GS-Turbooo
Cloud's built SOHC 4g64 project
Well, as some of you may know... I blew some rings. The plan is to rebuild the 4g64 and leave it SOHC. Here's the story and some pictures:
After stage 1 I only made 211 whp with a smooth curve... I was running a 16g at 8psi at the time... dyno tuned with an SAFC-II... ![]() I then did some crazy MODs without proper tuning (like camshaft and larger injectors) then upped the boost (to 12psi then sometimes 16psi). Eventually the car wore down and it blew... I was being an immature idiot. I saw it coming but it was the spur of the moment thing. ![]() ![]() ![]() Then the problem piston... ![]() ![]() ![]() ![]() ![]() The new plan, build the block and use the reflash + e-manage combo to tune it properly. The build kit: http://www.importperformanceparts.ne...itsubishi.html Its a modified version of kit #6.. going with the 8.5:1 Wiesco pistons and undecided on rods Going to use a 56 trim T3/T4 this time instead of a 16g. The valves on cyl 2 are smashed so I'm going with a +0.1 set of valves with titanium springs. Already have the RPW camshaft and I'm thinking about sending the head off to be ported and decked. The car will be complete before the end of summer (Aug or Sept) that way it won't be rushed. I have been humbled - and this being my first car, in the future I will be more realistic. EDIT: 3/11/07 Here is a list of parts I'm planning on using for the build: Head: 2g 4g63 +1mm oversize stainless intake/exhaust valves *purchased*. Port and polish *going to send off, + get the valves seated*. 3g 4g64 Titanium valve springs. 3g 4g64 RPW turbo camshaft. *installed* Block: 3g 4g64 Gasket set. 3g 4g64 MLS head gasket. 3g 4g64 Wiseco Forged Pistons (stock bore 86.5mm 8.5:1 comp) w/rings. 3g 4g64 Rebuild kit. 2g 4g63T 7-bolt Eagle rods. 91 6-bolt con rod bearings. Last edited by CloudINC00; 03/11/2007 at 04:17 PM. |
GS-Turbooo
its not as bad as I've seen other pistons but its still pretty bad. I want to start this thread off with the mistakes and the problems and hopefully by the time this thread is done, the progress would have been recorded and the end result is something worth the effort.
GS-Turbooo
yeah, the rest seem nice and golden brown... this is an odd-ball piston, but then again this happens a lot with cars. Once one piston goes out the whole car drives differently and the car is no-longer being pushed. If it was an injector, that problem is solved because I'm putting the 450ccs back in. I think it was just the tune and timing..
oh, by the way... I like the sound of sealed pistons getting pulled out of the block... haha Last edited by CloudINC00; 03/08/2007 at 08:31 PM. |
i look forward to watching you take your time this go round.
i really enjoyed watching you get everything together, i hope your next project turns out for the best, man. good luck with it.
just another n00b watching n00bs even MORE DUMB than myself blowing their shit up one start up at a time. |
#7 (permalink) | |
GS-Turbooo
my way was pretty easy, the block was already pulled off/bare and the only thing left was the crankshaft. So unbolt and just push down while the block was flipped over. It just made a sliding sound then it "popped" out haha
talk to playa. he used 2g rods. theyre even bigger, and they fit. he said they looked as if theyd flow a lot more than stock even.
#23 (permalink) |
turbo? unf unf!
that #3 detonated bad
make sure you fix the problem, or this will happen to your built engine too
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project |
#24 (permalink) |
GS-Turbooo
yeah, I know. I ditched the SAFC. Going with the reflash, emanage, and adjustable cam gear to level things out. Also going with 550ccs instead of 450ccs or the retarded 780ccs I had (to over-compensate for the SAFC's ability to perform... ended up screwing up the timing).
#29 (permalink) |
Vehicle: 02 sherwood green GS
If you can get EcuFlash to work properly, You'll have no problem with the idle. The injector scaling and latency adjustments should let you run the 780's just fine.
#30 (permalink) |
GS-Turbooo
thats what I was thinking. I need to get acquainted with the software first... either that or get a base map for my car as if it were to run 780ccs N/A then take it to the dyno.
