#62 (permalink) |
GS-Turbooo
the one im building im going to part out.
Stage 1 RPW camshaft and those stainless steel valve springs. Yeah, his head already had all the work done and I was tired of trying to find someone to build the head for me. I think Playa's friend was supposed to help me out |
#63 (permalink) |
turbo? unf unf!
did it myself using a bench grinder and a few hours of time :/
usually everything is done in house now
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project |
#64 (permalink) |
turbo? unf unf!
was it even ever used after me?!
#65 (permalink) |
turbo? unf unf!
i sold it a long time ago, but i think cloudinc got it from the guy i sold it to
#67 (permalink) | |
#71 (permalink) |
turbo? unf unf!
what do you mean, you want to buy the part manifold i made so far?
#73 (permalink) |
turbo? unf unf!
![]() the flange is CNC cut, tb flange is CNC cut (made for a 75mm accufab tb), velocity stacks are made, backing plat is cnc is cut, injector boses are made -- all that needs t obe done is the plenum has to be made and welded together
#74 (permalink) |
turbo? unf unf!
car is very close to being startd, im excited
![]() ![]() relocated the p/s cooler ![]() making my own fuel cell, since the plastic ones are a piece of shit -- they leak at the fittings since they use a teflon washer and a jam nut. the aluminum cell still needs a sump made and bunch of other work ![]() run new p/s lines to go around the engine so taking an engine out will be a piece of cake, these are the lines that are a pain in the ass when doing engine swaps ![]() and here she is ready to be awakened
#76 (permalink) |
turbo? unf unf!
![]() yay, fuel cell almost done i've never really welded aluminum before, so dont mind the heavy beads! just made sure it doesnt leak
#79 (permalink) | |
turbo? unf unf!
aluminum welds all come out like that, they are just wider than the usual cause i added extra filleri pressure tested it at 5psi already, i just need to water test it
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project Last edited by zeeshan; 06/09/2007 at 06:26 PM. |
#80 (permalink) | |
turbo? unf unf!
roll cage might be in the works soon.. not a priority though. priority is getting this running good and then swap the evo-built motor in, and then worry about that
#81 (permalink) |
GS-Turbooo
how much would it cost for you to finish up that intake manifold? Mine cracked where the throttle body is and I need a new one. ASAP... haha...
BTW: Nice work there man... updates on oil pan? haha... I also always thought you were going DOHC |
#82 (permalink) |
turbo? unf unf!
i am going dohc -- this is my test setup
![]() i did extensive work on the car over the winter which i'd like to test all out on the sohc motor and ensure everything is running the way it is before i put my built motor in (which is done too!) i pmed you about your oil pan asking if you got it or not, i do have a tracking number if you want, pm me the intake manifold that i have for aluminum will cost you an arm and a leg to complete to be honest -- it needs the core component -- the plenum so far the cost of it is 300 cdn with the velocity stacks, backing plate, injector bosses, intake manifold flange, 75mm throttle body flange the most expensive part is the intake manifold flange which had to be cut on a cnc if you want just that and want to take it to a local shop to get the plenum made, i can sell it to you for a lot cheaper since youll be making more use of it then it sitting around if that doesnt work, i do have a stock intake manifold around here btw, did you have the 2 brackets connected to your intake manifold? the throttle body stay and the intake manifold stay (the one that goes on the bottom)
2005 -- 326whp/339wtq 50 trim, stock motor 13.61 @ 108mph 2006 -- 400whp/400wtq 50 trim, built sohc 12.98 @ 114.7mph 2007 -- gt3582r w/ stock motor, 12.84 @ 116.55mph 2008 -- built 4g64 w/ evo 8 head, gt3582r 2009 -- 3g back to stock (daily driver) + 93 fd rx7 gt35r project Last edited by zeeshan; 06/09/2007 at 09:36 PM. |
#83 (permalink) |
turbo? unf unf!
fuel cell is done!!!!!!!!! wewt!
pressure tested it at 5psi, then washed it, then water tested it -- passed it all ![]() ![]() now i just have to make the two outlet fuel lines for the dual pumps and some how throw a pre-filter on each one of those lines :/ as for the custom wiring harness -- so far ive made the power lines for the alternator and starter.. still need to finish off the efi harness and i can start the car!! im scared and excited ;p
#84 (permalink) |
turbo? unf unf!
fuel line return hoses made.. i had to get rid of the rubber ones and put ss braided ones cause apparently you can only have 12" of total rubber hose according to nhra regulations
#85 (permalink) |
turbo? unf unf!
yes! just tested it.. no leaks. just need to get the efi harness in -- too excited
#88 (permalink) | |
turbo? unf unf!
then he sees my tank in the rear and goes "oh" and walks away.. it's funny as hell when people wonder what you're doing -- but i guess after a while it did get annoying and i was trying to find gas stations that werent busy
#89 (permalink) |
turbo? unf unf!
vive le quebec!
