Help from you Boosted SOHC peeps - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Performance & Tech Forums > Forced Induction & Nitrous > RS/GS
Old 01/03/2013, 10:52 AM   #1 (permalink)
UglySleeper : who are you?
Ok i have bought the kia dohc head already..
The question I have is I just want about 300-350 whp out of my engine just for DD and a little fun could I get that from just rebuilding the engine and keeping the sohc with a evo 8 turbo?
I know I will need supporting mods such as fuel,tune,stuff like that because anymore power for a DD would be useless unless awd or driving on slicks...
I just want you input thanks..
UglySleeper is offline   Reply With Quote
Old 01/04/2013, 01:49 AM   #2 (permalink)
GS-Turbooo
CloudINC00's Avatar
CloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends hereCloudINC00 has a few friends here
For DD just leave it SOHC but note that theres a chance you'll lose a/c. It depends on your budget
[ 2003 GS-T | 2001 GS-T Spyder ]
CloudINC00 is offline   Reply With Quote
Old 01/04/2013, 08:02 PM   #3 (permalink)
I wanta6G75TDiamante
Vehicle: 6G74 swap
Jonny03GT : who are you?
Don't the stock SOHC take boost better
than the DOHC kia heads though?
obviously the evo head is built for psi,
but i could swear i remember that stock
heads are better unless you build internals too.
Jonny03GT is offline   Reply With Quote
Old 01/04/2013, 09:27 PM   #4 (permalink)
Vehicle: 03 Eclipse GS-T
01GtCRazyKid : who are you?01GtCRazyKid : who are you?01GtCRazyKid : who are you?
i dont know how it would be better or worse? The Kia/Hyundai head actually have a bigger combustion chamber than the Evo's. over on evom there have been a few guys who actually went and built a Hyundai head with stock evo internals. I did the DOHC swap since my timing belt jumped timing on me. i have evo8 valves, springs, retainers. with the Hyundai Cams since iwas not turbo'd at the time. just recently i turbo'd and ran the Hyundai cams for the first 1k miles and they worked just fine. since then i have swapped over to the evo8 OEM cams.
01GtCRazyKid is offline   Reply With Quote
Old 01/05/2013, 04:22 PM   #5 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Vehicle: V-ROD, R6, GST
I love my DOHC. Haven't regretted anything. I was sick of breaking intake manifolds with the foolish TB flange. The DOHC runs great, and the parts are cheap. I landed a set of BC 272's on evom for 150 bucks... Seriously. My RPW cam goes for 600 for my SOHC, and you still are stuck with a smaller head and a shit manifold.
Old 01/05/2013, 04:27 PM   #6 (permalink)
this is true the DOHC intake manifold flows way better. but i still dont get why the stock mani cracks for some people?
Old 01/05/2013, 06:28 PM   #7 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Solid mounts, big clutch, stiff suspension did it for me
Old 01/06/2013, 11:15 PM   #8 (permalink)
I figured I would do a dohc swap later on down the road but thanks for all the replys I'm getting my order ready for building the short block I emailed RRE to find out what piston they suggest to run since I will be staying sohc right now I'm ordering 7 bolt Manley h beams with acl race 6 bolt bearings due to the fact Manley is one of the lightest h beam rods available does anyone have any advice on piston selection ?
Thanks
Old 01/07/2013, 12:49 AM   #9 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Je. there's rod and piston kits on ebay for the swap
Old 01/11/2013, 03:04 AM   #10 (permalink)
GS-Turbooo
CloudINC00's Avatar
Oh? Someone once gave me a part number for the rod and piston kit for the swap but when I took it to the machine shop, they said it wouldn't work. I'm sure I got the wrong part. Which are you talking about?
And people are right, according to what I've read (as I've only had experience with SOHC and a build SOHC) is Kia > Stock > EVO as far as flow.
I wish there were better intake manifold options for the SOHC, I've already cracked two
Old 01/11/2013, 03:35 AM   #11 (permalink)
just weld the seams of the stock intake manifold. hell i think i still have my stocker i can weld all the seams up.
Old 01/11/2013, 04:08 AM   #12 (permalink)
GS-Turbooo
CloudINC00's Avatar
Yeah I'll have to do that on my spare. One manifold didnt crack at the seam though
Old 01/11/2013, 04:22 AM   #13 (permalink)
post or send me a pic of where it cracked. tomorrow when i get off work i am going to weld up my old stocker and see if anyone of the boosted guys wants to buy it.
Old 01/11/2013, 10:42 AM   #14 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Well the rods are the same regardless, and I'm using JE pistons I bought off an egay vendor. 86.5mm was .020 over I believe.
Old 01/11/2013, 10:47 AM   #15 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Je Pistons 93 Up 4g64 Block 4g63 Head 87 5mm Bore 8 5 | eBay
Those should work with any 4g63 rod
Old 01/15/2013, 12:19 AM   #16 (permalink)
GS-Turbooo
CloudINC00's Avatar
Thanks
Old 01/19/2013, 11:09 PM   #17 (permalink)
Re: Help from you Boosted SOHC peeps
Thanks for the link for the pistons RRE emailed me back and said call them they got pistons in stock that would work didn't even tell me much i guess its there custom piston prolly from weisco or something ....
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Old 01/19/2013, 11:20 PM   #18 (permalink)
King of Rice!!
Lil Mitsu's Avatar
Vehicle: 2003 Eclipse GTS
Lil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by manyLil Mitsu is well-liked by many
I don't know much about this stuff, but I found these..
DSM EVO Eclipse Talon Turbo 4G63T Ross Racing Pistons Eagle H Beam Rods | eBay
Lil Mitsu is online now   Reply With Quote