#33 (permalink) |
GS-Turbooo
I just purchased a set of 4g63 SS +1mm O/S valves. Once they arrive, I'm going to ship the head to a shop to get all the work done. Any recommendations? (with website and contact info) A local shop here will take it but I'm sure they charge a lot more for them to ship it off.
#34 (permalink) |
GS-Turbooo
the local shop I'm talking about is:
http://www.stage6motorsports.com/s6_contact.html They don't do it themselves, but they send it off to somebody. I want to see if I can send it off directly without having to go through Stage 6 (they add on to the price) You guys may know Stage6 from youtube or streetfire. For a while, their twin turbo ford GT was in the top 10 videos. I've seen it in person and it's pretty scarry Last edited by CloudINC00; 03/11/2007 at 12:42 PM. |
#35 (permalink) |
GS-Turbooo
![]() They're on the way. I'll update the bottom part of my first post so that new-comers can see what parts im planning on using. Last edited by CloudINC00; 03/11/2007 at 12:42 PM. |
#36 (permalink) |
GS-Turbooo
Head: 2g 4g63 +1mm oversize stainless intake/exhaust valves *purchased*. Port and polish *going to send off, + get the valves seated*. Block: 3g 4g64 Gasket set. 3g 4g64 MLS head gasket. 3g 4g64 Wiseco Forged Pistons (stock bore 86.5mm 8.5:1 comp) w/rings. 3g 4g64 Rebuild kit. 2g 4g63T 7-bolt Eagle rods. 91 6-bolt con rod bearings. The more organized this post, the fewer PMs/questions I get. Plus, if you search for this info, it will all be available. Last edited by CloudINC00; 03/11/2007 at 04:16 PM. |
#37 (permalink) |
GT35 pimpin
Looks like we got the same build going on, sounds straight. Thise valves are sweet, wait till you see it all set up. I'm still waiting on my fuckin pistons
, I need to hit the lottery. As far as the head goes, my guy can do a sweet job, depending on if you want to ship it or not.
#40 (permalink) |
GT35 pimpin
You don't need titanium valve springs. I run those on my 13:1cr Chevelle that tops power at 8500rpms. That would be some serious overkill, not to mention you'd be out a crank after a couple starts. If you do feel like you need em, you'll need a stronger crank to turn the motor around
#44 (permalink) | |
F*** her hard
Look man, I haven't heard a person TILL THIS DAY ON THIS FORUM used 780CC injectors. For the power you want (12-16 range) hell, 440's can handle that and more. BUT!!!!!!!!!!!!. When is anybody going to learn that this car is not a damn DSM nor is it a SUPRA, you can't mod this thing with those damn half ass rinky dink fuel management systems. Sure the E-manage, AFC, S-AFC etc are good. But where do you see these system mostly in? DSM's, Ricer Civics etc. Those cars can tune on a dime. With this 3g ECU we try to make a relationship work with piggyback systems, and all I've read were people steady having problems left and right. I don't give a shit what piggyback system you have this car is too damn smart for that. The Mitsu engineers knew what they were doing when the car was built, and they didn't want our asses fu****** with it. But there is a loop hole. GENTLEMEN GO GET THE AEM EMS. Fellas, please trust me on this. I had a 3g modded with the SDS with engine work and I decided to go EMS just to save a hassel and easier tuning. Boy was I thankful, guys........I never had one issue, never had one engine light on, never had any strange noises etc. It ran perfect. I sold it because I'm getting into bikes now (should have done that in the first place). The key to making the EMS work is you have to have A GOOD TUNER. |
#46 (permalink) |
cloud, a sohc head wont flow enough to make power after 17 psi. if i were you, i think you should play around at 14-16 psi. and call it a day. pushing it any further is almost worthless, also on a piggyback, just isnt the smartest thing to do after dumping all that money into a motor. get an ems. it'll take some saving up, but you'll be glad you did.
i also agree with vielside but disagree with vielside. 450cc injectors can flow 300hp using the right turbocharger but if you push 14-16psi with a hybrid turbocharger, you'd be perfect with 780cc's IMO.