#90 (permalink) |
turbo? unf unf!
vive le quebec!
i will be heading down to montreal sometime this summer
#92 (permalink) |
turbo? unf unf!
it runs
#94 (permalink) |
turbo? unf unf!
#97 (permalink) | |
turbo? unf unf!
no need for it when using hood pins
#98 (permalink) |
turbo? unf unf!
its gone ![]() there's a mini one in the front that has fuses for mfi relay ign relay rad fan relay and starter relay very basic stuff
#99 (permalink) |
turbo? unf unf!
ahh i was wondering what was going on
#101 (permalink) | |
finally BOOSTED
Vehicle: 19.5 PSI SDS 2004 blk GT
yeah! i wanna see more pics and here whats goin on with this beast!
Black on Black Injen SES catback exhaust AEM Cold air intake progress rear sway bar http://bloodweed.mybrute.com |
#104 (permalink) |
turbo? unf unf!
sorry for not updating in a while!
i went to the drag strip though to run consistent 13.337 @ 112 mph, i can post up time slips if anyone needs to see all the little fine details. i was running around 2.2 / 2.3 60 foot times! i need to run with slicks and see if i can break into the 12s with the poor stock sohc to give you a comparison to my built sohc motor with a 50 trim, i was running 12.98 @ 114mph, best trap was 116~ mph.. so this gt35r on this OEM motor running 14 psi is pretty goddamn fast ![]() i estimate its making around 340whp / 355 wtq.. but we will see on the dyno on august 2nd
#106 (permalink) | |
GT35 DOHC 500wHp
Vehicle: 3G turbo
#107 (permalink) |
Soon to be boosted..
Vehicle: Eclipse GS '01 - Sporty
really nice... these are the things i need to hear and pump me up on my turbo project!
GREAT JOB!!!
'01 GS Sporty http://www.club3g.com/forum/showthre...89#post2008789 TURBO Project: http://www.club3g.com/forum/rs-gs/94...o-project.html |
#108 (permalink) | |
turbo? unf unf!
i quaife differential in the tranny
#109 (permalink) | |
turbo? unf unf!
the built motor i think ill install this winter since i cant waste anymore time working on it since winter is just around the block once again the built motor i used the 4g64 block with 4g64 crank, the pistons were custom speced to drop the compression to 7.8:1, the rods were eagle rods, arp main studs, arp head studs, clevite bearings... thats about it for the block then there's the basic stuff for the evo head that's done to it
#110 (permalink) | |
GT35 DOHC 500wHp
Vehicle: 3G turbo
i want to see it. I will swap my head and build my motor this winter so it is going to be done at same time as yours. I will probably upgrade turbo to keep up with your bad boy .PS I need to find good shop to port, and oversize ports of my head. Where yours was done? Last edited by slava; 07/17/2007 at 12:27 PM. |
#111 (permalink) | |
turbo? unf unf!
i plan to run 35psi or on race gas.. but on street gas i'd like to run 25-26psi
#112 (permalink) |
Turbo/Haltech V6
Vehicle: 00 Eclipse GT-T
Really nice numbers!! STOCK 4g64 + gt35r @ 14psi =13.25 1/4 mile. That is impressive. I can't wait to see the numbers with the slicks on. Keep us updated.
#113 (permalink) |
turbo? unf unf!
man im such a moron. some guys wanted to see my time slip , so i decided to take a pic of it... and what do i find. i raced my friends skyline gts-t and i actually ran a 13.2! ;p , so 13.2 @ 110 mph is my best time
im car #237 ![]()
#115 (permalink) |
turbo? unf unf!
yes
#118 (permalink) |
turbo? unf unf!
car weight is 2924lb with me and all fluids full.. including fuel (14 gallons)
i have all my interior pretty much.. except the headliner, and non of the HVAC stuff behind the dash
#120 (permalink) |
turbo? unf unf!
going back to the drag strip tonight to see if i can do better!!
