Vehicle: 02 GS
B16 G no dissasembulll!!!
Okay so i got a center section thats in good shape. BUT
the C ring on the old one is rusted to hell!!!! I soaked it with PB blaster which was the best anit rust liquid i could find but that shit wont budge. Plus the best c ring pliers i could find are lame for this job. Being that the ring on the compressor is about 3 or 4 times as large as for an SSQV,they barely applied a sufficient amount of force for the BOV's c ring. So i need some suggestions. Where to get some MEAN anit rust liquid and Like some industrial strenth C ring pliers.
2002 GS 5spd, Wrx modded 440s Greddy Type-S Megan Racing Evo 8 Manifold Evo 9 turbine Invidia SS O2 Dump Custom 3" DP Catco 3" HFC Greddy EVO2 modded 3" Injen LICP Zietronix ZT2 Prosport boost fuel press. oil press. oil temp. EGT G-Speed CF hood, Tien S-techs, ADR fuel bronze 17" wheels, OLD - 2000 RS 5spd Last edited by Ithinkyou; 01/14/2008 at 06:50 PM. |
GT35 DOHC 500wHp
Vehicle: 3G turbo
i took it apart using regular Needle-Nosed Pliers, but you have to take hotside of the center section first. If it slips take grinder and grind pliers tips so it does not slip. And if if is seized just put thin rod you can use a nail and hit it with hammer as if you would compress it, that should help.
Vehicle: 02 GS
fuck i hate snap rings!!!
2002 GS 5spd, Wrx modded 440s Greddy Type-S Megan Racing Evo 8 Manifold Evo 9 turbine Invidia SS O2 Dump Custom 3" DP Catco 3" HFC Greddy EVO2 modded 3" Injen LICP Zietronix ZT2 Prosport boost fuel press. oil press. oil temp. EGT G-Speed CF hood, Tien S-techs, ADR fuel bronze 17" wheels, OLD - 2000 RS 5spd |
Low and Slow.
A snap ring? They make a special tool for that, and it doesnt cost much.
![]() Snap ring pliers You should be able to get a pair at Lowes/ Home depot. |
#7 (permalink) | |
GT35 DOHC 500wHp
Vehicle: 3G turbo
#8 (permalink) | |
Vehicle: 02 GS
Ive looked for a bigger set but nobodys got anything or knowledge, I need mor leverage to be honest.
#9 (permalink) | |
RS-T in progress...
Mitsubishi TD04-13T Turbo Rebuild I guess you could try those. |
#10 (permalink) | |
Low and Slow.
At work we have some monster Snap ring pliers, but youre in California it looks like. Try Snap-on tools or even Sears.
Psychotic
![]() $9.99 Harbor Freight Tools 901 N. CARPENTER RD. MODESTO, CA 95351 i think thats the closest to you Harbor Freight Tools - Quality Tools at the Lowest Prices |
Vehicle: 02 GS
if anyone sees anything out of the ordinary please point it out. The inner part of the compressor had some black scuffing on about an 8th of the circumference, would that conclude shaft play or an imbalance of some sort right. The compressor seal def looks a bit worn to me, id say most of the rust on it was from the PB blaster and the other anti sieze liquid i soak it in. Since its bad i think ill try an take it apart just to have a look inside. The tip of the compressor blades were covered in oil as well... ill see if i can get it apart after i take a nap, long night of work. it.
2002 GS 5spd, Wrx modded 440s Greddy Type-S Megan Racing Evo 8 Manifold Evo 9 turbine Invidia SS O2 Dump Custom 3" DP Catco 3" HFC Greddy EVO2 modded 3" Injen LICP Zietronix ZT2 Prosport boost fuel press. oil press. oil temp. EGT G-Speed CF hood, Tien S-techs, ADR fuel bronze 17" wheels, OLD - 2000 RS 5spd Last edited by Ithinkyou; 01/14/2008 at 10:46 AM. |