#47 (permalink) |
he does have a cam and will be porting and polishing the head and using oversized valves so why do you think it wont flow enough to make power past 17psi? I am picking out all of my parts now for my build and plan on 30+psi with big turbo on a built single cam head. Granted I plan on doing more head work than him, i still dont see why he wouldnt make power past 17psi.
#48 (permalink) |
F*** her hard
Cloud, here is this......Long time ago Napalm built a SOHC motor, doing exaclty what you wanted to do. He used the E-manage to tune he Powerful SOHC motor only to dissapointment he ended up having motor issues because the Emanage could only tune so far.
After busting up his new SOHC motor, he decided to do the EVO setup. Obviously you all know the result, his car is a F****** beast. Is Napalm still here? Well anyway, he used the AEM EMS because he had to with the EVO Set up. My point is, if he used the AEM from the start he probably would still have a built SOHC motor (that is if he didn't go EVO setup). |
#49 (permalink) |
a EMS is a awesome tool. but there is some that a EMS is not a option, like myself. I need to pass a ODB2 inspection as REQUIRED by the state. He didn't have go use the EMS, he figured it would save him time to do it. FLASH is running the DOHC setup on the stock 3g ecu. Personally I think the best route is evo 8 ecu. This is a easy step for 5speed guys, but I am going to attempt to make it work with a auto.
#50 (permalink) | |
GS-Turbooo
but thanks for the suggestions.. haha Last edited by CloudINC00; 03/11/2007 at 08:06 PM. |
#51 (permalink) |
GS-Turbooo
going to use the T3/T4 56 trim hybrid with DSM flanges so I can keep my manifold and downpipe.
Here's the link: http://www.diamondstarmotorsport.com/turboparts.shtml |
#52 (permalink) |
GS-Turbooo
I thought 17psi was the limit for a stock SOHC head? I already have a camshaft and I'm planning on doing +1mm valves (which were bought) and polishing the ports (not too much, the only thing worth port-matching would be the exhaust manifold because the intake manifold is stock)
#53 (permalink) |
GS-Turbooo
Balla:
I was assuming he meant all 4g63s... is there something I need to know? I looked up some info: 4g63T stem diameter - 6.6mm length - 4.31" intake diameter - 35mm exhaust diameter - 31.5mm According to my Haynes manual it says the stem diameter matches (6.6mm) but the length does not. there's a service limit though, right? Our cars require a length of 4.421"... service limit: 4.402"... 4.31 is smaller than the service limit. Last edited by CloudINC00; 03/11/2007 at 08:45 PM. |
#56 (permalink) |
![]() Join Date: May 2004
Vehicle: 00 3g rs-t
dohc valves are already about 1mm bigger than stock 3g.
Springs are going to be alot more load on them. That could cause a couple of issues. lash adjusters may be able to take out the slack between the valve and lifter but will prbly tick loud. Also, wouldnt hurt to check for any valve to guide clearance issues |
#57 (permalink) |
GS-Turbooo
so technically its +2mm O/S? I don't think the head can be modified for +2mm, can it?
And (about the length) the service limit for our head says 4.402" so can the lash adjusters really compensate that much slack? the DOHC valves are 4.310" Last edited by CloudINC00; 03/11/2007 at 11:02 PM. |
#60 (permalink) | |
Although I share your advice that a serious turbo/engine build setup require a serious management, a al EMS or reflash, I disagree with your characterization of the 3G ecu as as somehow fundamentally different than others and hard to tune. Other than the incorporation of the long term fuel trim to open loop (which has been documented for quite a while and identified on other Mitsus) there is nothing special about our ECUs. Instead, I would put it like this. Tuning timing is absolutely critical in a moderate to high-power NA to turbo conversion. There is no piggyback that has demonstrated that it is consistently able to adjust timing on the 3G. Moreover, altering the airflow signal to compensate for larger injectors will only get you so far. So the only real options are to reprogram your existing ECU to make these changes or replace it completely.
Turbonetics DSM manifold Turbonetics T3/T4 AAI intercooler & charge piping Greddy Emanage Blue 440cc injectors Pocketlogger and PLX wideband Tsudo 2.5" Catback Hook'em Horns! |
