starting my build - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Performance & Tech Forums > Forced Induction & Nitrous > RS/GS
Old 06/12/2012, 11:04 PM   #1 (permalink)
rbrothers01's Avatar
Vehicle: 2001 eclipse gs
rbrothers01 : who are you?
starting my build
okay well after having a 1997 eclipse GST and then getting an 2001 gs its sparked my interest in boosting my 3g, now i have some experience with turbos but i will admit iv never done a full kit to a non factory turbo car, and im kind of on a budget. But i found a kit on ebay for around 1000$ and it seems to be everything im gonna need, im only gonna run low boost on it 5-7 psi and it seems that its a pretty simple kit, so im gonna need some support on this and im sure im gonna have some questions on this but i need some opinions on this kit from you guys
Mighty Max Dodge RAM 50 Eclipse DSM 3G 4G64 2.4L SOHC T04E T3 T3/T4 Turbo Kit T3 | eBay
so just give any input you want, i have plenty of time for this build and im sure its not gonna be a simple one so like i said just let me know what you think thanks !
rbrothers01 is offline   Reply With Quote
Old 06/13/2012, 12:31 AM   #2 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
mitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regular
Don't buy that shit.
In before the lock.
mitsu3g01 is offline   Reply With Quote
Old 06/13/2012, 01:32 AM   #3 (permalink)
You did what?
Dj_Bann's Avatar
Vehicle: 2005 VDub Jetta GLI
Dj_Bann : who are you?Dj_Bann : who are you?Dj_Bann : who are you?Dj_Bann : who are you?Dj_Bann : who are you?
THIS!!!
But in the end it's your money
Dj_Bann is offline   Reply With Quote
Old 06/13/2012, 02:56 PM   #4 (permalink)
can you explain why ? i have bought it yet im just curious because iv seen some ebay kits do pretty decent ?
Old 06/13/2012, 03:09 PM   #5 (permalink)
Drewski0523's Avatar
The parts are cheaply manufactured out of cheap materials with low production standards and serious cases of corner cutting. A turbo is a turbo, it will work for a moment so all the hard headed people who slap cheap crap on come back and say "see it works fine". But the don't come back 5 months later to say the engine siezed, the turbo broke, etc, etc. Plus it's never a complete kit and you always have to modify the stuff to make it only work at best.
Your money is better spent on a Evo 16g setup that fits perfectly and is built to last.
Drewski0523 is offline   Reply With Quote
Old 06/14/2012, 01:52 AM   #6 (permalink)
okay thanks that clears some of it up so it seems that im gonna have to buy it all in different parts at a time, so could someone give me a decent run down of the best to go with ? i had a full greddy frontmount kit with a type rs bov injen intake small 16g on my gst , im guessing thats gonna be a good set up to go with on my 3g correct
Old 06/14/2012, 03:54 AM   #7 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
There is a lot of different ways to run a decent setup. Check out the forced induction section. All the info is there. Read up...
Old 06/14/2012, 12:48 PM   #8 (permalink)
okay thanks alot , but iv herd that godspeed turbos are good ?
Old 06/14/2012, 01:13 PM   #9 (permalink)
You did what?
Dj_Bann's Avatar
That question can easily be found on Google.
Old 06/14/2012, 09:33 PM   #10 (permalink)
so im not sure of how many of you car but iv done some research and i guess if you get a knock off turbo and you run very low boost and easy driving and watching it closely for a few weeks it basically breaks it in and you can add boost and it will do just fine ? does this sound reasonable to anyone ?
Old 06/14/2012, 10:09 PM   #11 (permalink)
ya boy willz's Avatar
Vehicle: 2001 Mitsubishi EclipseGS
ya boy willz : who are you?ya boy willz : who are you?ya boy willz : who are you?ya boy willz : who are you?
Send a message via AIM to ya boy willz
Don't be cheap and get a knock off turbo and risk blowing your engine. A real EVO 8 16G with a 9.8 hotside can be found in good condition for under $300 easily on EVOM.
