Hello! This is a very odd one of a problem..
I was on the highway in 5th gear at about 110km and suddenly a hissing/ squeaking happens as i was on the gas.. It seem to only happen if i accelerate and gets louder as rpm goes up. So far no performance issue or anything other than noise.. Any ideas anyone??
Thanks for spending your time reading! Sent from my iPhone using AutoGuide.com Free App |
The noise is on the driver side, sounds like high pitch buzzing only when i press on gas pedal above 2000 rpm..
King of Rice!!
Vehicle: 2003 Eclipse GTS
The first bloody sticky, and the first post inside of it. Good Lord.
Common 3G problems Next time post in the new members sub forum if you're going to ask a question without searching at least a little. |
Lil mitsu, thanks but i ve gone through 4000 posts and didnt see anything thats relating to my problem so thats why i posted. If i found the problem i wouldnt be here would i.
And i checked the sticky note and that wasnt the answer
King of Rice!!
A "sucking" sound and a high pitched whistle while on the gas is the tell tale signs of your intake sucking up against your hood. It says so on the first post of the thread I linked. All you have to do it get new push connectors for it.
Thanks i will double check that today, was too dark to see where the sound was, thought it was alternator
