Electric problem - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 08/15/2012, 08:28 PM   #1 (permalink)
Vehicle: 2000 eclipse gt
dalesocks : who are you?
Send a message via MSN to dalesocks
Electric problem
So my battery was drain because there was a short. When I open my hood I hear 5 of the 30amps(or 20) relays clicking and my headlights flashing but the car is turn off. If I disconnect the relays and plug them back usually goes away for a while but comes back to the same problem. Anyone with a similar problem or any help will be appreciated. Thanks in advance.
By the way car is a 2000 eclipse gt 100% stock.
dalesocks is offline   Reply With Quote
Old 08/17/2012, 07:17 AM   #2 (permalink)
dustin560 : who are you?
as for relays yeah i replaced mine and still get the clicking but fixed my headlights flashing. asfor the the short if you dont wanna pay to have it checked get a ohm meter. Look up or message me on how to check for a short. Its not that hard to find what circuit is causeing it. The broke wire might be.
--==dustin560==--
dustin560 is offline   Reply With Quote
Old 08/17/2012, 09:56 AM   #3 (permalink)
I do have an ohms meter. It might be a single wire connecting them all, I have to check the schematic but is juts a weird issue.
Old 08/17/2012, 11:19 AM   #4 (permalink)
Yeah iv looked it over. If u want ill tell u how to do a drain test. When ever I get home don't wanna type it on the phone
--==dustin560==--
Old 08/17/2012, 11:35 AM   #5 (permalink)
Well it does not have a drain. Is more like on and off at random times that the flashing happens and the 5 relays start clicking.
Old 08/17/2012, 08:15 PM   #6 (permalink)
Vehicle: 2000 GT
mits00b : who are you?
Are you sure the alarm is not causing it?
mits00b is offline   Reply With Quote
Old 08/17/2012, 11:11 PM   #7 (permalink)
I think it could be related. But no sound just the flashing. And why would the alarm go off randomly?
Old 08/17/2012, 11:16 PM   #8 (permalink)
eligs's Avatar
Vehicle: 2000 gs eclipse
eligs : who are you?eligs : who are you?eligs : who are you?eligs : who are you?
hit the panic button on your key fob, if your lights flash without the horn sounding off its probably just your alarm going off, the horn isnt sounding because there is a bad connection between the connector and the horn, and my 2000 gs had the alarm going off randomly, draining my battery, i read somewhere to remove the underhood sensor (by the l strut tower, has a rubber cap on it) would solve the random alarm problem, i unhooked it and havent had a problem since
eligs is offline   Reply With Quote
Old 08/18/2012, 11:28 AM   #9 (permalink)
Car did not come with key less entry but I'll try disconnecting the sensor.
Old 08/18/2012, 11:37 AM   #10 (permalink)
Where is this sensor exactly? Any pics?
Old 08/20/2012, 08:45 AM   #11 (permalink)
I couldn't find it.
Old 08/21/2012, 10:53 PM   #12 (permalink)
eligs's Avatar
sorry, havent been on in a coupple days, i will try to remember to grab a few pics off the car tomorow
Old 08/23/2012, 11:12 AM   #13 (permalink)
Thank you but I think I fixed it.