Just save up for a bit and get the real deal. That's my recommendation to you but in the end it's up to you.
ya boy willz is offline   Reply With Quote
Old 06/15/2012, 02:40 PM   #12 (permalink)
okay so i got on god speed .com and found
4g64 turbo manifold
god speed .63ar turbo
down pipe
god speed 38mm waste gate
oil feed and return lines with all adapters
front mount kit
rs bov
for about 1300 $
does this seem decent to anyone ?
Old 06/16/2012, 08:02 PM   #13 (permalink)
Ithinkyou's Avatar
Vehicle: 02 GS
Ithinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends hereIthinkyou has a few friends here
You should post links along with what youre naming off.
2002 GS-X 5spd, v2 - Heavily boosted(Workin on it)
2002 GS-T 5spd, v1 - Boosted (an still slow, didnt come together)
2000 RS-T..?
2000 RS-X...?
OLD - 2000 RS 5spd
OLD - 2001 GS 5spd
Old 06/16/2012, 11:14 PM   #14 (permalink)
yeah i should of... but i ordered a god speed turbo for 800$ and oil line kit, cast iron mani, greddy rs bov, ebay front mout piping, greddy 27x7x2.5 fmic, down pipe, god speed 38mm wase gate etc ....
Old 06/17/2012, 04:48 AM   #15 (permalink)
T-Money is T-Money
Osirisfool's Avatar
Vehicle: 03 Eclipse DOHC GS-T
Osirisfool seems to be okayOsirisfool seems to be okayOsirisfool seems to be okayOsirisfool seems to be okayOsirisfool seems to be okayOsirisfool seems to be okay
this??
MITSUBISHI ECLIPSE 00-05 T3T4 TURBO SET UP KIT [TCK-039] - $800.00 : GodSpeed Project, The Art of Performance
Osirisfool is offline   Reply With Quote
Old 06/17/2012, 07:05 AM   #16 (permalink)
yahh's Avatar
Vehicle: S50 Swapped E30
yahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by manyyahh is well-liked by many
"ebay kit" with a branding.
Originally Posted by Tx4Codeman View Post
sell it, boost it, or accept its slowness.
Club3G Feedback Thread
iTrader
yahh is online now   Reply With Quote
Old 06/17/2012, 07:29 PM   #17 (permalink)
yea im guessing not a smart move ..
Old 06/17/2012, 09:13 PM   #18 (permalink)
Soon to be 4G64K-T!
ryandiaz440's Avatar
Vehicle: 2001 Eclipse GS
ryandiaz440 : who are you?ryandiaz440 : who are you?ryandiaz440 : who are you?
Is this gonna be another ball5out thread? I hope not.
ryandiaz440 is offline   Reply With Quote
Old 06/17/2012, 10:12 PM   #19 (permalink)
why what happend ?
Old 06/17/2012, 10:30 PM   #20 (permalink)
okay nvm dont answer that i read it, and no its not. i was just wondering if anyone could tell me if god speed turbos are decent for our cars ? i have a friend that boosted his 96 420a gs with a god speed and its ran fine for over a year now, and my other friend has one on his srt4, i did get all greddy parts accept the turbo waste gate mani and oil feeds, and ebay pipeing so i know what im doing im not a complete dumb ass, yeah i should of got some more opinions on godspeed's befor getting it i know but im still gonna take my time and watch the turbo very closely first sighn of any trouble and its gone.
Old 06/18/2012, 12:04 AM   #21 (permalink)
Behold a pale horse
Pale Horse's Avatar
Vehicle: 01 Eclipse RS-T, 99 S-10
Pale Horse seems to be okayPale Horse seems to be okayPale Horse seems to be okayPale Horse seems to be okayPale Horse seems to be okayPale Horse seems to be okayPale Horse seems to be okay
This isn't a very good approach to take when turbocharging a non-turbo vehicle, and I can't think of a scenario when it is a good approach to take; as you could have taken your time and bought something that will work flawlessly and NOT destroy your engine the first time around. Now you'll have to redo your setup or at the least change your turbo if and when your turbo shows these signs of trouble you speak of.
I'm not trying to discourage you and I wish you the best of luck, but you really should get some opinions and listen to people when they tell you that 90% of eBay parts are junk and 100% of eBay kits are about as useful as a candle in sunlight.
Four Wheels. Three Diamonds. Two Doors. One Turbo.
Pale Horse is offline   Reply With Quote
