Getting air out of clutch.??!?!?! - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 02/22/2007, 09:22 PM   #1 (permalink)
Eclipse.
panicbutton's Avatar
Vehicle: 02 Eclipse GT
panicbutton needs to be reminded to breathe.
Send a message via AIM to panicbutton
i have a air bubble in my clutch how do i seep it out.
panicbutton is offline   Reply With Quote Quick reply to this message
Old 02/22/2007, 09:49 PM   #2 (permalink)
Topless = Way to go
nox7788's Avatar
Vehicle: Chrome Blue 03 Spyder GTS
nox7788 : who are you?nox7788 : who are you?
In your clutch? I guess you mean in the clutch cylinder. There is a bleeding valve near the radiator on the transmission, you have to unrachet while applying pressure, rachet back and pump the clutch until the pressure returns. If there's still bubbles just repeat until you've bled the cylinder free of bubbles. Remember to refill the reservoir.
nox7788 is offline   Reply With Quote Quick reply to this message
Old 02/23/2007, 01:42 AM   #3 (permalink)
Eclipse.
yes sir, it only does it every once and a while thow my clutch just doesnt come back up, it makes it harder to put into gear.
Old 02/23/2007, 09:32 AM   #4 (permalink)
Topless = Way to go
nox7788's Avatar
Yes that would need to be bled out of the system then. Do what I posted earlier.
Old 02/23/2007, 10:32 AM   #5 (permalink)
What Speed Limit?
Bios24's Avatar
Vehicle: 2003 Eclipse GT
Bios24 : who are you?Bios24 : who are you?Bios24 : who are you?Bios24 : who are you?Bios24 : who are you?
Isn't the bleeder valve on the slave cylinder? From my experience this is a 2-person job unless you have a speed-bleeder installed. It's just like bleeding brake lines. Last time I couldn't even bleed it right, I ended up just taking it to the shop.
Also- If you're clutch is going to the floor this may be a sign that your master/slave cylinder is going out. How many miles do you have on the car?
border="0">
Bios24 is offline   Reply With Quote Quick reply to this message
Old 02/23/2007, 10:35 AM   #6 (permalink)
Halfway off da hinge
Stokes's Avatar
Stokes : who are you?Stokes : who are you?Stokes : who are you?Stokes : who are you?Stokes : who are you?
Send a message via AIM to Stokes
yah it is, and remember! when you bleed your clutch, don't leave the top off the fluid canister like my dumb ass! took me an hour to get the air out of..
Tranny Swapped...and She's OK!
Stokes is offline   Reply With Quote Quick reply to this message
Old 02/23/2007, 11:08 AM   #7 (permalink)
Topless = Way to go
nox7788's Avatar
Yes, its the slave, and ohh yes, don't leave the top off the reservoir.
BTW, it should be a two man job (someone opens the bleeder, another pushes the pedal down), but I've done it by myself.
If this doesn't solve the problem, then you probably have a defective master or slave cylinder.
Old 02/25/2007, 01:33 AM   #8 (permalink)
Eclipse.
ok guys, im going to work on it tommarow. how much is this cylinder cost if it needs to be replaced? and bleeding it is located exactly were?
Old 02/25/2007, 01:38 AM   #9 (permalink)
Eclipse.
and can i change the cylinder myself? to save money?
Old 02/25/2007, 09:07 AM   #10 (permalink)
Topless = Way to go
nox7788's Avatar
The slave cylinder is not costly but I have no idea on the master....
The bleeder is located (if you look at the car from up front) near the air filter box (right side) if you look down toward the transmission you will see it. Its a bolt with a little hole just like the bleeders located on the brakes.
Old 02/25/2007, 09:44 AM   #11 (permalink)
What Speed Limit?
Bios24's Avatar
FYI- if you choose to replace the slave cyliner I would highly reccomend replacing the master cylinder also. Both work together and usually will go out together. Last time I replace a slave cylinder the master started leaking about a week later.
border="0">
