of this "lifter tick" is probably your purge valve solenoid doing its job. And reving your car up however many times will never ever fix a tick coming from your valves. Run a slightly thicker, high mileage oil if your worried. Posted for searches.
gclawton is offline   Reply With Quote Quick reply to this message
